View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 2000 civic si help
- D16Y7 intake manifold swap!!!
- Is this del sol nice?
- Z6 Head vs Y8 Head
- questions regarding ej8 rear back seats.
- 1995 Civic Engine turns off
- new interior for an ek
- jdm headlights lights bulbs? where could i buy some?
- is there a knock sensor that is M8 x 1.25 thread that will work?
- 1999 Civic Si Problem
- Grille..
- 99 fogs and intercooler piping????
- Help on Finding EG6 part!!!
- i need help!!!
- swaping a gsr into 96 ek
- climate control lights????
- just bought a 4 door and back door wont open.
- 97 civic ex front bumper
- Car sometimes dies a sec after starting
- 97 Civic Ex D16Y8. ticking.tapping
- what cams are these? I think I got screwed.
- brake light
- Tokico Illumina question
- ls knuckles and brakes... which axles question
- Turn signal issues...
- sunroof help
- B Series Axle Length
- (Del Sol)Honda tech support need help! read Tranny Problem
- does anybody know where i can buy an D to B series A/C bracket
- help with accell ignition
- Ignition/fuel problems
- Civic ECU programming
- HELP ME PLEASE!!!!!
- rebuilding hydro b16 tran w/ oem parts question
- i need your help
- HELP THE HONDAS
- looking for a n honest shop in 323 626 562
- anyone in utah
- Overheating question...thermostat?
- how to tune my 1.3 civic
- 93 civic ex with LS motor
- Is there a website that gives tips on wire-tucking a 2000 Civic coupe?
- recaro type r seat question
- trans prob.
- whats wrong, cylinders compression is off, rings bad?
- What is your favorite gpt site?
- Help with swap problem!
- problem with my 96 ek
- Oil Pressure Problem
- AC AUTOTECHNIC fuel rail fitting size needed....
- Please help me start my car. Vid inside...
- Identifying a B series Transmission
- HELP! need exhaust!
- Amber buls in cluster Q
- 92-95 Civic headlights
- Throwing a random CEL..
- Does this sound like a bad distributor bearing or maybe rotor?
- Fuel pump not getting power...Need help
- so I'm goin sohc turbo, new questions :)
- springs
- Hondata Crank Sensor ??????'s
- how do I
- Getting really bad wheel hop in 2nd and 3rd..
- Remote start activation question.
- will a full itr catback exhaust fit?
- b18c5
- How to fix the door lock mechanism when the door will not open?
- Crazy gas tank
- rims
- Electrical Problem?? Car won't start!
- my ex is having a little trouble starting?
- Used turbo on d series
- What kind of axles are these?
- 99-00 civic coupe front conversion on a 96-98 coupe
- Picking up my swap soon, had some questions to clarify that aren't clear in the FAQ's
- ex & hx
- i know this is the wrong place to post but amp for sell
- need sway bar kit fro 4drs eg
- LED Tail Light Problem
- '95 Civic DX Transmission
- Is my car sellable? have title but not fully transfered due to smog
- How to connect dimmer? EJ8
- pass door lock freezes up everytime when temp hits below
- 1996 EJ8 cooling fan not switching on, but cooling fan does work
- no spark
- Help me wit my 94 civic vtec
- 2 Questions?
- Question on Changing Piston Rings
- P28-(a00 what do these numbers mean????)
- Automantic Tran D3 170km
- 95 mpg in a civic......an interesting approach.
- Question on B-Series shift linkage
- distributor
- Single cam slam help?
- ls/vtech help
- steering wheel swap
- clutch problems
- 92 vx with swap....engine question
- Need help on ls/vtec build!
- will doing this hurt my car?
- B18 swap
- timing belt tensioning
- Turbo a singlecam thumbs up or down
- Transmission fluid on 97 civic
- 95 civic will not start
- EG Foglight Grill Cut Out
- my 97 ek i just bought...
- ***********EG-Techs********
- Mudflaps!
- Violent vibration at 4.5k, any ideas?
- for sell jdm window visors for a 4 dr
- brake question
- way to much fuel help!!!
- does anyone know where i can find a 99-00 civic coupe either black or si blue under 5k
- EG coupe seats into EK coupe?
- My N/A Exhaust Set Up
- Anyone running with stainless brake lines?
- Identify these seats
- wierd AND crucial electrical problem!!!
- license plate mounting...
- Were can i find this!!!
- Cruise control light on.
- stupid question 99'-00' civic
- Burning oil
- brake lights stay on, when brakes not engaged
- 95 civic motor swap help!
- Fuel rails
- lights dim at WOT?
- 95 civic motor swap?
- DDing with CTR Cluster.....
- ek starts fine but rpm trouble plz help if u know
- Civic swap
- 4dr trunk hinges fit 2dr?
- Phearable ECU...
- just got car back from builder
- h22a swap time.....few questions!!!
- d16z6 compression
- Brake system Flush
- small problem
- Power steering problem
- h22 swap or b18b turbo?
- TRANNY PROBLEM
- manual to power options how hard
- 1993 Civic EX D16Z6 won't start after adding gas
- coilover question?
- shift play
- P1259????
- del sol exhaust help and compatibility
- Bumper antenna
- HELP: WIRING A OBD2 B16A2 INTO A OBD1 95 CIVIC SI HATCH WITH A GSR OBD1 WIRING HARNESS
- jumper harness question???CECU-002
- mixed valves
- how do i add pic
- why is my o2 sensor wire this long?
- 99 civic dx Brake swap.... searched
- ECU options 94 del sol d16z6
- K24, K20,H22 ?
- stanley corners
- wat tranny do i have????????
- my corners taillights and gauges wont turn on.....HELPO!!!!!! on eg with an LS
- where dose everyone get the hole plugs for thier motor bays after the tuck
- Damm Window!
- ******Where are the Honda Techs*******
- honda center caps
- Proper way to center aftermarket exhaust.
- Ls Motor Swap
- New Member From Ma
- Headgasket Swap, Car Won't Start HELP
- What CPU to get for a DOHC ZC?
- H22 swap
- Can anyone get me a radio code??
- Windage Tray ? ?
- i hate when people steal others cars
- Fuel Pressure Question
- trottle body cleaning
- eg trans swap quistion
- picture request for eg fog light installation
- What Dizzy do I use?
- autometer 5 inch tach goes crazy after 6,000 rpm
- smell from new exhaust?
- Honda/Acura B and D series Compression Calculator
- del sol seats
- Prove DC header legality in California?
- what kind of wiring harness
- hondata? what makes it different than chipped ecu? odb2?
- type r intake manifold
- PLEASE HELP!!!!
- lightened flywheel vs MPH shifts
- Stripped Bolts Need Suggestions
- is there a killswitch for a 92 civic cx?
- pic request.........ek coupe with group n preferably 15"
- What colour rims?
- Dome Light Itself Broken??
- NEED A TRANNY
- Quick Question
- Alternator belt keeps flying off?
- need your opinion on new car
- eg swap/build up pics
- HELP with California SMOG check
- When i go on and off the gas in 2000 civic i feel jerking and poping noise?
- 93 civic b16 A\C?
- Axle Question.........
- can a p28 ecu with hondata be retuned if its been tuned to another car before
- help.. need.. EK TAIL LIGHT GASKET PRINTABLE TEMPLATE
- B18B with GSR tranny?
- Question!! Can I Use A D15b7 Head On A D16y7 Block??
- Attemptive theft - fixing the damage?
- Annoying leak, exhaust gurus inside!!!
- HELP ASAP!!!!!!!!!!!!!!!!
- When turning- steering problem help !!!
- Cluster Lights, Climate Control Lights work only when hitting brakes???
- *****spark plug problems!!!!!**********
- dilemma!!
- Code 43 - Please help
- Del sol ?????
- compression
- what color are the wires
- Replacing EG coupe driver glass
- swap problem please help
- car trouble
- Tranny Brace
- H&R Racing Springs
- Can i put a passenger Type R seat and convert it for my driver side ek9
- JDM civc parts where can you get them at???
- vtec engages at 4k and car wont rev to redline??? help asap
- Looking For Power
- Need help. (1999 Civic Si Coupe)
- trial user
- 205/50/R15
- "Idle" problem.
- How to take off mirrors?
- need help its not the wheel bearing
- dc struts on a ek??????????
- ITR/CTR exhaust cam waste of money?
- radiator cap not holding enough pressure... coolant bubbling out
- b16 del sol
- a/c connections
- 00 ls into a eg coupe.....
- tranny question!
- help i need a radio code?
- about how much horse do i get out of bolt ons
- plug wires??
- what kind of clutch to go with?
- integra brace on civic?
- Throwing 2 codes
- High voltage?
- are all trans the same on D series bolting up
- d15b7 rocker arm assembly?
- Amp to front speakers on 98 civic
- Stereo removal
