View Full Version : Honda Civic / Del Sol (1992 - 2000)
- how do i add power windows and locks to an EK????
- EK swap
- b16 first gen swap in an eg6.....
- Weird Idle At startup
- Skunk2 ECU or stock p72?
- replacement headlights for EK civic?
- Having some problems with my JDM B16
- Pic of my 6 point cage
- Is there anyone who makes subframe connectors for del Sols?
- ek si cluster in a eg hatch???
- Engine swap for 2001 ex??
- Just fixed my problem. (VSS)
- flat black steelies
- Mods for my 2003
- My car died today and I need some help
- need help on how to bleed after replacing the pads
- ITBS on B18c
- d16z6 firing order ?
- First Time At The Track Tell Me How I Did
- HELP: obd1 wiring w/ OBD2 b18c motor
- rocker arms ?
- EG and EK suspension
- i posted this in the EF catagory, hope its ok here: NEW SOHC Honda Resource
- 195/50-15 on stock Honda wheels
- used vs new pricing
- keep on blowing fuse wtf?
- Apexi WS vs RS-R Exmag exhaust
- Headlight wiring trouble...
- Need help my engine is overheating
- my floor jack broke =(
- Do they make LSD for...
- b18a into DX
- difference between b16 and type-r tranny
- 99 civic si please help
- Quick n00b intake question...
- lug problem please help!!!
- idle control valve, from B to D series are they the same??
- Why do my ls's make this noise
- ICAV and Idling screw spec
- got a new cluster. i want to match (roll back) the miles!!! please help!
- Engine Cleaning?
- Sounds to good to be true
- Spark plugs
- Will rear disc(hub assembly) from a 90-93 integra hatch work on my 5g coupe?
- stock fuel pressure for b16
- HELP needed
- Fields Vtec Controller Problems - Not working anymore
- will these fit my car?
- long term experience w/ POR15 rust remover???
- 96-98 heater ac conversion to 99-00
- rear control arm problem...
- dropzone coilovers with KYB AGX
- Meetings and Fun
- fuel pressure reg and gauge help
- map sensor ???????????
- need help buyin new ecu
- Installing Header
- Got Back from the track
- Sites that sell disc brake conversions
- FS: D16Z6 from 95 Del Sol
- older engine into newer car ......opinions
- can you name this rim????
- Anyway to check and make sure ECU is good?
- Header/exhaust wrap question.
- Running Vtec...Need Help...
- Toda cams
- Civic Type R Carpet with Integra Seats....
- Are vtec and NON vtec distributors compatable?help asap please.
- Anway to check to see if struts are blown?
- jackson charger off of a b20
- got a 93 hatch/ might trade for EF or vw golf
- Takumi Project: Excellent wheel shop
- How fast is EK with B18B?
- Idle problems again?
- Popping noise when hitting about 3-4k
- track times... high et high mph
- Automatic to Manual
- Change from automatic to manual
- differences between a DX, EX, etc.
- I just had a cruise control crisis... (2000 Si...kinda long)
- Choking and dying motor help!
- MC too small
- seized crank bolt
- ECU Knock sensor Pin
- ek front and/or rear conv. on a eg?
- noise coming from distributor
- 99-00 Civic Si Cluster, what warning lights?
- Cheap coilovers, pictures and tech questions
- Need Help With my Hatch
- Need Help With Penals
- Clutch Differences BTW 4, 6 Puck & Full Organic Face???
- windsor cops suck
- time for a new clutch what you guys think?
- Power Door Lock Controller
- bronze rota circuit 8
- Harness with projector headlight problem..?????
- dolls hangin from cars...lol...?
- si door panels into dx
- aftermarket brakes for 96 civic dx
- *NEED QUICK ANSWER FOR QUICK QUESTION*
- Quick! I need to know if the master cylinder or Brake booster is bad
- check engine light asfter install
- Timing belt?
- what are good sites to buy parts off of
- somebody has to have the CTR radio delete !!!
- who makes a good throttle body?
- part # for EG armrest and audio console
- VAFC controller wiring into non VTEC ECU?
- Are my CV Boots Blown?
- how much coolant in a 1995 del sol si?
- gsr tranny on b16a2?
- -car WONT start-
- Brakes squeek when let off, when car on, or off
- 93 z6 manifold on 96 DX?
- Cylinder head question...
- dumb ida or good ida? please help...
- will integra door panel fit in civic
- Help with CEL URGENT
- Carbon Fiber Air Duct
- My car just lost its virginity to spray
- About to Get an EK
- Wiring problem in my hybrid civic
- Ground Control coil over key?
- Funky retarded n/a intercooler question.
- VAFC settings, NOT using the hack... ???
- question regarding rear suspension..
- HELP! I twisted off one of my intake manifold studs
- I LOVE MY D15B7 *CHECK MY TIMES*
- Skunk2 instake manifold on D16z6
- cams
- what the hell are these lines.. Newb quest.
- Changing suspension setup. (take a look)
- '01 USDM ITR rear seats in an EK...installation?
- Emissions help on EG / GSR swap. . .
- 100 octane too much?
- rear seat question
- just blew my damn motor!!!!
- WTF is going on.
- hondata on sohc vtec???
- how do i tighten the head bolts on a d16z6?
- Del sol leaks need help
- OEM ex power window & lock panel conversion
- Del sol's???? HELPY!!!
- Help me.... Problem with car
- Honda Civic 97 Check Engine on. What to do ?
- H&R springs...
- pm6
- how do i take my headlights off?!
- B16 head with a B20 block????
- got a sohc vtec but still have non vtec ecu
- Where do you guys weigh your car?? Mine was 2650 lbs???
- Props to iLLuZioN-B18C1
- head build
- How-To: 1992-1995 Hatch FULL integra brake swap: lots of pics!
- Radio Trim on 2002 Civic
- my car is starting by itself
- Need help with Tein S very simple, please help quick
- fuse box cover
- OBD2b - 1 harness?
- C1 in eg hatches....what are you mods?
- Head build!
- h22 shifter
- ENGINE PROBLEMS
- what would i need to install this?
- new motor for 95 ex
- RHD guage pods
- map sensor wire question
- !!!ANY & ALL EXPERTS!!!PLEASE LEND KNOWLEDGE
- New to forum
- map sensor p30 pin points.... any one have them.
- map seneor p30 pin points... someone have them
- high reving idle...about 2000...but no check engine...? a vacumm leak..?
- Anybody make a B-Pillar Bar for 92-95 Civics?
- The project is done!
- Best tire size for LS Mesh rims?
- si gauge cluster from japan?
- anyone delt with www.autosonic.com before?
- OEM Power window & lock installation help
- Brk Light fuse loc on tru jdm civic?
- ls swap now having wierd idle issue!
- anyone made a jdm Integra cluster fit in a Ek
- my rediculous weekend (56k, ehh maybe?)
- turbo install questions...
- ITR 5 Lug on EK help...pic included!!!
- Espelir Catback review with pics and vids
- Which is the correct ignition?
- dyno question
- Need help with del sol.
- Help !
- someone answer for good! haha
- Turbo set up
- do i have a bad clutch?
- do i need the heater box for the teg dash swap?
- Speakers/Headunit die out randomly, What to do???
- tdc points ?
- I'm sure this has been asked before but...
- D16Z6 Skunk2 Stage 1 Cams
- PW switches
- how the heck do you use a spring compressor
- Who has Injen intake?
- EK sir lip on eg?
- what happened to that guy
- Need Help On Interior wire harness
- Settings a Vafc II on my 2000 civic si
- resurafacing stock d16 flywheel
- Smog in CA? Help?
- What other E models can't fit on a Ej1?
- Replacing the speakers in ek
- remove intake mainfold gasket..searched
- Body kit for 2002 civic. Will it fit on my 2004 civic?
- question about true coilover systems
- EP3 Steering Wheel on EK?
- Rough Idle When I Apply Brakes...
- can i smog
- ek death......
- single came wont start due to rain
- what do drag racers aim for when building motors?
- South Jersey?
- where to buy 99-00 SI Front lip
- MY 97 JRSC civic ex broke. what should I do now?
- How come theres still wheel gap in the back with my GC coilovers?
- Need help/advise on removing automatic shift cable
- Worth putting Type-R steering rack on a non-PS EX EJ1??
- shots of the civic
- need a car have $4k hook me up Phoenix, Az
- My civic sucked water
- Spring Bolts for Apexi N1, help quick
- anyone have a installation guide to instal a intake mani......
- Si wheels
- HELP!!!! 4 CELs after D16Z6 swap into 95 CX
- new tranny?
- F/S 2 Eclipse 87 series subwoofers(good price)
- Mounts?
- How to: Wheel bearings?
- getting rid of an airbag light? !HELP!
- 99 Gsr Radiator?
- CF hood and fenders
- Maryland Civic People enter
- need help
- Help needed for CTR Sway bar on 99Si
- SideMarkers Parking light or trun singal?
- I need SSR Lower Control Arms (LCA)
- Pics Pics Pics....First time ever! (FBP EM1 Si)
- Oil pan differences?
- Cruise Control Button Amperage?
- helpppp
- subframe tearout with beaks kit?
- y7 manifold differences?
- Problem w/ clutch/tranny ...advice needed
- first impressions on new sir II jdm b16 longblock
