View Full Version : Honda Civic / Del Sol (1992 - 2000)
- vtec is not working on my jdm d15b wit p28 ecu
- HELP with EK gauge temp not working.
- 96 hatch/B swap. Carefully hardwired jumper harness, now wont rev over 2.5k.
- What tells your car, that it is in Park?
- burning oil and spark plug analysis
- No start when hot. Starts good cold, drives great.
- lca & asr subrame install ?
- vtec and xtd clutch are good?
- Need help d15b
- EG Windshield
- D16Y7 sounds choppy..
- engine harness needed for fuel pump to prime?
- b-series swap into ek
- 92 hatch w/ gsr swap overheats and stalls -- need help asap.
- Problems with EG headlights????
- 92 hatch si bone stock -- Need more power!
- 2000 four door gauge cluster lights going out.
- 92 eg motor decision
- firing order for d16zc
- 98 brake disc conversion
- replacing my head gasket question about my block
- Bad rings
- JDM DC5 ITR steering wheel into 5th gen...
- CEL turns on when I smash
- Overheating issues with a turbo build that still has A/C and PS
- Where do these hoses go? Gurus come this way PCV OIL COOLER TB
- D16Z6 TB on a D15b7 engine
- 99-00 Civic, Location of EVAP Bypass Solenoid
- Vtec Solenoid and Green Sensor
- EXTREMELY FRUSTRATED! NO INFO ON WEB! HELP PLEASE!
- how much do 2000 civic si seats go for now?
- o2 sensor
- LSVTEC dizzy oil leak HELP
- I need a write up on a b series (b18c) swap into a 98 civic ex (series)
- 1994-1995 integra harness in 1992-95 Civic?
- H&R race springs
- HELP!! d16y8 in a 1995 Del Sol running crappy throwing codes....
- idle problems after flooring...
- H22A EK hatch.
- Oem Civic struts squeaking like hell. Advice? lol
- How do you wire the VTEC on a B16A?
- Loosing coolant, no leaks?
- 94 del sol 3rd brake light clip - how to remove
- Need help with fluttering (b16)
- Nitrous guys GET IN HERE --dry shot on b16
- loud screeching noise!!
- Civic wont start...
- HONDA-TECH HELPPPPP!!!!!!!!!!!!!!!!!!
- What harness on the em1 has secondary o2 sensor??
- question on pin outs
- 98 ek hatch brake upgrade
- Radiator Leaking
- 98 b series swapped civic with over heating coolant
- 94 Civic EX Trans leak?
- 99 Civic sedan -- Power door lock help
- Teal to Reventon-Metalic
- Repair advice
- lowering problems
- How do i raise suspension?
- Helping friend with Mini-me swap... will this ECU work?
- urgent wheel bearing help!!
- Skunk2 throttle body
- strangest clutch noise.. push in clutch, terrible noise, speedometer drops to 0??
- idle adjustment screw question
- parking and headlight problems?
- 97 Civic DX is having power loss problems
- Any effective but cheap ways to prevent rust
- Del sol uncommon roof leak
- What kind of power should I expect out of a modded D16Y7?
- I'm interested in buying a Civic, but what trim? - needing advice
- 95 Hatch - do I mod the D16Z6 in it or swap in a B16a or B16b?
- timing belt
- '97 Civic Ex p0700 & p0715
- Crazy CRAZY fuel consumption
- Drop my 92 Civic LX?
- vtec help! vss help!
- Wrapping headliner
- b16a2 pcv? catch can?
- Another ej6 window problem :S
- D16 Turbo, GSR, Or type R? Which would you choose??
- 94 civic fender question
- Can someone explain me how what controls fuel & air
- just bought shell Now to plan build
- D16Z6 Oxygen Sensor Swap
- Window off track?
- Del Sol Hood Hinge
- oil leak
- removing installing rear EG sedan door
- Civic 92 Si Day Light problem
- EG parts Interchangeable???
- del sol to ek part fitment?
- 93 del sol ls swap - input needed on OBD2 to OBD1 conversion
- D16Y7 pinging, no codes, timing has been checked.
- Skunk2 IM d16y8 Not working out NEED advice
- 2000 Civic Si Climate Control mode selector not working
- Making a swap legal
- 93 CX w/ 99 D16Y8 Engine cuts out?
- d16 intake manifold
- Y7/Y8 Mini Me swap questions
- D16Y8 - ECU has no power
- 95 Civic LX with D16z6 Swap
- Pulling out dents?
- d16z6 head gasket help plz
- H22 - no vtec
- 2000 SI Winter Storage
- Is it a VTEC harness??? Or which harness is it???
- Eg engine choice
- Fuel injuector O-ring
- Buy which jack? 20 inches high enough for jack stands?
- Dc sport polished or ceramic header?
- 93 Civic EX 1.6L in Storage 4 Years Now Fuel Pump not Priming
- Del Sol Si. What else can I do to make more power? Want 0-60 in 3.5 seconds
- lower ball joint replacement
- a/c compressor question (98 civic)
- What would cause this starting problem?
- GSR rear sway bar needs EM1 brackets... but which bushings?
- Eg power mirrors
- Skunk 2 UCA bushing Replacement?
- Am I running rich?
- B18b from 00' Teg into 96 sol with d16y7?
- d16z6, chiipped p28, power falls off at 7000 rpm
- Another Hesitation Problem
- EK9 B-pipe n muffler into EK hatch D15b 3 stage VTEC
- 98 Honda Civic eg clutch grinding/scraping
- Carpet Dye (RIT) Review/Tips
- Real Mugen Carbon Wing?
- EG foglight options
- 00 civic si check engine light.
- 1994 civic dx zero power uphill
- Civic Factory Alarm???
- 99 Honda Civic DX Radiator Fan Switch
- obd2a motor obd2b engine harness
- >>> OBD1 B20 in my 96 EK need help rough idle <<<
- Hesitations, hard start up ext..
- connecting rob bearings?
- B18C into 2000 Civic EX EJ8 (EK)
- 2000 Interior
- Genuine Honda igniter 30130-P06-006...who makes it?
- Where does this bushing go?!
- d16z6 AC stopped working :(
- 93 del sol back wheel bearing trouble.
- My ek passenger power window is off the rail
- car blowing black smoke after hesistantly starting
- rear window to permanently stay up/shut
- seized lug nut
- Just bought a hatch...what would you guys recommend to make the exhaust less noisy?
- 99 Civic Transmission question
- D15B7 fine tuning w/ intermittent vacuum quirk
- 92-95 Civic door handles on 97 Civic?
- b20 smuttering
- Need help running wires through door for CTR MIRRORs
- 97 Civix Coupe HX: Ways to improve your MPG?
- engine wire harness questions
- Replacing compressor in 98 Civic
- Best LCA's for EG
- help problem really bad..
- Drivers side window still doesn't work, replaced regulator, motor, switch
- how does fuel tank work?
- Need part # for 93 Del Sol cluster plastic cover.
- sir ll spindles from Hmotors, which wheels bearings
- dash harness replace
- Need help!!!! Car won't start
- really bad jerking or cutting off on 98 civic no cels
- Gauge Cluster Issues.. Help!
- Parking Brake Cable?
- Identifying 15/16" Brake MC, ABS or Non ABS?
- '97 Civic EX Short Ram intake to stock. No fuel economy improvement.
- Improving Ek Hatch Power/MPGs
- help. AEM fuel rail..what is this..
- the "d' is blinking
- 95 civic/b16a swap - more idling problems....getting annoyed
- What's required? Integra GSR sway bars on EK civic
- Is a 98 Civic EX Odb2A or Odb2B need new jumperharness
- will jdm engine pass emmissions?
- unexplainable auto transmission problem
- Blower motor spitting out chunks of foam...
- what engine is in this
- 98 Civic hatch - fluctuating idle when A/C is on
- 00 DX hatch rack and pinion...p/s delete?
- my car's a *!?!*?! -- trying to get lights working in cluster
- How to Lube auto shifter cable?
- 94 civic ex wont crank - Replaced Main relay, still nothing
- Sea foam ?
- Ignition Switch for a 97 del so, where to get, ebay?
- honda EJ6 auto - Do I need to convert transmission to manual before a B16b swap?
- lsvtec build check
- Is there any way ur car can get stuck in clear flood mode?
- Misfire problem wit a 92 hatch cx
- HELP Honda-Tech - 95 civic dx has no spark or fuel
- b16b in 1995 delsol
- A few important wiring questions B18C (94-97) GSR into 99-00 civic ex
- Can't get oil pan out... rusted exhaust bolts...HELP
- jdm type r problem help please
- EJ8 infamous p0420 code...need help!
- Speedometer doesn't work
- Safe To Run Rich?
- Few B16a2 problem,please help
- missing/cut plug on a 99 ex wire harness?
- 2000 civic wiring pic under dash question?
- Tachometer bounced, car died, have solid CEL
- 96-00 - Do you know the weather strip part number?
- ignition problem need HLEP
- 96 b16a2 troubles
- CEL #9
- Ca cat bolt on dc sport exhaust.
- Del Sol Dash Removal random wire ID help?
- need help wiring vtec in my 94 civic
- E-brake locked even with handle down...
- check engine light
- Clutch noises and not functioning correctly.
- Help with a mini me swap
- Radio on/off, speedometer on/off, charge light on/off
- d16z6 with y8 head
- 95 Civic Won't Start, but NOT main relay
- Parking Brake Cable snapped??
- 2000 Civic EX Auto Transmisson problems
- Thread Pitch of a Bolt.
- remove subframe to install brake and fuel lines.
- 92 cx hatch with b18b swap and 94 ex cabin harness.wont start
- 98 EJ8 not turning on. HELP!
- 95 Civic EX - codes 3 and 22, hesitation, and misfires
- Battery/Alternator/Fuel Pump mystery
- 96-98 auto harness in 5 speed b16a2
- Can't advance ignition timing?
- Time to replace brake booster?
- New member with P0420 -- O2 sensor problem?
- HELP! 2000 honda civic sputtering when a/c turns on
- Help!
- GSR steering column in a 96-00 civic?
- 99 civic, short in the ecu? No power locks, cruise control, or dome light
- 99 Civic sedan -modified suspension with harsh ride
- 93 hatch not starting. No power to main relay/fuel pump.
- H series conversion question!
- Hesitation and sputtering after installing Y8 harness
- Manual transmission - Is engine oil best???
- Rebuilding GSR head question [Pictures]
- Replacing Rack and Pinion, who should i go with?
- b18b question
- rebuild question's
- 2000 Civic Si OEM Side Skirts?
- Performance & Power for Daily Driver 97 Civix Ex
- Random Over heating once again! HELP
- no start 2000 ex
- CRX HF front sway bar fit a del sol?
- Radiator fan not running
- how can i tune my exhaust
- Heat coming through eBrake/Armrest EJ8
- Car won't start
- 94 CIVIC EX WONT START
