View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Air leaking near transmission case
- Oil light on at idle... HELP
- Car is squeaking??
- burning oil, replacing ring
- Car dies when its warmed up
- possible mini me swap, need info.
- 95 del sol stock, failed emissions high co level
- 1997 EK Hatch Speedo problems
- Motor mounts
- JDM DB8 94 - 01 ITR Integra Type R Rear Seats
- Where can I buy a D16z6 oil pan?
- D15b oil consumption,burning issues
- ZC IDENTIFICATION! [HELP]
- 93 honda civic hatch - brake taillight problem
- 97 civic rear deck rattling need
- OBD1 Conversion...Service connector not working!
- motor shaking!!! help me haha
- Help me find a big bolt on my 94 that fell off/snapped..
- Iratic idle and bad mpg
- Cold air intake hardware?
- TDC sensor, Help me find a part?
- Steering Wheel Pull
- Will a steering wheel and air bag from a 2001-2003 Civic fit a 1996-1998 model?
- d16y8 on a 1994 dx hatch, which fuel filter/pump should i buy?
- D16A into my 1996 Civic EX. what do i need?
- 92 DX hatch idle surge
- Tips for installing rear drums plz having trouble~
- Excessive Brake pedal travel 94 civic DX
- 2 door vs 4 door hood
- Civic just chugs under full throttle And swallows gas.
- 92 Honda Civic seat belt
- E-brake problem 97 civic
- Password Jdm Intake doesnt fit with eldebrock manifold?????
- HELP Motor wont start
- Radiator Fan Inconsistently Turns On
- EG Spring to EK
- 92-95 Manual to automatic harness plug and play
- 98CivicDX , Friend Milled Head, Now telling Plugs are Crossthreaded
- 94 Civic hatch B18C1
- electricity passenger door civic EJ6 (coupe '96)
- P/W switch attach to Door panel Help.
- For the guru's... OIL light & Water Pump question...
- 1999 Honda Ballade (Civic) Camshaft Bearing
- 93 del sol - obd2 ls swap gone bad
- 95 Del Sol: Performance and other problems after installation of new exhaust system
- Engine tapping noise -- new head =(
- 98 civic ex axle...which one?
- Brake disk screw can't be removed
- LED SMD Wholesale
- 96-98 Rear windshield size?
- Squeaking Sound.
- cylinder key replacement..ej1 coup
- 99 Civic HX M/T DTC code P1165 with aftermarket mods and unstable idle
- What OEM Muffler bolts onto a stock 98 EJ8?
- jdm itr or jdm gsr indentification
- need part numbers, jdm civic sir badges/decal/sticker
- z6 trans in a ek? will it work
- Hydro to cable conversion/throttle cable question 98 b16
- 99 civic radio swap oem
- DA knuckles/spindles on ek?
- Drop 6-speed tranny into 94 del sol???
- IACV plug wire colors on 96 GSR Harness?
- t belt questions
- D16Y8 & Fuel Experts...
- 99 Civic LX Door Mechanism
- Oil dripping from D16z6 tranny
- B16A2 Injector problem
- 00 civic studder/hesitation
- ek sedan. battery light on/dim headlight/speedo doesn't work
- o2 sensor not working CA version vx with LS swap help.
- 96 hatch overheating
- 92 Civic AC problem (Condensor fan related)
- AEBS intake...IACV acts up when hot?
- 1997 EX Coupe wont start
- 95 Civic. Removing Oil from Cooling System and Idle Issues. Reward!
- Help with my Rear disc brake swap
- 94 EX CV Boot clicking - How long can I drive it for?
- B16 Tranny Mount Question
- Can a power moon roof switch be repaired?
- 93 Civic DX won't start
- z6 mated to zc block
- white tip spark plugs... normal?
- obd1 ecu wiring
- Car Overheating (D16z6)
- having trouble starting 92 civic dx
- Fabric softener for car seat?
- Whats the difference between a HADSYS and a SANDEN a/c compressor
- 1993 civic dash lights won't turn off when Back Up fuse is installed
- honda del sol ac unit button question
- Rearview mirror keeps moving down.
- check engine light code 6 - engine bogs and misfires
- 1996 civic manual transmission fluid?
- One high beam on the other a low beam 98 civic
- 92 civic w/ d16z6 wont start-dizzy problem?
- Bad third gear syncro
- Are the AC lines connected to the evaporator inside or outside the firewall?
- crank pulley removal.. dumb question
- strut spring question
- 2000 civic si not starting
- h22 into EK 99-00 helppppp PLEASEE with axles
- airbox for a type R swap
- Took a Dumb?
- p72 a/c commpressor work on 98 ek?
- Coupe owners with run channel trunk leaks
- p2p ecu on jdm d15b 3-stage to pass emissions testing, CEL
- Speedometer problems 92 civic hatchback
- Rear Sway Bar Question 2000 Civic Si
- Need help Mini-me o2 wiring
- Transmission doesn't seem to engage??
- how to remove mirror glass of ctr power folding mirrors?
- folding mirrors or just power?
- 96 civic lx question!
- weird itr swap in eg problem
- zex dry kit install
- Failed smog on the civic
- a/c wont stay blowing cold, please help!
- Stripped ALLEN bolt in GSR head pics.. ANY IDEAS?
- over heating issue?!
- Oct 1 parts give away competition - must e-mail me reason you deserve a part
- Should I clean VTEC solenoid and coat the gasket with oil?
- 99 Civic Wont Start, Help!
- Will acura rsx seats bolt up in my del sol?
- Brake Upgade to 03 Type S
- cars idle is high
- s200 cluster in a ek question
- D15B3 Carb vacuum line question
- what does hellaflush or flush mean?
- urrggh another Idle surge problem. gsr b18c1 in ek
- Help! Check engine codes PO135, And PO141 wont go away.
- 96-00 grounding locations
- jdm gsr swap, low idle, code 14
- need a pic of a interior peice 94 civic coupe
- Engine swap post, but.. AUTO!
- my 93 civic hatch with 95 b18b wont start....plz help
- Ek hatch brake system problem
- need a 96 civic ex underdash fuse panel image
- 2000 civic dies, turns over but wont start
- B series interchangeability..specifically cooling system
- Civic D16y8 Piston Issue
- LS-Vtec swap issues.
- swapped auto cluster to 5 spd. EX cluster and tach doesn't work,no tach signal??
- Trunk Leak Problem
- I need help... d16z6.... again...
- Can you cap the coolant line that runs from the im to the iacv
- s1 transmission into ek civic
- 94 civic with AUTO trans - Any way to change what RPM the trans shifts at?
- coolant hose question pics
- axle or tranny problem?! em1
- Help with door lock
- 1995 civic dx dash question
- Low idle, smell of fuel, bad when mpgs.
- Exhaust on b16a2 in 98 civic
- Honda Civic 200 Battery Overheating Help please.
- Civic rear hatch and dome light.
- interesting window problem (94 del sol 1.5L)
- z6 swap starts but wont stay on, HELP!
- parts direct from japan?
- TDC sensor
- Power locks work only on driver side.
- 94 civic cx no fuel no spark help please
- 93 civic DX d15B7 issues
- 99 si trade question
- The correct throttle cable bracket for a skunk2 manifold on b18c1 in a EM1
- How to tell whats in the head?
- 99-00 Civic SI EM1 Electrical problem
- What center caps are on these HX's?
- What exactly is a HX?
- 97 Civic LX has bogging problems - i cant figure it out!
- 1997 plastic piece "bushing" on the power steering hose bracket
- Remove headliner 98 Civic LX?
- where does this plug go?
- Oh no you have my license plate number!
- car dying while coasting in neutral
- Need help with power locks 93 EX COupe
- Alarm or Kill Switch?
- Torque specs '00 Civic P2A PWR Steering Pump housing bolts
- Polybushes for JDM rear LCA's???
- Noise when a/c is off - not when on
- Engine Hard knock/Shot sound when giving gas
- car wont start/crank. faulty starter cut?
- 99 Civic Lx, CEL code 54, which CKF sensor?
- white smoke while riden..
- Windshield interchangeability question
- is this the horn button wire??
- Civic cuts out on highway
- 99 civic ex auto door locks and mirrors problem
- civic 92-95 cluster. White face w/MPH but not the USDM or UKDM black face version
- 93 Civic EX with Wiring Issues HELPPPP :-( PICS INSIDE
- Issues with Rywire Harness in EM1 *please help*
- idle problem on a 94 del sol with b16a3
- Need door pin out info
- d16y8 idle issue
- A/C pipe connections
- easiest way to replace an axle seal
- Need bolt torques for installing new idler pulley
- Y5 perforamance...need input
- purple power degreaser bleached the block..
- Barely any brakes after rear disc swap
- Sensors Question
- EG climate control knobs removable?
- my civic suddenly turns off while driving?
- n00000b mount help? pretty please?
- EF9 seats into EG6 chassis
- Removing rear view mirror
- D Series - where do i hook a chain to pull the motor out?
- Ignition coil keeps failing, help needed!!
- Code 14 D16Y8/ High Idle/ Jerking Motor
- mini-me wont build boost
- help with iacv- its making a weird screaming noise after i cleaned it?
- Stock Cat on HKS Hi-Power?
- 2000 civic Auto trans not working
- eg exhaust fitment
- EJ stalled and now won't start
- Rim fitting question 2000 si
- B18A TIMING BELT COVERS ON A B16??
- couple weird problems on my 98 EX.
- Is this a good price for a auto tranny?
- Temp gauge sender V. TW sensor
- new cams for vtece
- 00 ex performance parts to my 00 si?
- 93 cx d15b2 swap now stock tranny won't work
- Can someone help me identify this sensor
- Rear End Schematics 97 honda civic
- 92 Civic only starts with starting fluid
- CEL ???
- Wheels pushed back into fender - 99 si
- Wiring/Fuse Questions
- My car won't start after it rains
- Dash light fuse keeps blowing.
- which grade of gas to use on 230xxx miles d15b7 motor
- Throttle cable snapped / motor overheating AGAIN
- b7/y7 Mini Me, What Cam Gear?
- d16z6 in ek idles fine but blows white smoke when driving
- P0301, P0302, P1300 1996 D16Y8 220k Miles, How have you fixed it?
- complete GSR into 1996 coupe ex. What do i need?
- Del Sol Passenger Window Problem
- IACV hose question..
- Shift Linkage + Bitch Pin
- Cel14 IACV & have searched help possible?
- 95 Civic LX won't start - cylinders flooding with gas
- Honda Del Sol fog light placement
- automatic transmission mount rubbing frame/bracket
- 96 hx - need input on what engine to swap in
- My first stock rebuild on EK4 B16A2 after broken timing belt (pics)
- d15b7 oil burning issue.
- Will the struts and springs from a DA work on my 92 civic cx?
- Help With gsr swap launch point?
- HELP!!!
- HELP: broken bolt connecting upper control arm to hub assembly
- Need some help making my 99 Civic SI faster
