View Full Version : Honda Civic / Del Sol (1992 - 2000)
- leaking head gasket
- 94 civic steering wheel shake?
- Would the passenger airbag from an EG EX Sedan fit an EG EX Coupe?
- 96 Civic EX/00 D16Y8 swap - reverse lights, O2 sensor, and EVAP canister problems
- Another B-Series Clutch, Pressure Plate, Or Flywheel Problem
- what rear seats fit into 96-00 ek hatch? DC (2dr's?)
- 92 Civic w/ carb engine - Done with this engine
- CEL pops up during high rev
- should i buy? 98 ex civic coupe
- Steering wheel wont adjust
- 2000 civic si head gasket leak, help!
- Ek hatch questions (hatch leak, rpm needle)
- hatch interior question?
- Burning oil -- repair or replace?
- 94 civic coupe/Ls swap with boost -- Broken axles
- Crower & Supertech
- My first eg build kind of ghetto because im 16 without a job!
- possibly buying a civic with CEL on....
- Are all 96-00 Civic Speedometers off?
- JE piston chipped.
- b18b auto vss into gsr 5spd????
- how to wire in aem uego wideband
- help getting 95 del sol running
- exhaust test pipe
- 2000 civic power steering noise twitchy wheel at cold start
- 92-95 civic door questions
- Possible bad CV Axles question..
- Help with D to B motor swap
- Squeaky suspension
- 96-98 Civic Radio Question
- 5w20 vs 5w30.... (no oil arguments) Just oil weight talk!
- Rust (Honda cancer) woes
- Will ek coupe D16 vtec cluster fit into ek hatch D15 sohc eco?
- Dim Taillight
- 95 civic ex -- need input on engine swap
- Window problem help please
- extended lower ball joints with stock height
- Shredded Timing Belt-Anyone else seen this/dealt with it?
- creaking sound on left and right turn on civic
- newly acquired cgp ej8- power mirror/window help
- Please help! My eg does not run right!
- Clunking Noise
- sohc ZC vtec oil leaking near block stamp
- need help with replacing axle
- 2000 honda civic wont start.
- intake questions
- Mission Impossible; getting USDM corners in The Netherlands
- running to rich
- 98 Civic/d16y7 manual - not starting, pump primes, but no spark
- Camshaft slipped on sprocket
- 1993 Honda Civic Auto Rough start, stalls
- Possible to fit 235/40-r17 on a EK
- 93 Del Sol/d15b7 block/d15z1 head -- bogging out at 4k
- [HOW-TO]Spoon Twin Block Caliper Install on 4x100 with 10" Stock Brakes
- Aftermarket Clutches
- D15B Block/ D16Y8 Head Mini-Me Timing help
- question about the stainless steel clutch line designed
- Changed cam seals. Now car won't start
- 96 EK turbo and A/C?
- any 99-00 si owners have a picture of their clutch lines? please help!
- 1994 Civic, ran fine and now won't start
- D16z6 swap into cx hatch
- Thermostat installation
- D16Y8 swap to B16
- whos running stainless brake lines?
- Whining noise when pressing gas pedal
- EK wheel fitment probable issues?
- 97 civic - power windows don't work
- how to hold cam gears while timing
- ek/b16 swap - What exhaust?
- How would you fix this broken fuel gauge?
- O2 Sensors Difference?
- Civic Si Motor Moubt Bolts
- How should i mount an eg chargespeed lip?
- Rough Idle from driving up a hill
- Is my brake switch bad? 93 DX
- Need help auto to manual d16y8 harness on obd2a b16
- What e brake cable will fit my eg hatch?
- 1999 EX Civic Codes: P0505, P1508, P0117, and P0118
- Aftermarket exhaust - Paying for the name?
- y8 block z6 head swap no start
- need power wire help
- EK Swap- Motor mount question
- CEL code 8 TDC Help
- Question concerning steering column swap
- 92 Civic w/ carb engine hesitates/misfires?
- 93 Civic Comnputer Woes
- cold engine squeal?
- wierd flywheel/starter problems help
- having trouble installing b16a trans wont slide into place
- Stories With Ethaniscools EK sedan.
- Need help with what VSS to buy
- abs light on 95 civic
- ek coupe engine swap help
- Feeler gauger recommended based on your experience?
- Extremely heavy steering; just swapped to manual rack
- engine check light on
- help with obd2 si swap into eg mount probs.
- ek hatch swap and suspension questions
- failed smog:HC (ppm) too high at idle
- is this a bad main relay?
- upside down si lights?
- Stripped Tranny Bolts
- Which to twist for an o2 sensor
- Will 18's fit on my EG?
- gsr motor in 97 ek..idling 1500?
- Help with ej1 cluster lights needed!
- My EK hatch thread Paint color suggestions?
- FLCA replacement - I'm stuck
- New to HT
- Wheel wobbles at all speeds
- B16 transmission question
- Want to buy a Honda, what should I get?
- Fix or Swap?
- Can I bypass the ac unit under dash?
- issues with 93 to 98 b18 swap
- 1998 Civic Wiper Linkage - Motor arm broken, but what specific part do I need?
- Help dont wont open
- 00 Civic - humming noise that goes away when turning left (new wheel bearings)
- Teg cluster in ej6 not working
- Z6 w/ d15b head running problems. PLEASE HELP
- diamond wheels
- d15b7 powerloss/bogging + starting up & immediately dying?
- J cloth instead of air filter?????
- EG4 idle problem
- 93 civic low idle after ecu swap
- blew my engine. some help
- 95 Civic D16Y8 behind crank pulley and drain plug leaking. Oil little bit above max.
- Dome light stays on after doors are shut
- Y8 block vs Z6?
- Stock b16a mpg?
- Axles for h22a for my EG
- Tire size help
- VSM 99 COUPE BUILD/PROJECT
- Difference between a Euro Spec VTEC Honda Civic and an American VTEC Honda Civic?
- D16Y7 "uncommon" idle problem...
- Locating my IAT sensor JDM b16a
- 2000 Honda Civic Lx wont turn over...PLZ HELP!
- Fan Toggle Switch
- Gauges stay illuminated when car is off!
- Both Radiator Fan and A/C Condensor Fan stopped functioning?
- Synthetic 10w/40 okay to use in 1998 Civic EX ?
- dc knuckle on ek?
- Clicking/popping uunder drivers side slow right turns! 99 SiR HELP!!
- BLACKWORKS CAM GEARS
- 1993 Civic DX How do I remove the automatic shift cable?
- Fix or start fresh?
- am in Okinawa anybody wants anything
- Automatic to CVT conversion
- d16y7 rpm question
- Honda civic dx 99-00 spoiler clip HELP
- 2000 civic charging system
- hose identify
- 4 door inspiration
- Clutch went out, looking for help.
- how to remove layers off house paintoff your car!!
- B series shift linkage
- Need help installing 2000 hx civic injen cold air intake
- 00 Civic - P0141
- 96 Honda civic tachometer questions
- ej1 wnt turn on?
- 93 DX - better mpg with CAI or stock intake
- Windshield glass for a 96 cx hatch?
- b16 into my EG hatch - What motor mounts?
- electrical. won't fire solenoid (rad fan turn on) push start works sometimes
- Rear drum brake replacement - How do you guys deal with the top return spring?
- 93 Del Sol Engine/Tranny - trying to get everything back to OEM
- EG what connector is this behind glove box
- 00 civic won't start after auto to manual tranny swap
- Civic 1992 double wishbone suspension?
- 92 Civic/GSR swap won't start - main relay problem?
- Magnaflow Exhaust for Del Sol?
- Transmission Problem with my 96 Civic
- 1995 civic failing emissions
- ek hatch rear trunk - question about removing something to install sub
- Wont pass 3k rpm
- Swap stock OBD1 b16a Sir2 into 00 Civic?
- Broken d16y5 valve cover bolts, how do i get them out?
- 97 Hx harness wiring to b16a2 for P2T ECU
- 94 Coupe/GSR swap - horrible gas mileage and cracked distributor cap
- 92 civic dash lights not working
- 92 Dx hatch Gas leak
- Honda civic 1998 lx Shuts off
- oem steelies size questions
- 1992 Civic Si G-machine (SCCA Solo STC Build)
- Cant find this leak in my boot!
- can i use a wire harness out of a A/T?????
- Girlfriend wrecked car, Back right suspension
- Sleeved BLOCK HELPP
- 93 Coupe w/B16a2 swap injector has no ground/won't pulse
- Power steering help
- obd1 with p28
- how do you remove oil level pipe
- EM1 front LCAs on 2K Civic DX
- 1.5 sohc vtec economy?
- Check Engine Light On
- 92-95 eg chargespeed replica vendors??
- no break lights
- Hazard Lights No Longer Functioning
- Clunking/Rattling from driver side rear
- Found a *New* Way to Install LEDs in your 96-00 Civic Cluster
- My first real mod...EX cluster swap into my DX
- 97 lx auto trans slipping?
- Installed ac condenser fan not working.
- z6 head on y8 block in 99-00 ek help!
- 92 Honda Civic Hatchback Headlights,
- Please help with rattling noise
- looking for 14'' steelies for a 1997 civic ex-Orange County CA
- Whats the best ECU to tune ?
- Problems with instaling sway bar on Civic Cx
- 97 Civic EX starts and dies
- Tranny problem..
- Did eg Si's EVER come standard with power windows or power door locks?
- spark plug gap?
- D16y8 swap
- Misfire - no acceleration
- Ruel pump relay tuck
- 2000 honda civic speedo wires? help!
- 97 civic auto to manual HELP!
- '92-'00 vs '01-05 motor mounting points
- 92 eg hatch taillight leak
- A/C Receiver/Dryer Replace?
- my 98 civic wont rev past 2500rpms
- 92 civic si b18b1 swap no spark no fuel
- 2000 civic Si horn is crazy?! Non stop!?
- 16z6 cam in a d15b7 ?
- B16A SIR2 P30 94 EG CIVIC - rough idle, backfires, and 3 CEL codes
- (B.A.R) b16a2 in 95 ex sedan
- JDM B16a Wiring Questions/Help
- d16z6 - what pistons/rods should i run for the vitara build?
- 97 EK H/B with B18C-R mystery radiator problem
- No heat in my 99 d16y8 please help
- 16x7 Enkei RCT1 4x100 price check?
- 95 Civic D16Y8 cannot add any coolant to reservoir. Is it normal?
- fully synthetic engine oil questions?
- Maybe I'm stupid, but where the hell is the Precision Injector site?
- best ecu for a vtec zc
- Leaky Ek Hatch need advice and info
- type r exhaust.
- 2000 Hatch Mid wing help
- Considering Purchase
- 97 Civic HX - b18 or b16 swap?
- Strongest d-series engine?
- Rear heat shield (behind manifold) on 93 Civic DX?
- 99 Lx rear sway bar
- $For Sale/Want to Buy$ - 92-00 Civic/Del Sol Parts Only (NO COMMENTS ALLOWED)
- ARP Wheel studs?
- Purple color code
- b16 high mileage oil preferrences
- 98 civic dx crankshaft postion sensor
