View Full Version : Honda Civic / Del Sol (1992 - 2000)
- suggestion on exhaust
- knock sencor problem on my ej swap
- camshaft Q
- Megan Racing Spring
- what should i do with my Ek hatch
- 98 Civic AT Transmission question
- CAI vs short ram!!!! need some expert advice
- i need some help
- b20v eg skunk2 cam question
- Blown Motor pics
- Motor Swap w/ AC on 93 hatch????
- JCS throttle cable
- CEL 72, 73 , 74
- Question regarding pistons/rod/crank bearing clearance. Rebuild questions.
- Exhaust question, URGENT!
- cylinder #4 mis-fire from hell
- ground control top hats
- quick gsr into eg swap wiring question
- dc header
- CRX / Del Sol rev counter / tacho
- E.C.U. for my Vtec-e HX
- Tranny problems?
- Noobie at its best
- B16 swap question
- advice on buying this civic or not
- Eg brakes question
- need suggestions on what kind of civic to get
- Please help me find this cover
- Upper Ball Joint
- help!!! car pulls to left when i hit the gas
- Do I need to remove dash to remove evaporator or exp. valve
- broil water from reservoir?
- removing dash for paint prep, Q(srs)
- PROJECT: 92 Honda Civic VX Build... till whenever I'm done.
- Friend is trying to sell me a Car
- JDM B16A2 OBD1 sawp into 97 Civic EX(D16Y8) major problems!!!! HELP!!!
- 92 Z6 wont start
- radiator question
- GSR Swap in EK (Question-Searched)
- magnaflow too damn loud
- Properly Flushing the Brake System
- just got a type r, with k20?
- weird ignition problem
- cant find this write up....
- what is a spoon sports header worth??
- '98 civic turns over but won't start
- What Lip for 96 Del Sol??????
- getting reado to turbo my SOHC need a little info
- which eg civic engine is good on gas
- does 92-95 civic sedan comes with air bag etc
- crx seats in eg will it work
- whats the differences between the body of 92-95 civic sedan
- getting my trans rebuilt... price???
- hooking up hids
- 94 del sol middle lenses
- civic si cluster question
- Real deal jdm stanley headlughts eg6
- strech tires on an ek questions
- Quiet Type RS BOV
- B17 rod bearings?
- 02 sensor question!!
- Knock on cold start, goes away for the rest of the day?
- Can someone please tell me what obd1 means? (and other engine swap questions)
- 92 civic wont start in the morning or hot/cold weather!!
- exhaust mounting help!!!!!!
- Most Desirable 5-lug Swap??
- could it be the starter or ignition switch?? help!
- Exhaust temperatures?
- Glass fibre hood / trunk to del sol
- Car dies and wont start, but starts right up the next day???
- how low is to low
- y7/y8 distributor difference
- Oyxygen sensor questions
- Difference in RHD headlights?
- a/c compressor
- i need to fix this quick...
- Will 96-98 Hood Seal fit 99 00 (for 3dr)?
- noob with drivetrain prob
- engine swap
- Im Painting my 4dr civc. any suggestions?
- car wont start
- doesnt overheat when idles but overheats after on the road?
- Paint Codes
- ok so i bent a rod.
- Front End Problems
- '92 Si w/B16 needs sway bar advise
- How can i tell if the head is a Y8?
- 95 civic disc brake swap
- 95 civic muffler
- Overheating issues
- 97 honda civic suspension
- 98 ex auto trans issues
- DC B Series wiring into EK?
- Got another hatch WOOOOOOT
- Power locks/Alarm system into 98 Civic DX Sedan
- ej1 turbo advice
- power steering delete
- b16 combination
- ► How to use Honda-Tech Search engine
- 99-00 si oem rear lip
- 96 Civic HX w/ Invidia Exhaust Question
- HELP: How to: 99-00 Climate Control Brezel to 96-98
- Will a y8 block work
- Just bought an AEM cold intake what is the HOLE for??
- JDM EG DRIVER SIDE CORNER LIGHT
- H.I.D. ballast location?
- how much 99 ex/b16?
- bouncing rpms?
- b20b swap help please i just want it in!
- Honda Civic Fog lights
- B16 Rod Help Please
- Uberdata vs Hondata???
- exhaust bolts(springs)
- HELP.. How Or Where To Check If Motor Is Stolen Or Not
- 2000 SI with OBD2A B18C swap
- 98 civic..windshield wiper problem
- Need Engine Build Advice!
- d 16 block swap.
- engine tapping and bad idle
- need help guys
- D16z crank leak?
- b16 intake size
- How to install door window ( Manual Window)
- sensor question !!!
- 6-point roll cage in ek question
- so damn mad with o2 sensors
- B20 swap help!!
- need help with my d16z6 jrsc setup
- Phil's 98 Coupe Build
- changing the Cat Converter
- swap help
- P0302 - Misfire on 2. Car missing and CEL flashing
- how many quarts of paint....
- Idle Problem?
- best pistons for a turbo b16??
- Can someone please run a vin#
- 98 Civic EX
- Does a 92-95 hatchback or coupe headliner fit a sedan?
- superchager question
- oil light comes on at very low idle <--- Is it a bad pump
- cx vs si prop. valve?
- Dream Build
- bleeding clutch????? help guys
- Redline at low RPM.
- o2 sensor help plz
- F20b into EK help?
- B20 help
- d15 block with d16 head
- b16 idle problems
- Cam holders
- Del Sol ls/vtec idle problems
- DC4/DC2 dash into an EG?
- removal of head, crankshaft, camshaft
- IACV 3 WIRE TO 2 WIRE NOT WORKING
- New to Hondas & have a problem
- how to prep my car for smog with mini me
- HELP! Which alternator will work for me?
- CEL in '00 Si, best way to go?
- A/C belt too tight maybe?
- to anyone having trouble with emissions (HC or CO)
- Questions on Swaps.
- RHD CLIP?
- Vtec still not working.
- Clutch job gone bad?
- 96' civic ex cooling hose diagrams
- ls/vtec and a lightweight, red, rim?
- need help on a d16z6
- High idle after TB clean up.
- ultra racing strut bars for eg
- Cops searching under your hood
- FPR help.
- AEM Intake + front strut tower bar problem
- piston chooses???
- need blow off valve help
- Help with my 96 hatch!
- Help!!!! 98 HX 02 sensor????
- Si cluster in 98 ek. Speedo is off???
- 195/60/15 on eg?
- air condtion 97 civic
- 95 eg rear suspension?
- red ek with bronze gt-3's or dr-16's
- leight weight flywheel ? or not
- HELP turning JDM Odometer back
- [HELP!] '98 Civic, stalled, now won't start!
- Re-doing my suspension setup --- far too bouncy
- d16 header help!!?
- need input on cel p1399
- Which Motor?
- spoon mirrors/
- Replica vs Real Spoon exhaust
- How much can i sell my '00 EX coupe for?
- Auto to Manual Tranny Conversion
- EK driver window regulator. HELPP!!
- ► EG B20 swap: non-typical questions
- b16a bent valve??? help
- 95 Civic A/C fit 00 w/ B-series Civic???
- What if you break something during a test drive?
- 1995 civic si steering issue
- Any worthwhile mods for 06 HX coupe?
- Skunk 2 camber kit?
- Door getting stuck because of the gasket. What should I put on it?
- Its not the ECU, main relay, fuse, distributor or fuel pump....what is it?
- alternator
- rear brake lights wont turn on
- Car Wont Start: Alarm Issue??
- 99 Honda Civic EX A/C Desperate..
- 3 wire to 2 wire iacv problem, cel p1509
- Looking to lower my 99 SI ?
- Need z6 help
- exhaust ?
- Fuel pressure regulator
- Do Quick-Release steering wheel hubs work on OEM steering wheels...???
- Distributor Question
- i have a short somewhere and cant find it
- want to know if gsr pistons will fit on hbeam rods
- ticking noise??
- what type of grease for oil seals??
- civic del sol exhaust question.
- HELP!!! piston has me stumped
- quick mini me questions
- D series Turbo
- 99 ek si door into a 96 ex chasis
- Lowering my del sol the right way
- How to adjust tranmission cable on civic?
- Just traded up for an EK w/ B16A
- I Need Motor Help! D15B8
- custom interior??!?!?
- [FAQ] LS/Vtec, The Truth behind the power
- d16y7 in a 95 civic lx
- !!!!!!!!!!!URGENT!!!!!!!!!!! Need to know what axle to buy!
- 5th gen hatch vs. 6th gen hatch
- 97 honda civic with jdm h22 won't start after it shut off
- D series Valve replacement
- Need some HELP w/ EG6 JDM CLuster
- Project Daily Driver: ( Ek hatch) Climate control swap, black interior/headlights
- Is this what a new clutch is suppose to look like.
- rpm signal
- iab wiring
- ***DSM 440cc injector question***
- Will an 06 Si coupe axleback fit 96-00 civic coupe
- b20 vtec/or ls vtec? which one should i build?
- Zero Clutch Pedal Pressure?
- shocks..
- 2000 EM1: Rebuild the b16a2 or go JDM b18c-r
- 95 civic b18 transmission
- ek harnes question
- Will invidia test pipe mate up to SR*S catback exhaust?
- Replica Spoon N1 Test (JDM Sh!t)
- majestic honda!
- New Engine, Turns over but just backfires
