View Full Version : Honda Civic / Del Sol (1992 - 2000)
- How much taller is the B18 series of blocks over the B16 block?
- Would this be bad on my suspension?
- tranny blown need help
- Bad News
- air blowing out of oil filler hole, when cap off (b16)
- Parts for valve adjustment
- What other seats fit my car?
- 92-95or96-98
- 94 civic won't start....pleease help
- Why do starters go bad? Any guesses?
- Can someone show me what rims look good ona teal hatch
- sway bars or new suspension
- ek ls swap(need help)
- fuel cell any one have any pics of thim in a civic Eg+
- 03 Si Recaros in a 98 civic cpe
- steering wheel jerks when I stop
- I need new struts
- tranny fluid for 00 si
- Does an EG catback fit on an EK?
- shifter bushings
- What is a good short shifter?
- Electronic Load Detector??!?!
- Confused about this lug key help please!!!
- Pic request: Ryans blue sol from old skool JDMHONDAPARTS.COM
- D-Series header fitment Q
- **Big problem doing mini me swap, need help**
- Omni Coilovers
- need 2 kno! i jus bought a 94 civic hatch dx (tach problem)
- DX Cluster Swap
- Bill of sale for Engine Swap. What info in important?
- **UPDATE** Recent problems with the eh3 hatch...
- restGauging interest: H to B series adaptor plate
- CAN i USE THE STOCK LINKAGE OF MY EG
- ST rear swaybar for EG/EH PIC REQUEST!
- civic hatch rear disc conversion questions....
- ever seen a harness plug with only 1 wire attached to it?
- Monza/Pacesetter exhaust ?
- Accident Repair Costs
- A Good Deal
- need help...install seats...i did serach couldnt find
- What Size Speakers for the front in an EG? what tweeeters to cover up hole in door
- what is better for an ek civic?? b16 b18 or h22???
- EG or Del Sol
- how can i get off of being a trial user?!?!
- adjusting ignition timing
- Interchangeability between 95 EH3 (non ABS) & 98 DC2 (ABS) front disk brakes?
- Sometimes, it's hard to shift into gears... Synchros going bad?
- Bad vibration during acceleration
- **need help making a desicion about my stolen car**
- 2000 si swap into eg
- b16sirII using gsr axles... do i need to use the gsr intermediate shaft or not?
- Lower Ball Joint
- 93' D16z6 - Mini Me crap questions
- need help, 95 civic ex won't run, don't know what else to check, pls lok
- What is the best for HONDA N/A or Turbo??????????????
- ebay ripoff or what?????
- Completely dumbfounded on y8 to y7 im swap!
- motor mount replacement questions
- Code 67: What are my options?
- lug pattern question
- GSR exhaust on EG hatch...?
- 98 civic shocks fit on dc2?
- Buying Del sol - Fair price?
- exhaust sputtering...help
- Question on trans fluid needed (searched)
- what can i do to get the most power out of a d-17 motor w/o using forced induction?
- Drinking coolant
- How to get ABS on a non abs car
- gsr braking system with a civic lx booster and mc
- b20 block what else do i need?
- What did your clutch do when it gave out? I think mine's dead.
- Front Head Light Bulb# For 94 Honda Civic
- brake pad size for an EJ1?
- good find.
- Code 71 and 72 why????
- NEED ENGINE ADVICE: B16A turbo or GSR N/A........
- inspection checklist
- Buddy Club Pro Spec Exhaust on sedans?
- Would this work with a turbo too?
- 99-00 civic si lip
- gc springs for eg and ek the same, interchangable?
- Manual Transmission Fluid
- acura integra cd player in a dx hatchback
- Brake problem on 97 Civic
- Ran the del sol...
- Struts?sways? what kinda should i get?
- Installation template for SI Spoiler?
- decision making help! which motor should i put in my civic?
- Where to buy fast idle valve?
- Symptoms of Bad Idle Air Control Valve
- b16 swap in a 95 cx Q's
- wird noise when i accelerate?
- D16Z6 Head on a diffrent block
- what makes valves drop
- Idle Problem
- Skunk2 coilovers - stock shocks or upgrade?
- JDM itr header with stock si exhaust will it fit right??
- Wanted: Pic of US EK Civic front lower control arms
- cams that work well on stock comp ?
- starter problem
- Question about vtec controllers
- PLease give a look!! Major electrical problem
- Do i need a new engine?
- small turbo and stock clutch..
- truck lip spoiler on 94 couple
- Paint matching parts....
- dizzy going out?
- New Driver side CV Axle needed...
- Noise around 1K-2K RPM
- 99-00 Si Owners who have a Helms manual????
- Drag times between SI vs. GSR tranny??
- 93 hb Si Fan/electrical ??
- help with 94 del sol
- carbon fiber body paneling ....
- Having problems with my swap.
- V8 guy buys 02 civic EX
- RPM Fluctuates after accident
- shot peening rods
- Timing belt is off a tooth?
- A rattle at 2k-2500rpm
- Removing EK Mid Wing...
- Which ignition wires goes where?
- CTR fat chubby lip?
- KNOCK SENSOR? OR HARNESS OR?? HELP!
- My car is throwing code 7 TPS - throttle position sensor
- Converting a obd0 ls distributor to work on a obd1 b18b, HELP!
- will my engine mods work on my new engine
- Tein Flex coilovers
- 99-00 SI radio bezel and climate control in 96 hatch
- sedan headlight question
- GSR mount Question?
- Vtec Head Swap
- honda spec
- Problem with my GSR Hatch.
- Does ECU Jump trick work on '00 civic?
- coilovers
- ****shift linkage issues...
- wtfux? b16 or 18b??!
- A little advice.
- Idle Problem .. Please HELP! =[
- a few questions about eg hatch..............just looking for others opinions.
- I need interior
- Should i add a turbo to my 98 four door civic LX?
- MY GAS METER IS TRIPPIN!?!? HELP?
- Question about cusco lower tie bar..
- What is the High Beam Bulb Code/Number?
- Exhaust Fitment help *searched*
- f22a / f23a
- did the search(cutting valve covers)
- SWAPPED MY FACTORY D16 wont F*%$IN START
- looking for Ek hatch W/ gsr interior PICS?
- turbo 93 dx coupe
- fucked up the tranny need some good help
- kyb gr2 struts go with coilovers?(searched)
- d16z6 and d16y8 clutch release fork
- Projector headlight question
- Need Ecu
- Quick question on GT3's
- civic 4dr pics???
- Front speakers in 92 hatch?
- EG Defroster Bulb
- b16a1 into 92 hatch
- Vtec sometimes not engaging?
- Retro fit in stock housing?
- Need opinions on replacement cat-back for 99 SI
- Can anybody tell the difference between h.d. and sport bilstein shocks?
- Struts for lowered sedan over 2inches (searched)
- DEPO fog light install on 99-00 civic????
- 2004 manual to auto swap
- Civic Newbie looking for hop-ups
- d16z6 shifter fork in d16y8?
- Electrical Problem Help!
- CEL prob wtf
- Any one have an EG optional audio console ash tray laying around willing to sell????
- 95 CX hatch
- 94 del sol help
- best turbo options for daily driver
- 99-00 Si seats FIT into a 96-00 hatch ????????????
- D15B engine questioin
- 93 del sol B20
- How much boost can stock b18b handle? (already searched)
- Exedy Clutch kit
- Skunk2 Q's
- civic/integra springs
- WHAT KIND OF QUATER MILE TIMES AM I LOOKING AT WITH A B18B MOTOR IN A 94 CIVIC DX HATCH BACK??
- Where can i get new mudguards for an EK??????
- HOW do i put a car seat in my eg
- Vtek
- Farwell to the "Civic" forum
- SRS light stays on! WHY????
- 99 si brakes?
- JDM 98spec Type R Header w/ 2.5in collector question
- mini-me swap
- are these the same? quick answer please!
- Philadelphia Car Stolen........ :-(
- Need help with springs for EJ7 (RS*R Ti2000)
- Alternator replacement on a 97 EX
- My transmission fluid is low. How do I pull out the VSS to fill it?
- Wrecked del sol, now having motor issues! help?
- Midwing install?
- EP3 Seats in a EG?
- 1999 si, my fan isn't coming on at all.
- duckbill install on eg
- motor trouble.....
- piston 1 2 3 4
- HELP ME PLEASE!!! ALL MY GAUGES QUIT WORKING! ON MY EG
- manuals?
- what years come in what???
- Fuel Filter help.
- Need help ASAP!!!
- what do you think of this car?
- Z6 dizzy in obd2 arness???
- need help on 98 civic
- F/S 96 civic!
- D16Z7 chip searching. Help!!!!
- grs radiator into eg'' need help''
- HELP!!! ECU Codes for 2000 Honda Civic
- Is there any danger with exhaust to close to gas tank
- need suspension opinion
- B18c/EG wiring issues tying up loose end etc.
- Turbo Kit on Del sol
- Off Topic, but help
- Eg6 near the LA area?
- DOHC ZC Swap
- springs and struts for my hatchback
- Need Pinouts for P28 ECU for a OBD1 B16a (with an AUTOMATIC Tranny)
- electrical problems
- HESITATION
- Auto to Manual Tranny Pedal ?.....Help me out...
- *Socal* any shop in socal that rebuild tranny?
- Exhaust systems for 99 hx civic
- AEM V2 2000 civic Si - ??
- Thoughts about my 92 Civic Dx
- AC problem, really need answers and help!
- seat covers?
- How exspensive is a turbo setup
- gsr
- anyone runnign koni yellows with neuspeed racelines?!?!??!
- just got me a new Del sol
- precautions for turbo charging my civic...
- air filter
- swaybar mountings points question
- CR adjustment for supercharger
- Tires sticking out like crazy..
- Mugen CTR Air Box....LOL
- Acceleration stuttering
- LOOKING FOR THESE GAUGES JDM SIR NOT TYPE R HELP!!!
- sorry about this question thread but i really wanna know....
- USING CHIPPED P28 WITH STOCK B18C MANIFOLD??????
- Generic coilovers...any good ones out there?
