View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Removing a Momo Hub Adapter: WON'T COME OFF!
- Del Sol Won't Start
- hytech with tie bar?
- d16y8 headers and intake manifold questions HELP!
- 08 si wheel
- Emissions for an OBD2 running OBD1 programming
- rear disc conversion question?
- broken fuel pump "I THINK"
- NEED HELP obd2 alternator in a obd0 car
- hahahaha look for a laugh
- 94 sedan clutch problem
- b16 swap?
- Del Sol into Civic Radiator Hose Choices
- 97 dx coupe IAT wiring help
- OBD2 engine/dist/etc into OBD1 car, crank sensor questions + others.
- integra coupe seats into eg
- seat exchange question
- yo a electronic blue si for sale...
- Oxygen sensor Question for B16
- Help.
- D16z6 head on a D16y7 bottom
- Will a rsx type s muffler fit a eg sedan. I've searched!! PICS!?!?!
- Where can I get this cluster?
- Going to look at a 2000 Si tomorrow!
- power steering removal
- S2K gauge cluster swap questions
- 97 civic with h23 engine motor swap?
- d15b7 to d16y8
- mounts (b18 b into a 92 eg)
- ignition coil....
- Price Check Please!
- Price Check Pls EM1 Hood and Trunk
- 98 civic DX PCV on a 98 EX?
- d16y7 smog questions please help!
- D16z6 with D15b7 IM.....problem. please help
- 93 EG6 Si-Gsr Swap
- Will GSR Cloths/Leathers Interior Fit EK hatches?
- Apexi N1 catback question
- Looking for parts for a 96-00 civic
- shuddering when releasing clutch from stop
- need info on sleeves???
- poor cold starting
- driveability issue!!! help!
- 1999 Honda Civic EX flickering lights (strobing, pulsating)
- need help deciding about obdI swap in obdII...
- Timing Belt Slipping.. Help!
- How much is a vtec head worth
- Need advice on bleeding brakes...
- my car squeaks HELP PLEASE
- removing read o2 sensor 00 ex... a little guidance needed
- a/c question
- GOOD PRICE FOR KYB WITH GCS?
- tranny fluid, where to fill? im lazy! lol
- B16a vacuum diagram
- 2000 Civic Wheel Bearings
- NEED HELP: B16a2 swap...need ecu advice
- starter/ignition help!!!
- have a ? about a rear bumper
- Thinking of defouler mod to rid P0420 - How can I check that the O2 sensor is working?
- those with innovative steel mounts b series
- Can you spot my XM antenna?
- 00' Si or 00' SiR
- bumper help
- pls help do u think dis EG worth 8000
- need help rewire dx harness to h22...
- smog test only... wont pass!
- TWM short shifter
- interrior lights not workin
- hydro to cable conversion ?
- HELP! Was changing brakes and tore one of the little rubber grommet/boot thingys
- Civic manual transmission rebuild questions...
- B18C1 Rebuild
- d15b harness o2
- Main Relay location
- HESITATION
- bad gas mileage :/
- B16a2 into 1997 Coupe with D16 - HARNESS questions and IMOBILIZOR
- brake light short - '93 civic dx
- 98 Civic LX Electric Door Lock Problem
- HELP: How to Disconnect my door?
- EK innovative mount question
- tps and map mixed up?
- is it really 93 octane? who knows?
- 96 Lx b16 swap
- black interior color code for a 94 civic ex?
- Ebay fog lights..
- 99 00 CIVIC BEHIND THE DASH WIRING HARNESS
- z6 head on y8 block
- door panel removal steps 96 civic lx . passenger power window button will lock power door locks????
- A/C QUESTION? High pressure on low side? help me please
- ecu question
- tranny question
- Exhaust question
- Metallic sound from my header?
- what ohm fuel level gauge do i need
- I need a p30
- compression test
- Backyard Special Front Bumper?
- 00 SI GAUGE CLUSTER HELP!!!
- car feels like its getting pulled back?
- eg auto
- Shaved Bays Thread
- bseries swap question
- SRE engineering
- My stock tach blew again any one know why I keep blowing through tachs
- Save MY Honda!!!
- need some helpful info on getting a EK9 regged....
- garrett gt-40
- Chassis/Cabin Harness - Cutting Ground Wires!!!
- Can't take a bolt out!
- Need some help!
- raged on the car now it bogs down
- question about a Cat.
- EK FOGS ON EG??? LOOKS SICK.. HELP ME!!!!
- Idle issues w/ Built Turbo D16z6
- P73 ECU
- Have you repaired the elbow hole in your door panel?
- Simple MAP sensor question
- Bad TPS
- most compression????
- Check engine...knock sensor ????
- swapped harness; car wont start NEED HELP!!!!!!!
- anyone heard of dnx
- New :]
- 92 civic with b16a2 swap ?'s
- Home insulation in car ok?
- Motor smoking, please any help will be helpful.
- VSS testing without harness (DOING THIS RIGHT NOW, IN A BIND)
- Just got my EG.. now what?? haha...
- no power in early RPM
- Type r side molding part #
- act street disc ?
- unhook vacuum hose more power?
- Types of seat rails
- Rod/bearing thrown in my GSR today :(
- b20vtec help
- what is the best flywheel to go with exedy racing clutch?
- Vtec at 6500, yes I searched
- S2000 vs 97 civic coupe DX
- random idle surge. help!
- Hi ppl I'm new !!! & I have a confusing bracket question
- 96-00 Civic Window Visor clips...
- Control Arm Bushing
- B16 gearbox oil over fill
- got acouple questions.....
- EG6 Shells?
- EK Power Window Conversion Help
- EK: ? for those w/Benen lower rear subframe brace
- P28 ecu running an OBD2A GSR
- Looking for parts ...93 civic b16
- need some tips on fuel parts
- Help Vtec and spedometer aren't working/ check engine light
- i have a b18a need some help
- need help dont know if i can post it here
- How to replace sideview mirrors?
- WHAT sIZE SLIP STEAMS SHOULD I PUT ON MY ek
- what is P1503?
- can i use the y7 ignition distributor on a y8?
- Mitsu Alternator in 92 Hatch w/ d16y8
- Cannot remove the bottom mount on driver's side
- New kid
- ABS issue after brake upgrade
- H&R Sport springs - any good? Any pics?
- ok so ive looked and need some more help....
- ealge rods vitara pistons what rod/main bearings?
- p73 with sohc vtec?
- dx hatch hub question
- Bird/ chirping sound coming from the engine (D16Y8)
- what is worth doing to my civic?
- Idle Drops/Struggles When Headlights Are On. Help Me Find The Culprit!
- am I about to blow up my A/C?
- More power for my B16a2. Help!
- water pump and flywheel questions
- Replacing '98 Civic Exhaust Manifold
- where is a good place to find a good used y8 head?
- 96 HX CEL Code 61, replaced Sensor, and still get Code 61
- dumb question but not sure
- Problems with my turbo civic!
- my stupid question...im starting to get a headache!
- anyone seen this video???
- Suspension Techniques Front Swaybar (19mm) with poly bushings, endlinks and brackets
- Mod's I Need Help!
- 00' civic radio deck
- Gas pedal stud snap?? HELP!!
- d16z6???
- how to take off fender liner screws??
- over-heating issues
- Car will not start after running...
- shifting problem
- 96 civic VTI radiator
- honda optional shift knobs? anyone seen these?
- Hondata gaskets - any good?
- knocking anyone know?
- muffler
- SRT4 Engine Swap into a 92-95 Hathcback???
- Chipping vs p08?
- Check this video out of a legend!!!!!
- Help.!!
- VTEC problems
- whats this
- Y8 oem billet looking fuel rail fit on B series manifold?
- How to get more power out of my 1993 civic vx?
- Honda B for Boost?
- how to get a new vin plate?
- B16 wont go over 3kRPM
- 93 civic Heater Control Lights????
- DIY GUIDES: CTR Replica Headlights 96-98 EK
- bouncing idle b/c of air in my coolant?
- d15b bottom end with a b7 head?
- B16B timing belt question
- Rattling from alternator at start up?
- Pos and Neg wires for sunroof 95 Civic EX
- 1994 ex coupe FOR SALE(GOOD PROJECT CAR) f/s f/t
- Del Sol - Clutch on floorboard.
- y7 block z6....obd2 ecu?
- Turbo Tuning
- 97 civic ex CEL p1509
- buy new air filter or not - cheapie filter in now, want K&N (worth the $40?)
- TEAMRICE.ORG
- bypass charcoal canister
- H22 bucking/ hesitating
- DTC P0450 and P0453 after Y8 swap
- i want to go to 400 hp
- GSR Swap Problems...
- part number ?
- Wiring nightmare!!!!
- GSR Swap
- 98 lx intake problem, need help!!!
- just making sure: header ?
- wat is the size of the oem throttle body????
- Hood on a 99 honda Civic Coupe
- Del sol Rain Vent Shades Visor for doors.
- 00 EM1 Drives fine, but sometimes won't idle at a stop....
- a red honda si "2000"
- 1.4 cylinder head swap
- how do i convert my d16y7 non vtec to d16y8 vtec
- Megan D series headers exhaust leak woes.
- technical help
- Wrapping the sunvisors?
- Question how to instal universal mufflers?
- VTEC wire harness problem with d16y8
- what piston to run? B16a fully built 600 hp of course turbo
- MAP sensor question.
- Dead Brakes, Need Help.
- wheel hop......mount?
- what are these 2 sensors for?
- Need Help With Engine Management
- Swap Help
- d16y8 built head!!!tell me what you guys think!!!
- whining annoying sound when engine is on
