View Full Version : Honda Civic / Del Sol (1992 - 2000)
- xXx NEWBIE HERE AND I NEED HELP!!! xXX
- B16A vs. H22A vs. LS? reliable?
- newbie question???
- ls/vtec swap into 94 coupe
- 96-00civic/ 94-01 integra?? suspension HELP!!
- K swap into DC
- I C U P JDM MEET (EL MONTE)
- How to polish Rota Slips....................
- Side Skirts
- FAQ: OBD2 into OBD1 into OBD0 into vice versa (WIRING ONLY)
- Itr hubs in stock civic spindle?
- battery for just alarm
- Cluster lights blinking! What does this mean.
- AXLE MASTERS!! please look here. Is this seated??
- The Truth About B20's
- water pump bolt
- Funky noise?
- Throttle Position Sensor
- Is possible to convert an EG to OBDII?
- Need Troubleshooter
- Converting to Obd1 from OBD2B ?
- 5 Lug question?
- WHICH ECU SHOULD I USE??
- car overheating. please help.
- Best spark plugs for 98 B18C?
- Best way to remove outer tie rod?
- '99 4Dr Teg Spoon Exhaust on '00 EK3 4Dr?
- Tranny Trouble
- hard ilde
- How do does this B16a block/pistons look
- need help on new clutch
- Worth the casH?
- Passenger side door
- Is there any diffrence in the oil pan from the 92-95 b16a to the 99-2000 b16a2?
- Brake swap
- Christmas times= fun car problems.
- OBD2b to OBD1
- b18c swap mounts???
- Wanted: 98 civic dx exhaust manifold
- 93 prelude vtec
- GSR in EK wire harness help
- All at once,electrical?
- Does anybody know where I can find...
- best motor to swap into a 92 civic
- Si EK Exhaust
- Filter inside the IACV?
- $5 Sent Via Paypal to the person that finds my problem out!
- 92-95 Clusters interchangable?
- B16 Engine & Tach jump over bumps
- looking for write up on extending shock travel. can't find 'searched'
- how do u tell if its lsd or not...
- poormans type r in proceess....should i port n polish b16a head..
- another bouncing tach and misfiring thread
- Ok! im going too start changing the headgasket on a B16
- Integra mirrors on ek civics?
- 96-00 Duckbill question
- Help rocker arm assembly
- revs good but no power please help.
- Tornado Fuel Saver
- how to id transmission?
- do the EK4 front brakes fit on the rear axel in an EK?
- Taillights are nto wired right...parts are missing. Help!
- Shaking like hell
- broken door lock help
- installing new springs and shocks.
- s2000 cluster in eg
- HELP HELP HELP, distributor question
- a little ecu help please
- d16 to b16 problem help please
- Scammed by PasswordJDM???
- d- series info
- engine swap.
- H22 into a civic EG
- EK9 dash, cluster, etc into an EG hatch?
- Replacing Manual vice Electric Doors
- DOHC ZC with a Z6 Trans
- FS: NOS bottle with bottle warmer, valve, 15' line, brackets!!
- civic/del sol weights
- help with crazy idle on 93 si
- would like to trade 2000 civic lx for a del sol
- Problem with shifting to 1st and 2sec gear
- Honda Coolant reacting badly with Prestone Coolant/Antifreeze???
- LS MESH, how much?
- Car Trouble
- EK front bumper
- b16a intake manifold
- swap
- LOOKING FOR A 92-02 Hatch
- power loss
- New Flywheel bolts needed?
- Need a part number, '96 HB rear wiring
- car is still boggin after replacing o2 sensor
- need pic of certain hatch see details inside
- changing head gasket on 98 d series
- links?
- Idle problem?
- 2000 Civic SI emanage system ????
- help problems with 1993 eg6
- ignitor question...
- omni
- HELP!! Wiring a obd2a dx to obd2a ex!!
- How do I change the horn on my Civic 99 Ex ?
- can i use an ek ignition column in an eg?
- Need Help -- 97 Honda Civic --Push knob on Shift Lever is Hard...
- swap problems
- Leakdown test!
- Del Sol with b16 parts?
- b16 tranny
- muffler setup question
- OKay seafoam Quick ?
- Reputable shops selling del sol parts
- these damn lugs
- civic body partss
- 94 CiViC GSR 4drEG B18c For Sale!!
- VIN #s
- spoon mirrors
- Whats it worth? 95 civic hatch turbo
- painting valve cover
- need to find a 99-00 civic si lip, oem
- tranny fluid sparkle, how does this look?
- Stock Tach JUMPING ???? anyone else
- crank pulley tool????
- ***What Kind of Axles 350Hp Turbo***
- head problems
- AFC Neo
- 92 civic hatch problems
- NEED HELP! car will not start
- Flywheel for b20vtec
- EK 97 hatch GSR swap
- Del sol Turbo
- Head Studs
- Can someone ID this gizmo.
- mystery sohc vtec
- clutch still good? life-wise
- Yet another failed smog...
- RINGS? or Headgasket!
- PROBLEMS W/ HMO...WHY ME!!!
- TPS question????
- 17 VSS - speed sensor ?
- I don't know any other furum to post this in but how much $ can I sell stock BK interior?
- Really annoying headlight problem
- winshield wippers
- What sizes are the HX rims????
- 90,000 mile Maint.
- Does anyone know if Type R seats bolt directly on?
- Air Conditioning question.
- Searched with no luck..integra catback fit my stock EK coupe?
- want to convert my drum brakes for disc.which way to go?
- Parking Brake Swap...
- timing marks on crank pulley
- Ebay Headgasket Kit?
- help a fellow honda owner out
- so i locked my keys in my car.....
- Paging all Gurus - Buzzing/Rattling noise
- mugen chip
- my civic is going downhill quickly
- good or bad idea?
- Failed smog check :(
- Its time for paint
- spinning wheel stud
- here ya go
- K20A or B18 GSR??
- Will Exhaust from EG Coupe fit an EG Del Sol?
- auto to manual swap
- auto cluster in maniual ek
- installing skunk2 coilovers into my 99 civic
- GM synch. ruined my tranny...BEWARE
- cf hood fitment
- rear wheel bearing wear
- first step
- EK9 Power Windows and 99-00 Style Heater Control
- weathertech visors for ek..
- IACV clicks when unplugged and makes humming noise
- Mini-me with no IACV possible?
- need help on installing the guage cluster... please help! :(
- Engine swapped - now these problems! (searched like hell!)
- DC GAUGE CLUSTER
- Moron inside
- Wondering which upper strut bar is better? for a del sol
- how adjust the cam with the cranck in SOHC?
- Heater Problems
- Rear drums vibrate MORE after new drums changed!
- no clutch pedal
- where do these tubes go!!
- speed govener
- d16z6 valve adjustments/specs
- Help with Fuel pump?
- SOHC ZC VTEC
- My EG DOES NOT Shift into GEAR when my engine is ON. HELP PLZ!
- What is this thing wired to the middle of the bumper?
- b16 obd2 into eg
- 06 civic si hatch seats in eg
- heater problems...
- new hatch
- NA Vs Turbo
- b16a2 needs new axles in EG/EJ - which year to buy?
- B16 swap price?
- Discharging Freon?
- HELP: I need measurement of the oem 99-00 Si endlink.
- Overheating Problem - 99 Hatch (recently Flooded)
- Zex Nitrous Kit #82011, HELP!!!
- 1999 Si???
- Glad to be back in a Honda, my "new" car
- For those using after market rods, eagle,tuner toys etc....
- Power to manual windows
- umm a lil asistance pls......
- production date on head
- speedometer problems
- <<cams?.
- I did the search thing and nothign came up for engine work in chicago.
- Need Help And Advice
- has anybody heard of this???
- vtec wiring d15b
- Whats a good gray/sliver
- title says clx
- wil 94 civic cx tranny fit on 96 dx
- ???about ecu harness
- Ghetto rig vtec wiring
- Will 4 door headlights fit2 door headlights??
- B18 SWAP INTO 98 CIVIC
- check engine light on ek9
- rev limet kickes in a 5000 not 7200 like it is sopesed to
- STEERING PROBLEM!!!!!!!!!
- 92 civic CX Tach Problems
- 94 Civic CX - Clutch (?) question
- It's almost Christmas, so help me? 95 Civic DX front bumper question...
- b16 swap into eg
- Having hard time weighing odds...
- sold my gsr, bought a 93 si hatch with a frank???
- KYB AGX question
- Engine Cooling Problem w/ 94 Civic
- HELP!!! Stuck at WOT!!!
- Whats the specs on a d16z6
- d2 coilovers , how do i set up the spring rate ..?
- has anybody ever heard of terraclean?
- Headlight bulb size for a 94 civic
- Quick question on short shifters...
- Defective Clutch?
- EG/ ITR brake upgrade question
- how are your AGX's set up?
- Considering a 7th gen Civic and -
- valve cover question
- OBD reader "Connection Failed"?
- A/C Compressor Turning On and Off
- I hate my wife but gives me an excuse to buy....seat belt related
- 93 civic engine code plug
- help !!! 4 CKP - crank position sensor
- Throwout bearing or input shaft?
- 95 Honda Civic tech Question please help...
