View Full Version : Honda Civic / Del Sol (1992 - 2000)
- hondata intake gasket???
- installing a ITR/97 prelude sotck CD deck into a 98 civic coupe
- brake questions
- Honda Civic CX Specs??
- D Series clutches
- anyway a 89 crx clutch will work on a eg?
- A couple pics of my hatch..
- y8 camshafts
- need a link to the website(already searched)
- What Would Make Vtec NOT kick in??? 99 Si HELP!!!!
- If you were me... You would pick..
- Calling Tom and all others who know tranny and suspension woes!!!!!!!!!!!!!!!!!!!!!!!
- ***Need Help*** Del Sol
- Cost of replacement bolts
- Will a header for a 92-95 Civic fit a 96-00 Civic Coupe?
- clutch fluid..... disadvantage to dot3&dot 4 fluids
- NEED KNOWLEDGE ON CIVIC MOTORS
- Man, need your guys opinions. Bad service related.
- Will an OBD2 D-series motor work with an OBD1 ECU?
- 97 Civic EX 4 Sale
- 97 Civic EX 4 Sale!!!
- clutch fittment
- Front window seal repair?
- EF to EG?
- for those with Ingalls camber kit...
- magically after swap my tires start rubbing......
- Automatic Transmission Swap
- newb with qustion 4,99-00 Civic Si(SiR)
- POP QUIZ: What does SSR stand for?
- pros and cons..prokit/sportlines
- Safe or not?
- Boring out 1st gen b16 TB
- Anything else needed to replace power steering rack with manual rack?
- BooRacing New User
- possible rear LCA problem
- H22A in EG HATCH
- Wot is the average age of EG+/Del Sol owners
- Upgrading brake boosters w/mc question?
- EVER WEIGHED YOUR EK??
- NORMAL USER!!!
- ITR internals on b16a2
- trouble with my 2000 si
- engine bay paint pics (no 56k)
- Bad Idle...... On JDM B20B
- lug patterns on cars...
- anyone have this em racing rear upper strut bar/pillar bar on there hatch?
- OBD-1 D16z6 have knock sensors????
- Best shifter bushings?
- suspension on a budget
- ARGH! My car makes noises while turning!
- Tie Bar Bolts
- exhaust question?
- camber kit.. these any good?
- new pics of the Del Sol..
- Need HELP PLEEEEEEEASE. BIG problem
- WTb EK stock radiator local perferred
- Question about Polyurathane Bushings?
- max psi on stock b18b
- gsr into a cx with complete LHD harness
- lookin for a stock deck? which one should i get?
- Quick and easy EG question
- considering a honda
- Wide Body Kit for 93 Civic Coupe...
- Thinking of selling out....how much is this car worth?
- what intake to use?
- Woot. Scored an Apexi VAFC today for 100 bucks.
- eibach springs?
- help me please, first swap
- safc battery, help quick!
- orange plug-in on swap
- my pos 99 hatch.
- HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- I need help on a swap before I invest
- 92'-95' civic v.s. 93'-97' del sol
- Can someone post pic of Vehicle Speed Sensor plug? No Helms here.
- 92 Ls into 92 Cx Hatchback??
- 96-00 headers for civic
- ITR sussy installation
- Squeaky SSR Suspension
- Antenna
- Focuz headers??
- Civic back seats.........
- Need Help ASAP!! Brake tech!!!
- MINI ME!!!!!!!!!
- Headlight Buzzer Question
- Boost Controllers
- Turbo Timers
- I'm New WTF is B16, EG,EF,& all this jive talk?
- Overheating B16 motor that I put together
- DxHatchback Photoshoot (17 Pics, 56K OK)
- Would anyone be interested in a honda-tech.com t-shirt group buy?
- my car has issues b18b civic
- what i happen if i drop
- good exhausts
- 1st Gen B16 head on a 99 LS block will B16 distributer fit?
- whats a good spray on lubricant/oil?
- Quicker ratio steering rack?
- bolts on stick on pull my sohc vtec
- oil pressure sensor Q need help fast
- Del Sol Auto to Manual swap any threads Searched already
- 96-00 lowering springs on a 92 civic si
- Help 99 si wont start...
- gas gauge fluctuating a lot!
- D16Y7 pistons/rings
- hard to get into second gear...any idea's ?
- This is my new EG Hatch 93.
- engine swap in EK question.
- got question on 98 gsr swap in 00 coupe ex
- first car show and pics of hatch
- Manual or Power Steering?
- 96-00 muffler
- Stinking Power Window Conversion!!!
- Just Picked Up a 2000 CX Hatchy:Check out the pics...
- Anyone have any stock 96-00 civic HB sideskirts?
- Need help, how much would you pay for my ride + extras....
- Switch tranny to manual or buy manual car?
- anyone know the part number for the del sol vtec A/C bracket, 99-00 SI driver side mount, and 99-00
- Can someone tell me what it feels like when you break a LSD? ( TOM HELP REQUESTED)? please!
- Wiring on a 93 hatch???
- insurance illegal??
- Vtec oil pressure switch connector question...
- D15B Parts?????
- Whats a THE BEST short shifter?
- frozen lost motion assembly d16z6
- header for b18b
- Shaving flywheel... most weight that can be safely removed???
- How much would you paid for Tein RA for EK ? I found a good deal !
- where can i find gaskets online?
- Flywheel or Header? Which one should I get?
- midpipe lengths...
- What intake do i buy??? i jus need a fast answer
- Will a Z6 crank fit in a Y8 block?
- Wiring!!! PLEASE HELP!!!!
- does anyone know if this brace is anygood
- B18b-T or GSR?
- 93 Civic EX Idle adjustment
- warm AC problem
- safe way to jumpstart car>>>
- compression of a d15b7
- cx tach help
- Hello! First Post and a Major Project
- mini me
- front lower tie bar and c-pillar bar... YAY or NAY??
- Electric Impact Wrench? Any Good?
- what octane fuel is recomended
- Radiator Help!!!
- cel #6??
- help on removing pistons d15b8 cx block
- CF hoods...
- brake kit that will fit for 15 inch spoon rims for a 92 EG civic
- dx vs ex/si tranny???
- i'm gettin tired of this....
- CIVC HELP
- Whats up guys....
- intake help, for Civic 2000 EX
- Will d16z6 power steering fit on a d16a6??
- wats the weight ratio for my ek?
- installation for Mugen grill civic 2000 Ex, help.
- Exhaust
- 93 ex transmission
- Gas Mileage Question
- Look at what I got for $400
- ?????????????????92-95 Civic Camber kit???????????????????
- ek rear lower control arms suspension????
- Weights of parts from rear of an EG
- D16Y7 Looking for 30 - 40 whp NA
- "C0dE ErrE"
- High Flow Cat
- Quick Vafc/ecu question
- Question about the extra wiring involved swapping a b16 (99-00 si) into my ej6 (99 non-vtec dx)
- What causes that trademark "chattering" in 6 4 and 3 puck clutches?
- clutch or synchros ?
- Ebay SiR: Conversion or the real thing?
- i don't usually post links to E-gay, but this Sh*t is too funny
- new intake, why 2 holes ?
- d16y8 into a 1995 coupe questions
- need help with belt size to run AC
- need help finding d16z6 bottom end or whole
- suspension questions
- header
- is 95 si TB same size as 95 ls?
- oil cap breather
- New dyno results...Not so good...
- Catalytic Question . . .
- Help with 00 si Swap Problem???
- help! nasty noise!
- need help with tire selection
- Spindle / Knuckles from all 92-95 Civics compatible?
- How to clean Headers???
- where to buy d-series
- turbo b16 or all motor?
- 92-95 hb stock tailights..where to get them
- CAR STOLEN!!
- bumper sagging a lil on one side
- just bought a fpr what is the correct adjustment(psi)?
- mini me dizzy question
- HELP !!! cam bolt broke
- How much does my 92 HB Si weight?
- Think I can paint this?
- will i pass CA smog with these mods? (search done)
- JUN chipped p28 problems!
- Does Anyone have Speedmaster A-Tech Finalspeeds?
- Oil Change/ how often
- Where To Buy: '99 Si LCA Bushings
- Acura RSX Type S muffler?
- Skunkworks Coils VS H&R Springs
- I need interior shots!
- CANT FIT MY NEW BRAKE PADS IN...?
- Questions about SI cluster into EK hatch
- projector headlight install......need help
- d16z6 into cx need to wire 02
- Wanted 92-95 Civic Ex Rear Speaker Grills
- Best struts for 99 Civic HB.
- Someone measure your lights !
- KYB Shox???????
- Spring ???
- help!!!! need help with daily driver!
- Did the 99-00 EK hatches come with moon roof? If so was it only optional?
- Painted Engine Bay Today - Opinions? (no 56K)
- 96-98 headlights?
- Update on my stolen Si in KNOXVILLE, TN
- HELP PLZ
- Changing over an Air Conditioner
- EX RPM tach
- anyone swap a 94+ dash into 92-95 hatch? i need help
- mirror q?
- Civic Type R Steering Wheel Will It Fit??
- best place to get alignment in Miami area?
- could i fit
- Front ends?
- All this and still no inspection sticker, but i made some cash (pics)
- News for ARC air box owners!
- My hatchback doesn't corner that well. Anybody have some helpful ideas?
- ctr muffler?
- Help on the o2 sensors for my Civic 2000 Ex intake.
- who uses a car cover here?
- Finally Ran Stock Si
- I don't understand the sensors on the intake for my Civic 2000 Ex. Plz Help!
- is this a good resonator?
- Is it safe to redline?
- Bisimoto D series Header dyno
- body parts needed..
- question about si vs. other hatchback models
- Emission Testing Blues
- Civic peformance engine mount
- Dash conversions......
- 92-95 civic ECU question
- Problems with setting VAFC
- new valve cover + old valve cover gasket???
- axle-back and cat-back
