View Full Version : Honda Civic / Del Sol (1992 - 2000)
- oil pressure problem
- vtec not engaging, not throwing any vtec cel's
- Fitting in B18C1 cylinder head, got a quick question
- Can you name these Alternators? 4 random ones I need help identifying
- question about catalytic converter
- gsr head on a b18b ls block?
- VTEC Pressure Switch
- No cat- still loud?
- Ingalls front A arms bushings shot...
- how to tint tail lights??
- NEED HELP ASAP! TAILLIGHTS!
- Apexi safc2 Base setup??
- power window help
- HID Help. What Bulb?
- Vin plate on dash
- 96 civic ex with idle surge at 15200 rpm
- fuses
- fuses
- fuses
- fuses
- Catback the same for DX and EX?
- fuses
- Disable Speed Limit
- duplicolor vinyl and fabric ( good product ? )
- Help?! stripped headbolt :-(
- Bought a 97 civic coupe...lost keys... now what ?
- Motor starts to stutter.
- blinker question
- brake master cyclinder or boost go bad?
- gsr brakes
- just got it!!
- WTB: Del Sol Drivers Door
- Brake line issue....please help
- Clutch Fork
- Brake Light Problem
- Integra Rear Seats? Do they fit? (EM1)
- took of my instrument panel and found something,i would like to know what it is
- help with my 2000 dx auto tranny!!!
- 97 Civic EX w/ B18b1, have spark, have fuel, only vtec codes, no start, help!!!
- 99-00 civic si (em1) sunroof question
- I need advice with my mini-me project from experienced owners please.
- question regarding ecu's
- need help with a blower motor
- Tranny problem???
- Skunk2 Pro Series S vs. Function & Form Type 1
- WTB: OEM REAR(RED) BUMPER 00 civic si
- Replace the Radiator and thermostat
- Syncros or Clutch?
- Overheating
- hey need a couple questions answerd with my mini me swap please
- 96 AC panel Swap to 99 Model
- quarter panels dents
- Need 99-00 CIVIC SI PART NUMBERS
- H&R lowering springs
- problem with idle
- anyone help we
- Will a vtec throttle body fit on a non vtec intake?
- Suspension is making Sqeaky noise
- whats the best tire out there rihgt now
- I THINK I FOUND A STOLEN PART ON THE craigslist.com (VTI CLUSTER WITH PICS)
- 1997 Honda Civic DX Hatchback
- honda civic 98 hood
- Returning to HT
- Throw out bearing for
- White smoke
- My Turbo Build
- CRX / DelSol wiring loom
- comptech ice box
- Clicking/Squeaking sound from Cyl Head, B18C1... no power under 3k! Valves Unadjusted?
- ek turbo timer
- Problem- Help Request Blown Fuse n.23 Stereo & Brake indicator
- lf:obd1 wiring diagram all wires going into ecu
- b7 intake mani to y8 head
- Oil in Intake Mani?
- please help lack of power..
- sohc d16y8 valve cover
- 2000 Civic Si OEM sway bar interchangeable...
- EK headlight issue
- A New Member Here
- Bad gas?
- removing emission componets?
- Is ek coupe carpet and floor mat size the same as ek hatch?
- Need Help With Cams...
- Help!!! I cant get into my Del Sol's trunk.
- transmission block needle
- My Stock JDM'ish Honda Civic Ex 4Dr 98
- Rear subframe help and questions
- D16A6+D16z6 what cam can i use ?
- 95 coupe A/C question
- Pr3 B16?
- Snail's 00 EM1 TURBO<----------- SLEEPER? (no 56k)
- quick iacv ?
- A little help is needed in getting my swaplist together...
- night shot of ctr cluster
- h22 swap in 95 dx wiring questions
- Question about header fitment?
- JDM EG6 Gauge Cluster wont get any brighter?
- Need help with P0505 code
- ? on cat converter
- code 15 help type r
- running too rich..
- half tinting sol tail lights with film.??
- s2k seats
- short shifter HELP FAST ALREADY APART
- oil pan ?
- 96 ex with h23 blows ELD fuse
- si grill bezel part num?
- cleaning an engine harness..?
- Need New Header... Opinions?
- help..engine code P01117'' low coolant temp inout..
- CANT FIGURE IT OUT!!!! HELP!!!!
- civic doors
- Need help indentifying these Civic parts....
- VTEC SOLENOID GASKET?
- Engine Mounts
- Gas smell in oil
- 92-95 civic door lock
- new engine swap ran for an hour now no fuel and spark
- What is this sensor? d16y7 motor
- Best motor for EG6?
- Wanted: 5 wire wide band Fed o2 sensor for Honda Civic VX
- EG HB exhaust on EK HB??
- Help, wipers?
- 92-95 H22A
- 93 del sol distributor ....which one
- 114.3x4 to 100x4
- DOHC D16ZC head
- Special tool ?????
- HOLY CR@P!!!!!!!!!!! DAMM WAKING UP TO THIS
- Swappin a D16A6 ino a 94 civic vx, can i just replace the bare block or do i swap sensors etc ?
- Are all B-Series Rear T-Bracket's all the same?
- STOLEN LAKE BLUFF, IL 92 civic hb blue
- my brakes locked up,, wtf do i do
- turn on heater, get smoke !HELP!
- Vtec Solenoid Ground
- failed car-jack attempt
- EG6/EJ1 window visor install
- Fuel Line Fitting Stripped ... Help?
- Best JDM Source?
- vtec ? help help
- quick exhaust question.
- clankity clunk noise coming from....somewhere
- radiator swap for b series swap
- lookin for an EG help!!!
- New motor won't crank. Timing?
- WTB: Driver side motor mount for a "94" Civic coupe EX...
- Spark plug wires
- What front sway bar to use with h22 ek?
- why would a d15b7 do this?
- POST YOUR 4 DOOR
- timing belt/water pumb question???
- OBD2a CEL problems after conversion..Help please
- tuner in San Diego area
- need help 93 civic hatch with h22a swap
- Extending wires....???
- need sum help with vitara pistons
- main relay tripping!!!??????help asap
- WHATS UP BRA!
- Hard start only after re-fuel? (B16A3 2000 EX)
- removing the cruise control on my em1
- cvic ek eg em spring on drpzone struts ???
- 1993 Civic EX - Rough Idle, Hiccups between gears.
- help car wont move
- Iso :: EG6 Hood + Fender Cash on Hand
- CIVIC NOT GETTING FUEL
- Was a power antenna an option for the Del Sol's?
- b16a3 into 00' civic ex (searched)
- Few questions, 95 civic coupe
- Is this the right car for me?
- 94 civic sedan help
- d15b3 mechanical fuel pump
- "Popping" when I turn into park...
- Del Sol Pic Thread?
- problems with my brakes on 99 si
- suggestions on ls turbo setup plz....
- cant get bulb out of headlight 96 hatch
- 1992 Honda Civic Jdm H22a - $3700 firm --Murfreesboro Tennessee--
- Car won't stay alive
- quick dashboard question
- nology external coil + profire icm q's
- RHD EK Dash wiring?
- VTEC NEED HELP NOT ENGAGING D15Z1
- Buying a civic shell!!
- Question about turbo
- Help
- TigerJapanese selling B18C Turbo engines?
- Change Wheel Stud?
- turbo tunner????????please help??????????gettn tuned tomorrow???????
- quick suspension question
- transmission fluid
- i need some opinions on which one to build...
- CarStuff.com
- H22a OBD1 in my.............
- b-series vs d-series shift linkage, what are the differences?
- 5spd Swap. Cable clutch or Hydralic.
- H.I.D messing up my Radio??
- IACV (idle Air Control Valve on my B18)
- i need ls swap guide for a 95 dx hatch
- B20b with ls head.
- OBD Questions = 93 obd0 b18a1 into a '00 obd2b civic dx. searched.
- charcoal canister routing OBD1
- Looking for an AEM V2 Air Induction System........
- timing help
- My new exhaust choice...what ya think
- I NEED TO KNOW ASAP,
- Any way to tell if a motor is good/bad off the car?
- Lsvtec with mild built and losing oil??
- can anyone help out with color code??
- IAT SENSOR on JDM B18C type r motor on 93 Del Sol CEL Code 10
- help with emission on a 1990 civic hb w/ d15b vtec
- will this fit on my car?
- b16a swap HELP
- which is correct way for cross drill slotted rotors?
- Exhaust question.
- my car screeches wen i start it
- anybody have a VTEC model sol? if so what kind of intake?
- Few honda questions, please look !
- my car died on the interstate
- anyone running 2.5" catback on a d16z6?
- D16A6 and D16Z6 what were your out comes ? anybody done the swap ??
- Hatch rear bumper fit on coupes?
- 99-00 civic intake on 94 del sol???
- VIR + tire wall + 50$ paint job = I'm going to SEMA!
- rebuilding P.S gearbox
- EP3 Recaro seat questions
- need some help with screeching noise
- Another z6 misfiring question
- dimensions of 96 hatch?
- does aem make short ram for b16 sol?
- need advise asap good deal or no???
- H22-del sol swap
- Brake Swap 94 EX Sedan w/ ABS to 94 DX Coupe
- anybody have an aem short ram on their delsol?
- HELP!
- 00civic radio bezel
- need help with smoging a 94 DOHC del sol
- Speedometer doesn't work please help
- d16y7 running rich and sputtering
- Redline problem B16A(Sir2)?????????
- Radio swap question
- how much is a rear windoshield wiper motor?
- i need a short throttle cable. 97 hatch
- master cylinder or brake booster?
- losing compression
- Innovative 96-00 Civic Driver's Side Replacement Mount Question...
- still surgeing
- ? about block off plugs
- need help with power loss
- obd2 ecu in a 94 civic
- Debating on which quick release
