View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Nardi Steering Wheel
- i juss finish a h22a swap in a ek9
- off topic and sorry but why have my Avatars are disabled
- door lock cylinder help
- complete B16a2 into 92 dx hatch
- slight grind in first gear
- cam cap oil leak
- d15z1
- hey...
- Taking Off Valve Cover....
- Does intake filter size matter?
- what is this blinking light?
- cali.. about to buy a car.. smog question
- ZC or d16z6
- honda EPC??????????????
- D16Y8 timing question...
- Doing a ZC swap on my 95 civic! I need help!!
- WTB Hood and Drivers side head light and Corner light
- kick hard vtech why?
- Question about vin number help!
- name that color!!!
- how much eg 4door weighs
- most popular..
- my hood cable snaped... how can i open it from behind the grill?
- chipped p28....
- I have a confession to make..
- OEM CF hood. help!!
- 99 - 00 ek convrsion question? gap between fender and headlight
- eg low fuel light
- 10^4
- cel code 6 water temperature sensor?? searched
- bypass valve cut on CAI???
- NEED HELP: asap.. fuel pump!!!
- EJ.Ek.....and so on
- EG CLOCK DIMMER
- sir ek rear seats
- I got a ZC motor question!please help!!
- Opinion on purchase of 97 civic w/ SIR swap. Quick responses needed B4 its 2 late!
- Gauge Cluster Problem
- Code 0505
- help please!
- Newb question about the JDM B16
- B16 Transmission from hmotorsonline.com
- psi?
- having problems changing upper plug seals on d16z6
- can you use a heater core from a 99 civic in a 98 civic?????
- Reasons why you consider upgrading your final drive.
- My friends is asking if the ZC block as an oil jet
- my car shuts off when I remove the keys....WHY?
- What is up with my suspension/front end?
- Question about cilovers
- How much did you pay for your swap?? (just labor cost?)
- throttle body sizing question
- CEL CODEs 36 and 23 HELP !!!?
- A canceled cilinder
- help whit the clima
- 97 ek with d15b dual vtec sluggish >>!!!HELP!!!<<<
- cel fuel supply system
- motors smoking and has near perfect compression PLEASE HELP!!!
- LSD question
- knock, chatter, or rattle?
- Doubled screen in jdm center consul??
- easiest way to replace cam seal (B18c1 motor)
- 99-00 Fog Lights?
- GUYS I need help coolant going into oil.....
- idle high
- need quick answer. will it fit rear 90-93 integra strut bar on 92-95 civic -searched-
- Fair price for a 94 CX?
- Cams & Ign system for my h22
- codes
- B16 to LS ?
- check engine light
- My turn signal lights turn on when I press my brakes?
- IAB help on swap
- y8 head on y7
- When using RC 440's on a D series motor, do I need O rings on the intake manifold side?
- cleaning my headlights.....
- Design Review. Please give me your input!!
- ek 4 door seat cover??
- What car do I say for?!
- 02 rsx steering wheel on a 00si
- 95 civic auto trans issue!
- blown headgasket?
- New with a '99 EX
- Some unanswered questions
- Help With obd2-1 pinouts
- Brake boost?
- how do you post pictures on here
- ek interior question.
- GSR TB
- D Series Axle replacement
- civic transmission
- Odometer/Tripodometer just stopped working?
- Heater mods?
- Scratching Sound @ 3k rpms in gears 1-3
- shift link problem need help please
- What happened to the ek pic thread.
- Brake problem please help
- **Help Question JDM ITR 5 Lug Conversion on 95 civic si**
- where to set my adjustable cam gears on ls vtec for good results
- 95-01 JDM itr front nose to a 96-00 ek what u guys & girls think?
- 99 Civic Si timing belt and o2 sensor
- Can Suspension Techniques EK rear sway work with ASR subframe
- Poor Mans Type R Set-Up
- Question on map sensor
- RHD EK
- OEM Interior pieces?
- b16 motor mounts
- Removing front bezel
- Knocking noise
- How to depin mirror harness/plug
- auto tranny question
- Clean Engine Bay
- Smoked vision corners? Possible fading?
- Fixing up a Honda Civic 1997 Coupe (Pics)
- check out my eg and tell me wut ya think
- Idle/ vibration issues
- Front lca WILL NOT come off!!
- rear motor mount problem
- tokico & h&r 'race' bouncing
- CAI ouestion?
- 98 to 2000 front end conversion
- is this a good buy itr japan motor with no tranny details inside going to see it tomorrow
- k20 turbo civic...
- Do EG lowering springs fit an EK?
- Anyone have a good write up / DIY for fuel pump cut off switch?
- need help on lights.
- caliber mounting bracket question
- just bought a 92 eg hatch, need some help
- ZC DOHC swap into my 1993 Civic DX Sedan (yes, I searched)
- Crankshaft pulley fell off
- F2D?
- Storing Car for winter is this a good plan?
- 4-2-1 header vs. 4-1 header
- 96-00 civic Window derail
- Gas Pedal problem too much travel
- b18c1 into 95 civic ex
- limp mode, not going into reverse, tons of problems
- vtec not pulling very strong
- j's racing lip for civic (96-98)
- LS/Vtec coolant problem...
- Eg6 gauge cluster
- need some answers
- stock cam specs needed
- here is a strange one.... fuel pump not coming on EG
- Spark Plugs
- v-tec controller ?
- In need of bolt (toe arm adjustment bolt)
- CATALYTIC CONVERTER 02 SENSOR
- Weird Question: What is the stock exhaust piping on an EK coupe made of?
- Front strut bar
- should I get oem honda spark plugs or some other brands?
- Anyone know part number for the Header COLLECTOR GASKET/DONUT for Advance ?
- sticky throttle body
- searched this****** hesatation????
- Rear breaks change on 97 civic lx
- do i actually NEED an oxygen sensor?
- Exhaust question
- golden eagle intake manifold
- NEED HELP ASAP!!! b16 obd2, will b16obd1 longblock work?!?!
- HELP MY CAR WONT START!
- Oil temperature needle issue
- can someone help with this problem??? ex to si
- Chipped ECU or not?
- Need Help With Some Missing Nuts and Bolts.
- h22 civic with skunk2 intake mani heeelllllllllppppppp
- Now my car smokes at idle and is burning oil bad. HELP! 94 eg hatch gsr with bolt ons!
- h23 parts
- change ECU
- decked head for d16y8
- how to install power windows and locks
- break light/horn fuse trouble...help!!!
- CLUTCH PEDAL WIRES
- 5w-40?? best oil for daily driven turbo hondas?
- Does my LSD sound normal? (video inside)
- Does my car have keyless entry?
- auto to manual need help
- New to Honda Tuning - Taking Suggestions
- so i changed my own oil for the first time
- ecu reset everything?
- '95 Civic Del Sol - Help me pick the right manual please.
- Remote Car Starter not working
- 98 civic dx with B16a *help wiring vtec*
- need a few things for D16z6 motor
- 95 civic coupe dx (stock brakes) - Brake problem!
- b16a to b20
- ek problem
- 94 Del sol door question
- 99 coupe agx w/ tein s tech or h&r lowering springs???
- car wont turn over -92 civic lx
- Airbag removal ??
- Axel question ???
- Difference between auto harness and manual harness?
- Speed Limiter?
- 94 si hatch, what's it worth?
- Rebuild kit
- Name This Part, and Why it Could be a Problem
- power steering vs no power steering?
- which motor responds better to modification
- clutch opinions
- question on drag springs
- wire tuck brake light on
- smog test sucks
- Need Parts Advice
- D15b Vtec-e
- civic 92-95 foglights not working!!
- Searched: 96-00 Cupholder complaint
- Exhaust Setup
- REAL Quick: Calling all Apexi world sport Exhaust owners?????
- question regarding camber.
- 94 civic ex rear disc questions
- Whats the difference between a 1996-2000 Honda Civic Hatchback CX and DX?
- After tune problem...help
- Motor oil break down
- 97 civic Ex Codes
- 99-00 EX Interior Color Codes
- quick question about window
- RSX Steering Wheel into EG Hachback?
- del sol with civic front end
- Lights Flickerin' and Stereo Cutting Out
- skunk2 throttble body?
- high mileage del sol
- what are the functions of these 2 electrical parts!!!!
- D series INFO needed
- my car is off to the body shop
- Snow rack on eg help!!
- anyone selling
- 92 CX engine harness. *HELP!*
- how do i check motor compression if motor if out of the car?
- Delsol front end conversion EG
- exhaust
- 97 hx with obd1 jdm d15b swap why does it not run and bog out and not make enough power??
- has anyone heard of split second?
- Difference between B16 transmissons?
- Cold Air intake for a d15b 3 stage?
- how to get more power out of me gsr
- will alcohol injection work
- lsd problems
- looking for info on replacing rad suport
- Intake Manifold replacement...
- Running a P75 ls ecu on a d16y7??
- Cyl. No. 3 Running Rich.
- DISTRIBUTOR PROBLEM hELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- trans question
- *STOLEN* in HIckory, NC
- Individual cylinder air/fuel mixture
- Intake hodler bolt
- first serious build and need a lil guidance
- Alignment / Lower Ball Joint Issues
- Motor Knock Please Help
