View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Help with Driver side window!
- Squeaking Suspension ej1
- 1993 Civic VX hatch H22A
- Temperature Control doesnt work in 92 EG
- help where is this oil leak coming from???
- 92 civic climate controls dont work/move
- 92 honda civic fan making screeching noise
- How to do 2000 front conversion??
- 99 Civic hatch/98 B18C swap/P28 ECU/OBD1-2 jumper harness - cranks but won't start
- B20 vtech vs. h23a1
- High Flow Fuel Rail slowed me down?!
- EG hatch - How do I remove the 3 Piece Spoiler and patch the holes?
- Where buy front bumper for a 99 Civic ex or si?
- pcv valve/ gas mileage loss
- Boost problems
- Motor cuts out only when it's cold outside
- car stalls then dies when i turn on the headlights...HELP!!
- Help!! My EK hatch starts but then stalls in cold weather??
- Eg vs ek
- Built b20/vtec looses top end
- help me
- find rims for slicks 13x8 for honda civic ex 93
- Brakes Almost Touch the Floor
- 98 LX, no spark
- Please Help! D16Y8 Hesitation & Bogging
- FRONT NOISE WHILE DRIVING HELP!!
- bigger tire/rim size affect mph?
- b20 swap help!!!!!
- LED Exterior bulb question...
- SUSPENSION: STRUTS/COILOVER HELP!
- Reverse lights Stay ON while in Drive
- rota grid - would these fit on 98 civic?
- converting a 94 civic front bumper/headlights to a 2000
- ek ls swap problems...HELP>>>
- Seat paint longevity?
- HELP B16 Idle problem
- Help. JDM d15b vtec grinding gears.
- 92-95 Coupe & Sedan Windshields Interchangeable??
- B16B Head Questions
- electrical problem blinkers flashers brake lights hazzards
- 2000 civic ex automatic -- need some diagrams
- Radiator Fan Stays on W/O direct Wired?
- 93 Civic CX Hot Start problem?
- Did anyone use osidetigers injector ??
- Exhaust system repair - 2000 Civic
- canister and purge valve removed
- Honda civic rust prevention
- B16 manual tranny full swap
- major pain in the *** problem
- B16A Crankshaft Oil pump pulley seized?!? (Pics)
- * 95 Del Sol passenger door wont open *
- Stock honda ecu and injectors?
- swap emissions
- b16a obd1 swap
- my eg lights wont work
- 94 vx o2 sensor 5 wire to 4 wire conversion
- issues with 98 civic low beams; not headlight switch.
- supercharged d16z6
- Bad Ignition Coil?
- How to swap out targa internals
- LS Vtec/ Nitrous Question..
- Del Sol - D16z6 - Vtec won't engage
- Which fuel regulator for all motor LS?
- eg and ek swap questions
- Removing Tint
- b20z ek
- CEL 3 on a 97 coupe. Wiring Issues?
- itbs vs boost
- 98 civic-possible to remove engine+trans with shift linkage still connected?
- 98 LX mystery connector under dash
- cluster is too dim
- Doing the right stuff but NO power gains!
- EK hatch build
- D16Z6 dizzy firing order HELP ME!!!!
- Newly Purchased 93 delsol s b20b - rough idle, back fire, and CEL
- 98 Coupe - want to swap seats over
- 99 si/b18c1 boosted swap with high surging idle
- single cam clutch question
- 99 Civic D16Y8 fuel injector air assist valve
- D15b or D16z6
- Exhaust Pipe diameter
- Problems with d16z6
- Overheat with solid CEL. Fixed overheat but unknown cel
- High compression pistons in a b16
- Tacho Problem
- Help with 2row or 3 row radiator !? :p
- lights went extra bright then quit, 2000 ex
- y8 shortblock
- single cam build!
- longest gears ever?
- Few manual conversion questions
- 98 civic ex solenoid valve and oil pressure switch.
- ek hatch new window regulator... is it L or R for driver side door
- Glass or Plastic Housing Headlights; EJ1
- Part number for rear defrost connectors in trunk
- 1997 honda civic DX hatch, dome light is not working and I have searched!! Alot lol
- Need part number for Z6 distributor
- Help!! I have searched and searched
- 98 Civic Ex daily build thread
- how to fill up mtf in gsr tranny
- Increase speed
- 96 civic wit gsr swap...can i add power steering
- b18 in ek sedan... engine leaning issue
- GSR IN EG HELP!!!
- New honda member
- Rear brakes making noise
- 94 Integra GSR P/S Pump on B16A2?
- 92 hatch front camber kit?
- Coilover Sleeve adjustment on eg hatch
- 99 civic swap
- Vtec Solenoid Seal help
- Best Way to Learn About Your Car?
- 95 Del sol stalled and wont start up!!
- y7/z6 mini me jumping timing
- 95 cx five lug problem!!! need help fast!
- funny idle problems
- HKS Silent Hi-Power Exhaust
- new 97 ek sedan owner/new build
- Air Intake with B20 swap
- EG+F22 harness+H22A+P28+Turbo Questions
- D16Z6 auto and manual redline difference?
- 98 EX burning up main relays?
- 95 civic speedometer not working...
- 93 Honda Civic EX 1.6L cranks but won't start have gas, spark
- Honda No Spark Ignition Troubleshooting Guide
- 99-00 civic coupe all clear tail lights anyone???
- 98 Civic -Help removing door panel when door wont open
- What Top Hats to get for Progress CS-II Coilovers?
- 97 civic srs clear hard code?
- 2000 Civic Hatch DX (IDEAS)
- Civic Coilovers
- east coast distributors
- Safety Question
- need help !!with my 97 civic no spark
- 93 Civic - ls/vtec no fire or fuel pump need help asap please
- driver side caliper sticking on 93 4door civic 1.6 liter cxv
- 99 si/b18c1 swap won't communicate with scanner for emissions test
- OBD2 GSR block, b16 head in OBD1 civic. Running rough. Any tips?
- Master cylinder abs fit on non abs EG?
- Ej1 gauge cluster, clock windshield wiper, and turn signal problem..
- 95' Civic shaking above 60mph
- Open Loop/CEL?
- what intake to run
- SIRII parking brake cables on VX , too short?
- Del Sol Map Light Install Issues...
- 00 b16a2 making knocking noise
- Why does my B16 smoke at low rpm and at idle
- White cloud of smoke coming from exhaust
- JDM B16a - Would thermostat from a b16a2 fit?
- 95 brake light out...?
- Del Sol tire size question
- windshield wipers stopping half ways
- ek sir conversion
- How much hp and tq to wheel with jdm b20 engine/ls ecu/ls trans?
- 97 build,
- Skunk2 manifold, pcv from charcoal canister, in to manifold?
- How to beat a H SERIES with a B SERIES
- Looking for an EK Black Interior
- 95 gsr motor in 96 hatch
- 12.9-12.5V system voltage with engine running
- weird shut off issue
- 92 civic b18c overheat only during vtec!
- Intake manifold suggestions for a B18C Type R
- vtec hookup
- Torque to Yield Headbolts? Oil Control Orifice? '00 Civic
- Cage weight
- Stroked and boosted b18c
- 93 del sol si h22
- Virgin Stock 97 Civic DX hathback
- which cap and rotor?
- 95 civic ex won's start or won't stay running
- Performance Help! where to start with d16z6 del sol!
- OEM vs aftermarket window visors.
- fuel line upgrade questions
- eg with gsr swap.needing smog legal tb suggestions
- stripped bolt hole need help..
- what are the differences in each eg hatch?
- 99 hatch power steering
- Del sol targa top leak/trunk question
- New Header help
- d15b8 rough idle
- 94 Civic DX - Fuel pump primes but no spark
- No electrical power help
- 2000 Civic Suspension info
- 99 Honda Civic - Rough idle, stalls at full open throttle
- Advise on vehicle purchase.
- how can you tell if its ex or si clustee without turning it on?
- j4d lsd axles?????? need help
- 94 Civic Hatch horn and srs light issue
- Car Wont Drive?
- 96 hatchback gsr swap axle help
- Need part number rear hatch hook - look!
- Popping issue 94 civic coupe help?
- pics of needed trans mounts for auto-manual swap
- how much was a civic DX 5sp hatchback retailed for?
- B18c idling too low, fitv too tight or idle screw adjustment?
- No start after stalling engine. distributor and rotor replaced 1/2 hr prior
- Quick Question: Bad P28 Ecu throws Code 14 and 22??
- Quick help!! Ek headlight and interior light wire loose?
- EM1 with XXR 513 15x7 fitment
- 93 civic si engine question
- Clutch slave cylinder?
- 98 civic purge sensor
- Hey All! New Guy Saying Hi!
- 97 civic ex cruise control don't light up or work
- where to find .75mm .030" oversize rod bearings?
- 95 d16z6 turbo...running like crap blowing smoke...dont know where to start
- DSM convert!
- Sensor Repin
- issues with distributor & stalling
- Help, d16y7 oil leak.
- EK Overheating
- Traction bar installation on Civic 99-00
- lower radiator hose cold
- Lsv no spark on ej1
- 3 stage vtec Idle Wiring and IACV (my experience)
- EG43 D15B2 (DPFI) - Coolant bleeding procedure?
- B20 EG idle problems....
- Where to start on a D16 Turbo Build?
- Possible Dual Cam Zc vtec?
- Avital Keyless entry
- 99 em1 harness
- Civic 95 coupe - Idle, deceleration, A/C, and mpg problems - PLS HELP!!
- Arp main stud
- d16y8 turbo and meth inject as a daily driver???
- 2000 civic coupe aftermarket (ebay) foglight help
- 95 hatch dx brakes sticking
- Injectors go lean on vtec?????
- 95 civic ex-i????
- 1995 Del Sol Suspension creak and wobble
- 1997 Civic URGENT HELP! Gas tank holes
- 1998 Civic Lx Radiator Leak
- 94 Civic Not Starting?
- Interesting TPS problem...
- will eg6 rear panels fit into an ej1 coupe.?
- Removing sunroof Visor Glue
- 98 Civic overheating. Possible coolant in heat system?
- 93' Del Sol Si H23A1 Project.
- 1998 Civic erratic overheating problems-please give advice
- Possibly making a trade... 98 LX for 00 CX... Questions.
- 96-00 roof rack install?
- Car overheating help
- '93 cx with a D15B7.. no power over 3k, struggling
- h22a 95 civic coupe engine harness question
- Civic 1992 LSi strange coolant gauge raise
- '95 Coupe: 'Thud' when downshifting
- Restore engine additive.
- Crankcase ventilation vacuum hose question.
- funny acting after head studs n gasket?
- my driving lights went out and it keep burning the fuses
