View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Need info on b16a1 motor
- Can somebody please help?
- I push on the brakes and idle goes up ?
- Noisy tranny. Doubt its the TOB...
- 99 civic si tach stopped working
- How much my car worth?
- Overheating issue on swapped 98 civic
- b16a2 tensioner question
- B20 Or D16y8 turbo
- Cam pulley timing causing rough idle and MIL?
- Question: On a Y8 head what OE intake manifolds can be used on it??
- D15B8 to D15B7 swap??
- Tein Basics
- 92-95 civic power door conversion
- d16y8 header fit?
- vtec solenoid
- EG to EK suspension question!
- 96 Civic d16y7 Idle issue
- Clogged Catalytic. Got Fix?
- Car Sputtering Need Help
- Close to everheating, radiator fan
- info on this jdm Subframe brace?
- What is this (PIC)
- Just bought a 99 Si parts car
- buddyclub spec II, del sol?
- Question regarding rear disc conversion/master cylinder
- em1 rear valances where are they
- issues after new harness install
- No speedo/trip/vtec - ITR swap
- How long did your clutch last?
- i have a question can anybody help
- si trans rebuilt problem
- '99 Civic LX P0420 Code
- How to drain tank? Old Gas
- Best shoes for driving a manual car
- Greddy Turbo Timer Install HELP!
- OBD2b 16y8 to ODB1 D15B
- Center Caps?
- Racing Hart C5 3 Piece Info help
- anyone know what sensor this is?
- Coolant to Head adapter
- D16y8 help plz, dont know the name of this part...
- 1998 honda civic manual rack and pinion question
- Can you handle my d16z6? Inquire within...
- Lost as what to do with motor
- starter problems after clutch swap
- i have a couple of questions about a stock d16 y7
- Lowest seat/bracket for 6'5" male in EG
- 99 GSR help
- Del Sol/ My Trunk Struts are shot
- HELP: D16Y8 Engine
- OverHeating? BUT WHY!
- EK rubbing tire need help
- Does your shifter vibrate?
- [B]Eg Cluster not lighting up[/B]
- 92-95 civic rear wiper plug doesn't work??
- NEED HELP HIGH VOLTAGE PLUS 3 OTHER CODES
- Cel p0740???
- weird start-up idle on 98 lx
- Want to learn to make carbon fiber parts
- cant read cel on jdm eg6 cluster
- IM Gasket Replacement
- New here with a 95 civic with LS turbo swap...
- PGM-FI... Why!?
- Horn not working, only "click" sound - 98 Civic
- Mixing clutch/flywheel - Quick Q
- RPM is Erratic and Fluctuates when driving Hard, EG Civic with B18C1 swap
- 98 civic b18c5, go to crank all power shuts off.
- shell
- Best Exhaust System for EKs
- D16z6 bore to 76mm max hp on stock sleeves?
- dash
- New Guy from Minnesota
- A couple problems going wrong with my car..
- Help With A/C wanted
- lugnut lock broke, what to do?
- 2000 Civic Si
- need help on putting spoon/itr calipers on my ek
- My '94 EG8 build
- 94 civic no crank
- Wheel bearing replacement cost
- Skunk2 Coilover Sleeves vs. my wife.
- quick question
- Electric sun roof not operating
- JDM b16a bumps CR of b18c1 engine
- Jdm b18c itr swap in Ek = 17 mpg????
- 94 ex front sway bar question
- EH9 suspension question.
- Benen Front Lower Tie Bar on 92 Hatch
- ECU compatibility (pertaining to CA residents with BAR knowledge)
- h22 swap?
- d16y8 ek CEL help!!
- Ipod adapter or Aux wire
- OBD2 Question
- 5 wire O2 Sensor
- New upgrades..b16a2....any suggestions?
- GSR Swap issue-Injectors? HELP!!
- honda meet?
- Wheel stud broke?! wheel wont cant come off!
- sohc IM help
- d series shift linkage part no.
- Are my tie rods out?
- Lower my civic
- My first Honda...
- trouble shifting *AUTOMATIC* need help asap!
- Need help on rim size
- New on Honda-Tech
- Question for EG owners
- oil nut stripped?
- 1995 civic SI won't start
- huge oil leak help
- EF rotors on a EK
- What clutch upgrades can us del sol owners make?
- ls head bolts stripped!
- EG civic front amber corner light bulb.
- Car does a nosedive when I get off the gas, and hesitates in low gear acceleration...
- Radio Code
- USDM Engine Suppliers
- Problem with rack and pinion
- Integra springs on a civic
- toda type c with blox valvetrain
- vtec/oil problem
- d16y7 loosing coolant, blown head???? please point me to the symptoms.
- Brake light help!!
- How to take a deck out of a 92 eg ..
- 99 civic rough idle after overheat
- need help?
- 2 SteP question.
- CEL CODE 23 (knock sensor) Help please
- NO POWER TO MY CAR
- Lots of Oil Leaking from Back of Block, need help!!!!
- integra ac in civic ej1
- D16z6 Clutch bleed????
- Anyone know what pen/marker pick n pull uses for warranty stuff?
- Looking for local shops: ATL
- civic lip question
- headlight
- 'Drag' wheels, junk?
- Calipers do not fit on with new pads and rotor
- Need help getting my si to pass smog!!
- Y7 to Y8?
- cel code 41
- BEST SUSPENSION SET UP FTW
- b16 engine rebuild help!!
- mini-swap vtec oil pressure helpp
- Need help..A/C question
- I got a 94 hatch which motor should i go for?
- D16 check engine light on and cant get high idle to work
- integra sway bars on EK hatch
- EG with Type R 5-Lug Shock Replacement Question
- 98 Civic power window issue
- 96 coupe tranny problems
- new car ??'s
- Coolant hose question
- HALP bellhousing bolts
- HELP! Del sol Brake Lamps wont work!!!
- Non-Vtec --> Vtec
- dumb??
- My Civic EK4
- EK9 City Light Install/Harness
- knocking noise?
- ej1 rear disc suggestion.
- Is there any way to install HID into EG fog lights?
- Slow power drain?
- powder coat guy f***ed up suggestions??
- Very confused on my EX header conversion (98 HX)
- Passenger side door wont lock (manually or keyless)
- 99 4dr trunk fit on a 96 4dr?
- PA Emissions Help
- An example of the sick minds of thieves...
- Got an EK
- Axles Binding! Please Help!
- 96 Civic fuel sender location?
- random 2000 civic coupe Question???
- ls swap question
- ek9 head on to ek4
- 1st gear and 2nd gear grind? Bad tranny?
- Good brand of headers
- honda ek tranny fitment need help asap
- Amber Climate Swap w/ how to get your temp/fan levers lit up!
- speedometer not working~!!!
- Cats
- 94 ej1 lsvtec code 3 (map sensor)
- Help!!..I need a part number for a S80 Trans w/ LSD
- 95 civic speedometer flutters
- Help! Which size rims should I put on my civic
- D15B NO SPARKS, BUT STILL STARTS!!!
- power windows and locks
- No Spark an No power 2 Injectors.
- engine breakup from 3800rpm to 5700, no cel, stock gsr motor.
- HELP!! b16 ek axle comes out
- Civic Greddy Turbo in CA LAW
- Grinding on take-off
- 97 civic caliper banjo bolt thread tap?
- Question on Comptech subframe bar/rearsway
- what does the radio have to do with the turbo timer?
- P2M ecu same as P2P? I have searched
- Kind of a weird surging idle (95 coupe)
- '94 Civic hatch SRS sensor location
- Well that was just weird.
- need a hand on my front end conversion?
- eg 4 door problems, windows, sunroof, and more
- gas leak between FPR and fuel rail
- gauge cluster lights prob
- clutch peddal stays on floor!
- 1995 HONDA CIVIC HELP PLEASE!!!!
- swaped civic keeps blowing main relay???
- Possible exhaust leak and emissions issues HELP!!!
- a/t to m/t conversion help??!!
- 96 Del Sol S Intake advice D16y7
- My build thread: Project Ej8 Take 2
- 97 civic ex keyless entry programming (not the same as lx/hx)
- Obd 1 b16 into 2000Ek code 6 help!!!
- IAT unplugged but no code
- 97 civic ex coupe with a 99 B16a2
- Need help with ignition timing
- S20 Isb Repair Help
- sohc zc block/z6 head(not getting power)HELP!!
- arp head studs
- Which Shift knob to BUY?
- How much is my car worth
- Integra AC in Civic?
- Where to find a good "true" 3'' exhaust for GE
- EG Thule or yakima Rack
- EK4 from northern ireland!
- fusebox wiretuck and a/c removal?
- power windows clicking
- D series head compatability?
- RC injectors wont fit ITR manifold
- b18 oil pump problem
- Have I Screwed Up The Gasket ? Weird Rain Scenario.
- THROTTLE CABLE DILEMMA !
- Center Caps
- Suspension question 93 sol
- Barometric Pressure Question
- Help! B Series; car shutting off
- Doors
- b16 w gsr cams? b18a1 w b16 or gsr cams?
- Back up fuse keeps blowing
- dseries dizzy ?
- Si Rims offset??? Anyone?
- Honda 98 LX misfiring chugging worsening problem
- Strut Fit Question
- Do grounding kits work, are they worth the money? Would they help with dimming lights
- b16 oil pan on a Ls block
- 2000 honda civic hatchback Acc fail
- D15Z1 Problems
- hey people i need a little bit of help with my ek
- EDM rear fog light switch
