- 94 civic ex coupe power windows
- Burning Coolant like CRAZY! HELP!
- how to count the check engine codes?
- ATTN TroubleShooting Guru's:::: Motor Wont Start!
- Tire Size
- Honda Civic chick needs help with overheating issues!!
- suspension on EK?Please give me some advice. I did search
- TPS
- Engine Swap Help
- 01 gsr in 94 civic smog legal?
- interior wiring problem on EM1
- Stage 4 clutch difficulty
- s80 transmission what is it??
- Braking noise
- B18A1 swap into 93 Delsol(dail up die.)
- I got a leak. Checked the Service Manual. plz help!
- Fender question
- insurance
- 96 d16y7 engine issues, please advise...
- 98 hatch (civic) cx with 97 teg motor
- Omnipower Full Drag coilover???
- car spudders a lot and has no top end power
- Bumpstop question
- I would like to chip my computer to the specs of a dual cam computer can someone teach me
- Where else can oil be leaking from?
- b16b issue plugs have 2 melted electrodes 2 shattered white areas HELP PLEASE
- Help! Tranny removal a no-go - stuck on block.
- Problems with a Map sensor
- ECU CTR
- rear lower tie bar
- got fuel, no spark, read what my situation is!
- Kswap in a 94 eg
- need thread for auto to manual conversion
- A tip on oil filters: I lost 8-10 lbs of pressure with.......
- OBD-I and OBD-II D series transmission interchangeability
- sohc vtech computer
- Car idles great...until it warms up, then it starts acting funny!
- EK navigation to 00 civic coupe
- how do i install an air/fuel gauge?
- power options in the door panels just died
- ticket for aem intake
- Civic 92-95 EG6 power mirror covers; cover
- Question about shock disposal
- WALBRO PUMP ISSUES
- 99-00 si floor mats
- EF Shocks into EG hatch?
- need some help dont know wats going on with the motor
- can I use a single cam non VTEC ECU(D15B7) to run a dual cam non VTEC motor (B18A1)
- What Exhaust???
- turbo that sohc d15b7
- White smoke and fuel coming out of exhaust..
- Where to buy 5-wire o2 sensor -best price-
- fuel injector help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
- cusco zero 2 coilover .
- Civic Si or Del Sol??
- 96-00 lower ashtray help
- stock rails on aftermarket seats?
- a/c blower doesnt work
- Have both y8 and z6 longblocks. What parts to choose for minime
- Found These Parts In My Sol Door - What Are They?
- what will fit
- A/c with type r
- Coolant leak help.
- Canadian CX's
- '95 B18c1 into 99 civic cx??? Won't start!
- 2000 Civic SI
- Vtec sylenoid
- tein ss question
- gsr seats on to eg
- B16a swap 94 coupe. PICS INSIDE
- Ever see a backwards moving engine? (Video inside =))
- help with installing alarm
- 94 si GSR Swap
- Eibach pro street s coils
- smoke when started up...
- camber kit?
- ecu tuning
- car dies and ecu fuse blows???
- am looking to buy some light bulbs which ones are best?
- Flywheels on a ex tranny.. any opinions?
- optional canadian rims?
- d15b no spark
- DC carpet in a EG
- check engine light
- Quick Question
- Miracle Cross Bar or EMRacing Bars ???
- Check Engine Light
- Z6 head
- 2000 Civic Si doors
- Where is my PMG-FI main relay
- any import shops around Syracuse NY?
- Ek Supension into EG
- Quick o2 sensor question
- cluster change please read
- srs light?
- jdm d15b swap help
- oops
- maybe stupid question about knock sensor and smog on mini me
- Motor Questions
- who is this
- will tockico blues for an integra 90-93 (da) fit an ej1?
- eg rear disc conversion help please
- Compression screwed :(
- Defi Guages?
- do i stand a chance?
- oxygen sensor replacement inspection
- LS/VTEC vs. GSR
- Help with axles ASAP
- EX tranny on Dx
- Is it safe.......
- clank/ creak from rear while braking
- aem v2 (strange sound)
- Tranny Issues.....Any Help???
- IS A GSR AND B16 OIL PAN IDENTICAL?
- Back again
- is aircraft paint remover bad for rubber?
- squealing sound when taking off ???
- ep3 seats in a del sol?
- new Here
- EG to RSX seats
- help 97 civic ex d16y8
- EK Suspension into an EG...Anyone done this before?
- some sohc all motor questions
- hatch seat dillema
- back brake seized!?!?!
- Eibach Pro Springs on 99-00 Civic
- Need tuner in MD
- Where should my idle be? (Boosted EM1)
- air bag q
- anyone ever purchased these?
- taking off main crank..
- Injector Question. Help!
- need help asap b18c1 trouble
- gsr swap question
- Will 99-00 Civic evaporator fit with 96-98 lines??
- ZC DIZZY WIRING HELP
- Civic 92-95 EG6 power mirrors covers; cover
- obdo b16 in a delsol
- car power problems
- removing p/s question
- Climate Control Help
- suspension
- My DD finaly died. I wonder why?
- any pics of 92-95 civics with these tail lights?
- Kswap in eg?
- Just brought a EG HATCH ANY SUGGESTIONS?
- ECU
- k20a or b18c
- gsr in 2000 civic si
- installing ac in my cx hatch
- NEED HELP!! Car died and won't start!!
- grs brake upgrade
- INtercooler
- cams for a gsr
- built B17 swap or LS-T
- touch up paint
- 95 ex died yesterday need help!
- Just bought a 97 Ex Coupe
- rear disc swap for eg hatch already search!
- CRV Gauge cluster question.
- HELP ASAP.
- help with a little surface rust
- crv-b20b-z transmissions
- FMU ?
- turbo help! need some one
- please help identify the sensor
- b16a ns b16a2 cams
- What color is the positive wire going into the fuel pump on a 94 Civic Coupe EX?
- My civic isn't starting please help
- B16 turbo rebuild
- Mugen Brake Upgrade for Civics in 4x100 12" rotors is complete!
- motor smoking
- Exhaust help?
- Troque mount question
- tensioner spring.. DO I NEED IT??
- Hydro and Cable clutch compatability
- rear disc conversion question?
- 50 state legal
- H2B
- Tranny ?????
- Pwer steering leak, need help!
- car alarm help etc
- OBD0 alternator converted to OBD2a plugs, possible?
- just wonderin.
- harness bar question
- i need help with my timing belt
- question about transmition code
- What lip is this?
- How do you install aem short ram intake on 96 civic?
- Bleeding coolant
- egale rods with ctr pistons?
- how much deos it cost to swap a k24a1 with a k20a head into a EG???? answer inside
- Conversion Help! Sorry!!!
- Conversion Help! Sorry!!!!
- 4 Door Honda Civic post here!
- Engine temp fluctuating during road trip from Portland, OR to Las Vegas PLS HELP!
- dont know where to put this but leaking trans fluid
- Put some faces with names on MySpace
- Very Confusing dont know were to look next?
- cluster and cat question with B18c1 swap
- which mounts to use?
- skunk 2 full coil over reviews
- ebrake adjustment after replacing rear shoes
- civic start up ?
- Help with injectors
- my crank pully fell off need asap!!!!!!!!!!
- FOGLIGHT HELP!
- 2000 Honda Civic Dx 4dr - weird engine noise
- Engine noise
- Are 92-95 civic ecu pins different from 96-00?
- oem headlights
- 110000 miles
- stock intake...
- Need help on timing belt
- 93 civic help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- how many engine/tranny mounts for 98 Civic LX 4 doors
- Problem with brakes
- How do you get water out of the engine cylinders?
- Rota C8 Center Caps (searched)
- A/C line wont fit new drier?!?
- Check Engine Coming On And Off While Im Driving On My 94 Civc Ex
- P28 Ecu
- cant figure this out
- ls crank in a b16?
- IDLE PROBLEMS 93 civic si hb
- oe dust boot on kyb gr-2
- CEL 6, 17
- headlight: turn signal trouble
- Any other ways of checking CEL without jumping connector? obd1
- which ecu harness do I need?
- Rear gathers speakers...
- VSS problems
- Tanabe Touring Medallion
- Camber adjusted now fender rub and sagging?
- just failed smog and need some help
- Del Sol Stalling
- what is this????
- Intermittantly decides not to start?? Possible problems? No CEL (94 EG EX Coupe 5spd)
- valve cover washer question
- any ideas of my 2000 cx?
- Exhaust leak on resonator?
- please help i only have until 4:30/5:00!!!!!!!!!!!!!!!!!!!!!!!!!!
- Mud Guards for EK side skirts on EG Body
- ecu question...
- 99-00 civic Fog light wiring question help
- New project car just arrived!
- I Need Help on a swap
- exhaust problem
- Axle help
- Question about oil pan****
