View Full Version : Honda Civic / Del Sol (1992 - 2000)
- SI gauge cluster into a 95' civic? will it Fit?
- Car always starts on second turn, why?
- What are the consequenses?
- 95 auto civic swap
- Headlight Woes
- Crashed my civic
- JDM-Styled Custom Face Gages (56k sure!)
- seat question
- MPG?
- *NEED THIS* 2000 honda civic cut stereo dash harness wiring diagram/schematic
- h22 timing
- 93 delsol with y7, question on mini me
- Apexi WS owners. I gotta a question.
- do you think this is a good deal?
- Dilemma in clutches. Need assistance!!
- Fog lights
- EG crushed
- Adj. Cam gear, Where am I at?
- JDM h22a -- Wheres my map sensor?
- Searched but no help
- 02 question wires.
- 95 Honda Civic.. need advice in buying
- couple questions here. need some help please
- ebay brand type R cams
- Car too low for shops???sh*t
- 2000 Honda Civic Timing Belt Change - Suggestions required.
- d15b8 on a y7 quick question!
- 99-00 Civic SI Front Lip Part Number?
- civic ex 96 window visor installation
- Ignitor unit
- Buddy Club vs. Skunk2 camber kit
- Would Coilovers in a Rollover Car Still Be Good?
- weight of a 14 inch steelie
- cluster
- fog lights broke
- clips that hold side ground effects on?
- lowering problems! need help
- throttle cable
- 4dr vs 2dr
- 95 gsr 4 door interior direct swap into
- Are 96-00 civic hatch/ coupe exhaust B-pipes interchangable?
- How to remove front brake discs for EG civic
- z6 question (im stumped)
- Downpipe suggestion..
- aftermarket slave cylinder good or bad
- ctr spoiler fitting.
- High rev Check light
- I need some help please!!!
- B20b swap issues
- re. vtech grounding
- gauge help?
- do i need the prelude carriers if i fit prelude calipers to my ek 4
- engine idle question
- my car on start up.
- Main caps?
- problem with the hood release
- Ep3 rears into eg hatch ? Or am i better off getting Type R's ?
- Car Problem. Please help:cry:
- moly additive in trans
- After replacing both axles and new motor mounts, somewhere still click/poping
- what do i need to replace before swapping my b18c into my ek
- EJ2 Coupe (92-95 civic 2dr) - Where to get windshield mouldings, power rack and pinion, and other pa
- VX vs CX intake manifolds - are they the same?
- HELP ASAP
- Greddy SP broke I think :( *shrugs*
- Don't know what ecu i have
- Tick/Knock Sound
- 93 civic radiator support removal/airbag disengage?
- JDM PR3 ECU not starting up my car??
- Car sitting to long
- Y8 tranny on D16z6
- fuel line
- Engine Swaping
- p28 or p06
- Remove ac and ps
- which is better?
- 96-00 Honda Civic Vs. Acura 1.6 EL
- an oil leak... :(
- Me introducing my self
- 95 HONDA CIVIC 4 DOOR EG STOLEN TONIGHT AT 10PM URGENT I NEED UR HELP!!! PLEASE
- Vid: auto-manual swap, d16y7 with y8 intake manifold and throtle body, no vtec.
- Thinking of fixing up my car, where to start?
- Electrician types: Engine bogging ~12.5v until ~2800rpm, then 14-14.6v after.. is this normal?
- NITROUS HELP
- ground VTEC solenoid?
- car wont start
- How do I start my car??? D16z6...with slight wiring problem...
- B18CR Axels, EK Civic Spindles
- EDM amber clock with no pigtail????????????
- rear disk swap question
- B16 Tranny Issues
- NEEED help ASAP.....95 eg idle problem
- Lack of engine power
- Distributor on a zc
- EM1 Rear bracket same as DA??
- Which iacv to grab?
- how to reinstall C circle clip of front lower ball joint,
- front lip on civic lx
- Vibrant Performance J Spec
- quick wiper switch question
- EVO's up front........99SI
- alternator help
- d15 civic IM Intake Manifold upgrade mod?
- Wings West RS front lip for 92-95 still available?
- turbo b20/vtec question..................
- b16A2 swap into 94' del sol
- 99 civic lx whining noise.
- help on o2 sensor (if needed to be rewire)
- The 2pt vs. 3pt tower bar discussion *searched*
- LS Boosted vs B16 Boosted?
- ssaacckkeedd is a scammer
- Early Redline?
- Exhaust system help
- car wont go forward
- WEATHERSTRIPS! WHERE TO GET?
- Help question!! Need some info about rear disc swap
- EK Rails on Recaro SRD seats?
- New quarter panel from Honda....
- HELP! My Power Steering tank is STUCK! How do you..
- 95 Civic non-ABS brake pads
- Pedal Creaking Help
- How to replace front lower ball joint for a eg ciivc?
- EG steering wheel in 92 integra?
- timing advance / retard question.
- ENGINE DIED WONT START
- Hondata S300 question....
- Ball Joint Install Help 94 civic
- D15B7 build it?
- not full potential?
- ***HAPPY NEW YEARS HT***
- wheel spacer???????
- Side Mirror question
- d16z6 or d16y8
- Passenger side window problem...help plz
- looking for automatic short geared b series trans or a shift kit for a b20 swap...
- Strut towers
- h22
- Thanks
- Front Speakers
- gsr stock shifter on ej1 coupe
- Can injector duty cycle go past 100%?
- Europeans, help me out!
- b20 vtec..i need help plzz...
- Picked up a '99 Si, what should I do?
- Happy new years I am in Germany!
- 99-00 b20b in 92 EG. ??knock sensor and intake maninfold.
- need some info on SIR steering wheel
- someone please tell me where these pins go...engine harness
- d15b injectors (what size are them)?????
- Hondata and wideband
- exhaust question vibrant performance
- SAFC2 Wiring ?!?!
- How to Avoid Being Ghetto
- NEED HELP!!!
- Where the heck can I place my ballasts in my 00 Civic Si?
- no spark
- For Sale: OEM Honda Optional CD Player
- EG cluster questions
- big problem in need of help please
- quick ? eg si intake manifold onto vx engine
- z6 tranny in an EK?
- How can I calibrate the VSS for the size wheels/tires I'm running?
- Help!!!! SERIOUS DEL SOL PROBLEM!
- ??Rear Fender Protector Removal??
- 99-00 civic Si VS Ex Lip
- car location question
- Need help with CEL
- car alarm question- parking light output (+/-) relay
- Some help--i need a interior code from a del Sol
- Cruise control
- Questions?
- civic EJ/EK engine swap
- Buying Honda locks of Ebay....hmmmm
- cam questions... plz help
- jumper harness.
- creaking sound from upper strut mount area in 00 em1
- p28 chip for sell?
- LS build question?
- well, car is out of comission for a little bit now. need possible diagnosis, searched
- Low pressure side port?
- h22a euro r w/ T2W4 tranny... Need axles
- rear engine k20 ef
- h2b help
- my car isnt heating
- removing 3rd brake liight
- car stutters and grinds
- JDM SiR2 Fusebox diagram Needed!
- Vtec just kicked in yo!!!
- spammer
- poping/clicking sound whenever i step on gas or make a turn
- Clutch problems
- Will a bad coolant temp sensor throw a CEL?
- "Popping" noise
- 2000 Civic Si muffler.....RSX muffler......Type R muffler
- Has any1 Seen this swap?
- GSR????????please help
- Are there JDM sideskirts for the 92-95 hatchback?
- eg hatch questions
- Help ... did swap and car wont start!
- vacuum manifold???
- Dashboard Lights
- kyb and tokico shocks
- new owner, first car, LA
- so what can possibly be wrong with the map sensor?
- i need ek side skirts coupe
- iat sensor problem
- b16 or b18
- ******POST YOUR CIVIC PICTURES******
- vafc + safc question?? asap
- cel 20. need help please!
- Air vent block off plates
- Where do you get switched ignition from in the fusebox?
- PICTURE REQUEST... WHERE YOU MOUNTED YOUR MSD 6 control boxes
- b16a2 with profab header???????
- EG to something new?:?? er..
- brake booster and MC question.
- scammed on a B18 swap: where to go from here?
- por man type r or b16
- problem!!!!
- h22 civic problems...
- clicking injectors?????
- Need help with my power windows..
- A Second Look at Things
- HP VS TORQUE?
- Buddy Club Vcon vtec controller
- AIRBAGS
- Sunroof installation
- Need Help please!!!
- 99 civic boggs down at a constant speed
- removing axel back
- Lowering springs from a sedan to a hatchback
- Brake light problems....not so bright. Help!
- Do You need to remove Intake Manifold to install knock sensor?
- Tanabe Super Hyper Medallion Exhuast and ASR w/ 22mm ITR sway clearance issues
- Repair Manual???
- idler pulley assembly
- Just got my B18B1 block back from my mechanic.. how do i identify it's year/vin/theft status?
- Engine removal question
- how can i install a car alarm on a 1996 civic
- Heating Problem HELP.
- Hearing knocking noise when turning...HELP PLEASE. not the axle!!
- idle issues
- is d16y7 worth turbo charging for lil more power???????
- Motul Gear 300
- Honda Civic turbo installation
- steering noises
- 92-93 gsr distributor will fit on 92-95 civic ex??? it fits but will it work???
- Smelly Vents..
- SRS light popped up
- Fuel pressure problem
