View Full Version : Honda Civic / Del Sol (1992 - 2000)
- car driving weird
- can gsr or 99-00 si motor mounts be used to put b-series motor in a ek
- anyone running a vtec controller- (Fields)
- radiator support civic sedan
- Secondary O2 sensor
- Front End Vibration on my 00 SI
- after 3 hours of trying to make it work..... it didnt fit
- 94 EX coupe sideskirts and 94 SI hatchback sideskirts
- Better power for the money: engine swap or purchasing a whole new class of vehicle?
- Mini Me distributor question please answer!
- What kind of axles are good?
- AEM Hybrid Intake
- My civic sounds like a lawnmower now?!?! HELP
- Benen Strut Bar in EK
- mini me
- My Car Wont Start!!!
- gas mileage question
- Insurance Question
- ebay mod chip
- Skunk 2 OBD2-1 Harness Question
- help ecu
- Stripped 00 SI questions about new engine
- catback exhaust
- Help Quick Please!
- The JDM P08 Ecu have knock sensor?
- car just goes TICK
- type r head
- eg w/ h22 exhaust question
- things i need to clear up real quick ..(auto to manual stuff)
- 2000 ITR doors on a 94 civic hatch?
- Should i pursue this?
- JDM gsr cluster in to 99-00 civic, quick question...
- A/F gauge install question...
- having trouble starting the car =/
- Why do they keep locking my threds and wont let me post in classifieds
- help; ques about injector selection
- is it a CDM car
- Draft:Is there bolts missing from my head. (PICS Inside)
- what should i do to my 96 hatch
- Hyper Ground System
- ANYONES CAR EVER JERKED SO HARD YOU THOUGHT SOMEONE HIT YOU??
- OBD1 or OBD2 B18b in a 96 dx?
- Idle air control valve can anybody help
- B-20 swap need help
- Trying to swap a GS-R engine into my 97 civic
- Sunroof Wiring
- integra master cylinder in ek
- need help with choosing coilovers..
- suspension setup question
- JDM 96-00 mirrors out the a**
- Spoon ITR motor
- *new* Pics of your vehicle, pics only NO COMMENTS.......NO COMMENTS, 56k beware
- where to get testpipe/ cat convertors???
- DIY: How to GUT your CAT ????????
- what is ITR and CTR?
- Short shifter how to?
- Tein EDFC for Del Sol
- d16y5 - OBDII to OBDI
- 99-00 SI spring rate vs: 00 EX
- what lip is on katman's car? (eg hatch)
- Can anyone please run a carfax for me !
- Good Websites for buying CarParts cheap.. cold air, cams..etc
- throttle cable
- d16a1 (p29) pistons into a d15b?
- 1997 Civic HX?
- Best Site or Place with best prices to buy an d16 Vtec?
- charlotte, NC peeps!! whats a good welding shop?!!
- power steering crank pulley
- b16 in a 96 ex with a gsr ecu?
- k20 & k24 complete change over?
- Search done: now the question - EK master cyl Civic Type R
- Integra Alternator on B16A2
- Best place to get V-AFC Tuned in Central PA
- oem 96-98 fog instal help
- DC 4-1 header
- Having trouble with OBD1 Gsr
- Gauge Cluster Question
- how do you drop the engine through bottom of car?
- EK9 Cams in ITR ,ITR IN to Exhaust Side
- What are "PR" codes?
- Just got a banging deal on my new GSR :-)
- Location of block vin number
- Pure s3x
- Please HELP !!!!!!!!!!
- STOLEN CIVIC IN CHICAGO
- oversteer
- I need an oem honda part number
- WTH!! My new 1/4 time!! So disappointing!! 8(
- Too low for headlights?
- Which flows the best?
- .:HELP:.window fitment DC to EG
- Car worth $9500?
- Si Cluster in DX ???
- suspension torque specs
- brake rotor difference? delsol vtec vs SI
- Need LOTS of Advice on What I Should Do NEXT... 99 LS POWERED CIVIC ...
- AEM v2 fitment? EG hatch
- Brake and Tranny problems, help please
- roll up to all power
- ACT prolite or streetlite flywheel??????????
- Thinking about Parting mine out !!!
- Where to find Arospeed wheels?
- fan isn't coming on....
- first gear problem
- how much power am i losing using my origanal d16 ecu w/ b16 swap?
- IAT sensor code P0113 (High Voltage Input)
- sol exhaust question...
- what cai do I buy?
- turbo kit from vecco.com?
- DIY cold/ram air setups on EK's...i want too see what's out there..
- engine and suspension swap
- Vtec Hits and car turns off
- just put test pipe on yesterday!!!
- [FAQ] DIY: How to convert JDM intake manifold to USDM specs for smog ref.
- sohc
- What Engine Comes In A 92 Civic Dx?
- ecu for 98 ex w/ b16
- when can i post
- Are there REALLY benefits of putting Integra (ls) front brakes/ suspension on my 93 Ex coupe?
- Where can i get a black backseast with red stitching ( ITR) For my 93 Coupe?
- Tenzo Rally Seats?
- my del sol
- Tips painting lips?
- parting out 92 DX HB - what to keep?
- r there any good shops in nj
- is this supposed to happen when you turn the a/c on?
- Any coupe rolling on Rota Slipstream?
- Sunroof Question
- b18b or b20 head ?
- Throwing CEL 5, and 14.. searched.
- y wont my tranny go into first?
- 95 CIVIC question...
- What octane gas do you run?
- CLUTCH ALIGNMENT BY HAND
- SWAPPING MOTOR: what is everything i need to make the swap work?
- EK trim differences?
- smoke out of exhaust
- SHAWN HILLIERS SICK A$$ EK!!!!!!!!!!!!
- Another Auto to Manual Converison in an EK question ... (mount related)
- OmniPower
- body damage
- Complete transformation!!!! My b16 powered eg will be B20/vtec powered and RHD
- turbo
- ek tachometer question
- 95 CX Question
- Rear quarter panel extraction ?
- why am I running hot???
- Need some help, questions about a 94 CX hatch.
- Next level Mini ME- write up (Work in Progress)
- WTB- 1 wheel with tire on it-stock- 626 so cali area - hook me up guys!
- honda-tech mems help me out with a suspension question?
- Help top dead center and cam gears are off...
- just got a 92 hatch shell... what else?
- SPARK PLUG WIREs (RESISTANCE)
- integra master cylinder fit sir brake booster?!!?!?
- Hood latch cable..
- Do I have an Eg6 5 9 7 ?????
- car wont start...already searched but nothing similar...need help asap
- GOOD!!!... engine sweapping shops in northern cali
- how to paint needles in the dash??
- Crashed My Hatch :(
- does anyone have the greddy cat back on a del sol
- del sol exhaust on eg hatch
- ???what brake booster an mc to use in my civ???
- ecg o2 sim doesnt work
- Tranny Does not go into gear easy, Help
- is anybody selling any 99 civic hb parts?
- Exhaust Problem (yes i've searched)
- VAFC I harness ---> VAFC II harness
- HELP! replaced cv axle, now loud wobbling noise at 40km/h+?
- GSR Brake Swap Fitment Issues
- EG Side skirts... same across all models?
- To boost or not to boost...THAT is the question
- Turbo guys, need help, exhaust housing spraying oil
- USDM d15b (searched)
- fog lights
- Rattling thread PT2
- valves?
- Coolant leak...D16Z6
- Opinions: 96-00 with Tein SS
- Which pressure plate should i get???
- someone with k20a swap in a EK civic? Troubles?
- will '99 lude seats fit in my '01 civic?
- Cheapest place to buy a VAFC?
- any tips for removing the engine in a 95?
- is this a bad WHEEL bearing?
- question about swaping engine
- D15B7 Track Time, Should it be better suggestions
- e-manage on all motor apps???
- 94 civic ec sunroof 3 wires to fuse box power/ground and ???????//?
- Coilover/bushing noise issues
- JUST BOUGH 92 DX EG, HAVE USDM OBD2 B18C ready, quick question about the swap! (OBD1,OBD2?)PLEASE HE
- How fast is my EG?
- EK SHELLS
- DSS Axles = not recommended for 165mph.
- d16z6 Block Rebuild.. Difficult?
- 2002 honda civic sedan/coupe pillar (please reply)
- help? H&R SPORTS OR NEUSPEED SPORTS
- New Import buyer here
- Swap Help - L@@K
- EKs with Illuminas PLEASE HELP
- 1 piece headlight question...?
- Is it possible to have AC in the summertime?
- Draft:Maxspeed Coilovers.....
- Short shifter myth?
- New car and some problems
- i need to find a turbo for a 95 civic lx with d15 engine
- Sensor trouble...
- Such thing as performance exhaust with close to stock sound ?
- Just changed my rear pads...had a question.
- CVCC help!
- WHite smoke??????????
- What is this? Pictures inside..
- how long do i have 2 be a trial member?
- 96-98 head bulb replacement
- can you use K&N filter in Comptech Icebox ?
- What does "offset" of wheels refer to?
- need radiator placement help
- What the heck kind of headlights are these?????
- Perks of owning an EG?
- Side marker wiring
- spoon exhaust
- Reseting SRS light
- 92 versus 93-95 A/C compressors - What is the difference?
- Speaker Wiring
- engine removal.. quick question
- Whats the weight difference from stock 94 civic ex and the 1 peice front end?
- Might sound stupid....but somebody must know????
- Second ACCIDENT of my cars 1yr anniversary. where to get NEW BUMPER?
- Rattling at 2200 rpm. Help.
- hmm some help please....
- Painting Exhaust
- valve cover
- Where to buy B16A2 engines/blocks
- help
- hear something from the front passenger side brake....NEED HELP!
- zc altenator or 95 civic stock altenator?
- PLEASE hooking up vtec .. p08 to d15b
- Anyone have any experience with LoJack?
- 92-95 coupe door fit a 92-95 hatch
- i need some help
- Can u help me find JDM clock and climate + cluster 4 cheap..May 7th car meet was tight
- Code 73 (Random misfire Cyl. 3)
- help with code 21
- polyurethane or new stock bushings?
- How would this ride?
- welding
- Front Lower Tie Bar install HELP!!!!!!
- OEM EK9 CTR rear lip - Installation question
- Should I upgrade the exaust?
