View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Thinking of lowering my EG question!!!!!!
- eg coupe sun roof leak
- eg coupe rear seats
- B series swap (power steering ?)
- Intro and Question about P/S
- EM1 engine mount
- Wierd Lights problem.
- Springs that don't drop much?
- turbo build NEED HELP!!
- 2000 LX (D16Y7) Motor/Trans mounts, torque-limiter, shifter bushings, MPG, etc.
- damn o2 sensor ?
- Replaced hatchglass shock mount
- Can i use ARP and Orginal head studs??
- Check engine light came on after turning on wiper
- Location of G401,G402,and G552 on 99 Civic
- 92 EG CLutch!!!
- Inner CV joint pulled apart?
- Black housing headlights
- Freakin' Window
- List of Civics with no tach?
- Opinion on Delsols and Miatas..
- gasket HELP!!
- Need a new header which kind should i get??
- My poor clock and dash trim!
- Sunroof probelms
- Tranny.... YS1
- Clutch master cylinder leaking after tear down / build up, any ideas? 1995 vx
- Drive shaft gaiter change
- Distributor Question!
- What sideskirts are these?
- Ls/Vtec bucking
- New Header problem????!
- civic/del sol shocks
- what brand rims are these? pic*
- 93 civic b15b7 throttle question
- hardcore n/a guys
- Pls help! Blinkers stopped working?
- strut problem
- New to the scene somewhat...
- cluster trip meter & total meter didnt work...please help
- Questions about exhaust.
- Chipped p28 in a stock 00 Si
- Some Air Condition installation question.
- will gsr rear seats fit an eg coupe???????
- mugen intake system?
- idle surge smoke puffs black bumper gas smell
- 92 civic eg conflict
- MY FOGS ARE IN WTIH PICTURE
- 99 si wing 4 sale
- h22 eg ques
- Why Do People CUT ECU wires? Now I'm screwed!
- wiring foglights as blinkers in my ek
- I think I just got ripped off on this ECU - PICS
- obd1 dizzy on obd2a harness
- Loud Screeching coming from passenger wheel area??
- Getting on hondamarketplace
- power windows come off the track
- need help deciding wat color i shuld paint my car..
- Suicide Hood!?!
- just wondering if these fitments will work on my 97 hatch?
- oil leak in the cam seals
- 99 si lip on eg
- JDM SIR Cluster illumination dimming not working....
- What Do You Keep In Your Glovebox?
- HID QUESTION
- Where can I buy a 99-00 Si lip
- warnig to all civic & integra owners
- Car starts but dies if not given gas
- anyone have spacers on their car? if so post pics plz
- Headlight problem? (EK)
- headlights dont work on 2000 em1
- Mini me Y7/y8 parts list
- B16A2 Spun Rod Bearing / Rebuild
- Substance in intake
- Lx w/ Da suspension
- antifreeze leaking...
- CHECK OUT THIS VID!!!
- eg question
- Air Duct For EG
- rainy day, clipped a car, need a opinion c/f fenders
- Broken Valve Cover Stud
- side moldings
- getting bugs out...
- B18b1 non vtec to vtec?
- looking into this HB opinions good buy????
- NEED HELP
- How do i replace my boot?
- 91 da dash conversion into 92 eghatch? Has it been done?
- EG OEM style Foglights question - Why is one side bright and the other not?
- NEED HELP WITH STEERING/SUSPENSION PROBLEM PLEASE!!
- FTIV?
- 00 ek Si cluster into EG?
- Does any one know were to get plastic clips/screws for wheel liners
- b16a2 engine question
- clutch line fluid empty? wtf
- can arp b16 studs be used in a gsr?
- 99-00 Ebay Knock off JDM fogs need help
- 1999 Honda Civic Si ALL MOTOR HELP
- gsr glove box fit civic coupe
- Faze Tach install
- Bought a ek hatch trunk is un aligned help!
- i have an eg question
- Gude or Web high per. camshafts advice.....
- fuc* thieves..... less than a month..
- Rear LCA
- Stolen - 93 Civic Hatch Satin Black
- got a problem with axles
- 93 Si rebuild (56k warning)
- Installed some new toys yesterday, tell me what you all think
- windsheild and roof rubber
- Brake problems help.......!!
- Question on the origins of a B16A...
- BIG QUESITON NEED ANSWER PLEASE LOOK CONCERNED
- Does the engine have to be completly cold to bleed?
- know any solutions to the [i]infamous[/i] EK leak in the hatch?
- my hood for my ek wont fit snug. help? w/ PICS*
- p28-a02
- Overheating problem. 93 civic dx
- Sensor question
- Please help!
- THROTTLE BODY SPACER
- foglights blowing fuses...
- B18C swap in 92 CX
- Engine code 15 help please.
- show me your aftermarket tachometers!
- tail/instrument/license plate fuse keeps blowing?
- Timing
- sir2 b16 alternator belt.
- need eg engine bay left side pics. starter wires/ ground wires question.
- FUEL PRESSURE REGULATOR AND P72 ON D16Z6 PRO & CONS
- gauge help
- 92-95 Honda Civic EG Pedals
- Hydraulic clutch problems after swap....
- need help!!!!!
- Suspension Stuff
- Is there a C-West Rear Bumper for 99-00 Coupes ???
- rear wheel studs
- STOLEN CAR. SAN DIEGO. please keep your eyes open
- Which AC compressor for 96 Civic LX
- 92 civic clutch question!!!
- H22 civic intake help.
- I need some experienced advice on my 00 Civic Si
- wicked swap
- Pulstar Pulse Plugs
- Mini Me Swap D15b7 block with a Z6 head need help
- b16 t-bracket on usdm gsr?
- Oil catch can installation
- Question regarding the condition of my light weight flywheel
- car has problems starting after filling up?
- Tranny & Clutch help needed badly
- eBay Coilovers... Suggestions, Comments, Flaming, All welcome!
- obd2b harness question
- trying to put the Ls in...
- civic cam gears...??
- manual doors to power doors!! need info that isnt listed in faqs
- my idle isnt steady....anyone?
- How Can You Tell The Difference?
- buddy club spec 2 for ej1 question!
- How to clean HX Rims black spots?
- I Need Help!!!! F22b2-> 92 civic
- Possible CV Joint?
- How much are B16a2 engine harneses going for?
- distirbutor question
- GSR swap into EK Exhaust manifold issues? 2000-01 GSR maybe? help please
- Car crapped out. CEL went away...plus odd sound
- What is the extra connector near the other injector connectors? *searched*
- eg fog lights
- OBD1 92-95 DOHC ZC?
- Check out this car that came into my work today!
- Are AEM's Truw Power Pulleys worth it?
- 95 civic w/ zc motor questions???
- 1998 Civic Coupe Rebuild
- Wondering if this is a good deal
- mini me - z6/y7?
- b16a2 head build
- 94 CIVIC EJ1 ON SPORTMAX RIMS ....
- Question Regarding Tein S-Techs
- obd1 dohc zc into 93 civic dx 4dr 5spd
- Anyone now how to instal a EG OEM stock Strut Tower Bar on a 94 Civic Ex Coupe ?
- Timing Belt question
- Civic Complaints
- some pics of my ej i've been work'n on...
- Park/dash lights take a while to come on
- i need help finding out what this part is...
- Recommended mileage to change shocks and struts?
- HELP GUYS- HOW DO I POST IN CLASSIFIEDS?
- Type R motor Skunk2 Pro 1's with fuel pressure problems...
- 97 dx hatch automatic jdm b16 swap ????
- cams
- Another o2 sensor problem
- AEM Fuel Rail Fitting?
- need help on a D16Y8 engine
- o2 sensor
- -= Power Window Issue Please Help ASAP =-
- b18b1 oil pump on lsvtec
- k20 help
- quick easy stupid question
- NEED HELP i need a dizzy but need your help b4 i get it
- guage cluster...SEARCHED
- Wheel Hop?
- 97 civic sedan B18A Swap?
- Trip meter and car meter doesnt work..
- help with brake system!!!!!!!!!!!!!!!
- MagnaFlow Header w/ High Flow Cat Combo
- I need help just put cam in!!!
- D15B7 Rod Bearing Replacement
- 2000 civic ex skiping
- unchipped p06 in a 96dx with obd2 to obd1 conversion
- No brake pressure
- what could it be?
- 99-00 front si lip question
- does ep3 steering wheel fit 99 civic si?
- 95 civic si clutch problems
- how can i tell if my fuel pump is maxed? fuel cut?
- Odometer doesnt work...please help
- speedo trouble
- changing a oil and water pump for a gsr...
- Can any one let me know if this is for a EG
- a b16b question
- noob question need anwsers
- Simple question about Automatic interchange
- Suede = my Del Sol's new friend *pics*
- advice on pulling my engine
- CEL light, h22 swap ek. cant find problem
- occasional overheating issue?
- skunk2 throttle body
- 99 d16y8 into 97 ek - which wiring setop to use?? PLZ HELP
- engine mount
- Putting A B16a into a 1993 civic hb
- Start my car, Engage Clutch, Screeching Sound from pass. Wheel, Only when cold (I searched)
- WHO USED TO OWN THIS CAR
- How do you know which engines are OBD 1 or OBD 2??
- please help! smog questions.
- No smooth throttle anymore
- car shake when at 60MPH
- Any experience with a gsr shifter in a civic?
- Foggy Yellow headlights
- spark plug wire
- How to tell the difference between a REAL and FAKE CTR / EK9 96-00 Civic Wing
- HELP CEL 6 coolant temp sensor.
- H22 civic
- quick question
- Looking for a good AC leak detector at a reasonable price.
- HELP FRUSTRATED
- lowered on Tein S-tech, help with little problem.
- car doing some weird things
- CEL code 43 "Fuel Supply System" on B18B swapped EG hatch
- Converting EG to accept a cable tranny
- my friends car has been stolen. please help!!! 92 civic hatch si
- 92 Civic Si gauge cluster into a 94 Dx
