View Full Version : Honda Civic / Del Sol (1992 - 2000)
- sunroof need loob?
- Anyone Know where I can get a set of lock relays for my 00 Civic?
- 98 Civic DX Blower Problem
- 2 different styles of EK wings?
- wheel specs for a 92' civic && gauge cluster question
- easy question
- can someone please tell me how to become a regular user???
- Need Help ASAP
- Car trouble, help please
- going to start doing ecu mods. whatcha think
- hello what are the best b16a internel upgrade...??? Cams, valves, retainer, springs..?
- couple of questions...help me out HT members
- 95 civic ex coupe tire pressure
- 92 civic si cluster issue
- backfire
- Advice (Clutch Master/Slave Cylinders, CV Boot Dry Rotting, Wheel Cylinder)
- difference between headlights?
- without the ac condensor, does an integra radiator fit in a ek?
- weight reduction question
- Power steering or no power steering?
- Gears out of place?? [kinda long but weird]
- stripping my car
- sunroof help!!!!
- engine misses off-idle
- Power window/locks conversion kit?
- Need Help Choosing Pistons for LS/VTEC!!!!!!
- manual or auto ?
- Backup ECU fuse keeps burning - Help!
- CHIPPED ECU QUESTION
- need shiftlinkage help
- how to identify a oem sunroof visor from 96-00
- Horn removal and replacement...
- need help with diy ctr headlights. silicone wont dry :S
- NRG steering help momo wheel
- Looking to see how a Thermal exhaust sounds on all motor b series
- aem pulley question
- 225/50r15 bfgoodrich drag radials, 40mm offset 92 hatch.. will they scrape bad?
- cam question
- s2k rpm guage in a 92 si
- Throttle cable too short
- How-To: Fix Aftermarket 96-98 Type R Rear Lip Fitment (Sedans & Coupes)
- 98 civic ex vtec
- Skunk2 v. Tein v. H&R
- Has anyone sold a car to carmax?
- Help! Code 61 - primary oxygen sensor
- How much for 99-00 Civic Si power steering bracket?
- About buying a car without A/C or Power Steering
- 92-95 Honda shell help!!
- dowel pins
- SIDE MOLDINGS
- Need a quick upper control arm answer
- where is my ecu?
- lost all my coolant, now engine wont stay running
- Hazard Switch.
- HELP... lower fuse box for EG
- What clutch will i need to replace?
- O2 sensor question
- Planning on to Ref a Motor
- will a 94 ex exhaust fit on a 94 dx?
- d15 alternator.can i just transfer it to my new b20
- What do you think?
- 96-98 and 99-00 hood question
- vtec?
- Spoon shift knob question
- Hasport mounts....can I remove my transmission mount?
- vss help
- aftermarket foglight aiming question
- headstud question
- Need swap info
- Engine conversion help (Integra Type r)
- Over wattage H4 bulbs? Feedback?
- overheating h22 eg
- 99 Rear Disk Brakes
- PCS Valve
- bad clutch?
- Can I rewire my DRL (City Lights) to use parking lights instead?
- pulley?
- D15 power question
- Crank Position Sensor, Crank Fluctuator Sensor
- Overheating with bubbling/splashing rad. fluid
- b16 header torque sequence
- Ground control coilovers, what else?
- apex n1 rear section
- Tein springs or skunk 2
- will gsr 94-00 seats bolt up in an ek? how well do the fit?
- wheel hub spindle?
- help with the vss
- Sway bar bushings?
- naming a body part on a car 97 civic coupe
- CTR red carpet.
- My gauges
- EG/EJ Speedo cluster questions........
- 92-95 honda civic wire tuck?
- ls\vtec internals
- need a little help
- engine dress up
- anyone know what this is?
- couple questions here...
- coilovers or springs?
- 95 gauge question
- 99 si dash in a 96
- Need some input on a solid Autox Setup
- Power Windows/Lock into 92 SI
- Bypassing knock sensor
- ls/vtec swap, having problems, what engine harness and ecu to use
- help!!!! motor hesitates....
- 92 honda civic throwing code 21
- gas milage goin to shit!?!? help
- NEED help with ignition replacement in eg/dc
- Window issue, I dont think its off the track
- 93 VX Hatch, interior dash lights not working..?
- 96-98 climate fit 99-00 civic?
- hi all
- help on front rotors
- fed up
- What do you think i can get out of it???
- FRONT END DAMAGE
- civic brake question
- 99 civic si cluster into a eg coupe
- worth it?
- Car wont start! CEL 9 after obd1 conversion.
- Installing Ener. Sus. Ball jont boot sets.
- do i have a mechanical vss or electrical?
- Urgent!!! Please HELP on swap harness!!
- rear speakers install how to..
- Lowering Dilemma
- front sway bar on a 99 civic ex
- QUICK POWER STEERING QUESTION...
- rotor retaining screws
- lower engine mount nut
- Anyone want to help me with Vacuum lines from wg, bov, boost controller ect?
- y21
- hey what up. Just got a 2000 si
- PROBLEM WITH A B18 GSR SWAP INTO MY EG6 HELP!!!!
- turbo question
- Upgrades on a D16Y
- Low Idle Problem 95 Civic Vx
- starter issue, doesnt crank
- quick question on Ek rear discs
- the noobiest of the noobs even though ive been on this site for a while
- what kinda pistons should i get?
- avid mounts ???
- Engine oil question.
- Quarter Window Trim
- I found a good online supplier for trim and door clips
- 95 Civic EX CEL analysis troubleshooting help
- Idling at 2500rpm's constantly!!!! It's a jdm zc
- Clicking or light clunk sound from front end.
- CEL code help
- Quick 4 door to hatch question
- The infamous 3rd gear grind and its fix
- engine light: intake air temperature sensor
- o2 censor cel?
- egr valve/ bad gas mileage
- Lots of Play in my Shifter
- .....NEED HELP.....
- *** hondata launch control question ***
- Wiper Switch 1998 HX
- will rear window from ej6 fit in ej1?
- 65 dollars to spend whheee
- car doesnt start please help
- motor been sitting in garage questions...
- new clutch... any ideas wat clutch i need wit turbo?
- Rear disc on My 96 Civic Coupe?
- Headlight-on warning chimes
- EK9 replica wheels?
- axel race stuck in trans, rest of axel removed any tips?
- HID idea
- Transmission swap
- Stock Alarm Problem
- driveaxle removal/installation
- lsvtec???
- Question about gauge lights..
- ((((What are some of the best mods for a civic???))))
- 1992 Civic SI
- b series transmissions?
- if i swap an h22
- was the eg si ever offered in teal green?
- Best budget brake upgrade for 99 Si
- need your opinion
- engine light help
- Suspension on my 95 hatch.
- DTM Style Mirrors ????
- VTEC Soleniod GAsket
- Window Tint.
- looking for a shop to build a B16
- D series with Mishimoto Radiators
- Front brake lines and rotor upgrade for a stock set up on my 99 hatch
- S-AFC?
- Performance difference going from stock EJ6 breaks to Type-R 5bolt conversion.
- newb question
- Thortle cable help
- integ carpet in EG hatch...
- My D16Y8 engine build thread...LOTS OF PICS
- issue with PasswordJDM PC Intake
- VISION Wires
- prelude f22 block question
- driving my civic from mo to cali
- P2T Ecu Question
- Need a how to on headlight blackout
- hid question
- DC Sports 4-1 VS ITR 4-1 Header
- Monster tach
- car starting problem
- JDM Honda F23A SOHC Vtec Accord 98+
- can someone check a vin for me plz!!!!!
- dizzy is out???
- EG6 FOR SALE FROM WEST COAST TO EAST COAST
- b17 swap in 94 dx hatch no spark no fire
- 5 modifications you should NEVER do to your car!
- Somebody doesn't like Civics
- p05 civic cx ecu and injectors...
- b16 turbo and tranny question
- 93 civic si questions
- general question
- Brake and blinker light issue.
- i thought this was funny..so i decided to share
- rewired alarm, car wont start
- my d15b is acting like a girl
- Stripped threads Need Help...
- wiring a nock sensor to a B series?
- OEM Injector Size in B16?
- Distributor questions...
- motor swap question
- coilovers
- b18b
- Spotting Real From Replicas?
- questions about rhd conversion
- Speakers Information! What SPeakers to get
- quick exhaust question
- sohc vtec obd II engine/ tranny/ ecu/ axles/ shift linkage (d16y8)
- yo hook it up with some si pics i need som insperation
- Car wants to stall when coming to a stop or after revving
- whats a good compression for a gsr motor???
- Halo Lights, help.....
- how does your "NooB" status go away?
- what mods are need for GSR back seats to fit CIVIC? (00 GSR to 99 CIVIC)
- whats up
- civic white box????
- 1994 ex tranny
- b16 turbo/engine questions.. bore?
- what do i need for an engine swap (other than an engine)
- Any experience with Passwordjdm fog lights?????
- Need help on choosing coilovers 99 civic
- Colored tint?
- tranny wont go into reverse?help!!!
- Rear SI caliper mount bolts
- where do u get the cartoon car in ur sig's?
- 1 inch integra type r master cylinder and Civic DX brake booster
- CIVIC SI REBUILD MOTOR QUESTION
