- Stock Springs
- my civic vs. his civic (not a kill story)
- jdm apexi n1 catback
- del sol front conversion
- help -94 dx hatch- help
- Boosted LS block. How much boost can it hold SAFE?
- Integra Type-r seats in a 94 coupe
- JDM gen2 b16 cam plug
- change ignition rotor
- Clutch rebuild question
- what exactly does a main relay do?
- Pulling to left- Caster is off.. adjustment?
- 99-00 civic ex/si tweeter question?????
- EUDM EG6 power steering pump [need help]
- OEM DC Steering Wheel Fit In a EG???????
- omnipower bushings ?
- distributor question
- permission
- Help: Putting a 97 GSR complete motor into 97' EK civic/IAB Sensor addition
- Wingswest skirts install on a hatch. (92-95) Question????
- What can i do about the O2 code i keep getting. Please make it stop.
- todays search for a type r
- For Sale JDM 96-00 Civic steering console with ignition light and light below
- picked up my motor
- Finishing up my swap.............56K?
- my smog test results
- i hear the sound of air releasing from my car
- my "pop the Hood handle"
- Tail light Glitch
- Car losing power?
- GETTIN Alignment done HELP!!!
- Illegal Window Tint???
- O2 sensor CEL
- stock exhaust system
- help plz....gray smoke comin out of exhuast!!
- side mirrors question for ek
- Headlight help?
- aftermarket cat
- I need some serious help.....FAST!!!!!
- Bad starter
- Cat question!
- b18a
- Gauge Lights Still Won't Turn On!!! Integra dash.
- cat- back question
- to go straight must turn steering wheel slightly to the right
- ASAP HELP PLZ
- aebs intake manifold worth it?
- pics of srr or beaks lca's and aftermarket rear sway bar???
- Torn between 99 civic and 06 civic
- Flat tow 98 civic?
- edelbrock performer x on 16y8
- '95 gsr motor into a '95 hatchback cx
- brake light problems
- Tanabe Ultra Medallion???
- 99-00 Ek Fogs on Eg?
- just swapped gsr.. smokes bad
- Fuel pump with out high pro. injectors
- PR3 Piston Questions
- on totaljdm.....
- Vtec Solenoids the Same ? ? ? Will my VX Vtec E Solenoid work with a Z6 or Y8
- 1996 gs-r motor swap into 1994 dx hatch
- Can anyone swap my eg from auto to stick in ny?
- H22 HELP..NEED HELP!!!
- d16z6 vs. d16a
- compresion
- lights dimming
- Type R in an EG
- o2 sensor
- what other civic caliper/knuckle/hub assembly is the same as a 92 vx hatch??
- jdm oem or skunk 2
- Eg swap?
- can a z6 IM work a y7 block?
- d series turbo manifold??
- Does a 92 civic hatch vx front right caliper match a 92 ex??
- grill...
- F*cked up my stereo, I think, HELP!!!
- best place to buy eg hatch aftermarket fenders....
- Changed spark plugs now car won't start.
- Whats a cylinder sensor?
- taillight
- del sol seats
- have no idea what i did now
- Help! My new Skunk2 catback exhaust rattles.
- Issues when starting car after obd2->obd1 conversion
- skunk2 vs... A'PEXi N1 exhausts
- Wiring 97 dx to a 99-00 ex ecu, possible?
- Header won't bolt up to magnaflow cat. help!
- Would you buy this exhaust for 145 shipped? Its Airmass by Holley.
- question about antilock brakes on my swapped civic
- Vouch Thread TurboHatch00
- Great site for ECU PINOUTS
- Mirror block off plate
- 98 hatch broken rod or what
- ANYONE EVER DELT WITH THIS GUY??
- before i start modding......
- Installing new gauge faces DIY?
- firing order
- difference
- b16 turbo- air conditioning
- GSR seats in a del Sol...
- 1994 Civic DX FOR SALE!!!
- Whats my problem here?
- looking for a civic HB
- short shifter-synchros?
- FREE D16Z6
- on going idle prob!!!! help
- molding door panels in an eg
- ES tuning oval exhaust.. ANY Good?
- catalytic convertor ???
- What head is the Pr3-4??
- anyone done a head gasket please help
- wheel hop kills radio?????????youve gotta read this
- Dangerous question?
- help on ek civic
- I got 94 civic lx 4dr with a automatic b16.....
- Sparco seat with stock seatbelt?
- VTEC problems
- JDM SOHC Vtec motor question
- cf bumper and hood
- del sol seats
- quiet / loud performance exhaust
- Bride seats............replicas
- GSR eG twin turbo
- Too many options
- getting car towed here to AZ
- WTB: Stock OEM Passenger Side Del Sol Headlight and Corner Light..
- Monza Cat-Back Exhaust
- i need help with my d15b 94 hatch
- Sorry im new at this but i have to ask Ek cluster
- ECU Code Help...
- Front and Rear Lip install question?
- WTB DEL SOL SI (LA AREA) ANYONE???HELP ME OUT
- which halogens?
- crazy ass short
- Landspeed Racing
- header question
- problems with k20a2 into eg
- modified integra panel for eg??
- Quick help needed - Changing axle + oil seal
- rev limiter
- who sells uberdata?
- New here from UK
- VTEC kick point
- Can someone find this part # for me?
- 88 civicf 1.6 block w/ d16z6 head and ecu?? will it work
- how much would you pay for a b16 hatch
- Help i cant figure out what code this is (code infinity)
- anyone know a honda site to show pictures & diagrams?
- Stock Horsepower on a 96 civic ex
- Passing emissions with obd1 in an obd2 car Washington
- Problem with my 02 sensors and ECU. Not sure what to do to fix it.
- 450 cc dsm injectors
- si cluster in auto dx?
- A/C removal questions
- Fender fitment? 92-95 civic
- can vtec stay on all the time if i hook it to a flip switch
- eg sway bar
- eg civic radiator caps also fit????
- Rear ended?
- DEL SOL REAR LIP ? ? ?
- Which E-brake cable??
- SRS light after aftermarket steering wheel install.
- humping and bumping when start moving
- air bleed bolt for d16z6?
- Need some help with my EG.
- virgin p28 ecu OK for B18b engine??
- 2000 D16Y8 into 1999 Civic DX
- DC2 Gauge Cluster...help
- will a 4dr jdm itr exhaust fit on a 2dr EK? mind you, with a jdm itr cat and jdm header.
- Front swaybar install for 98 hatch???
- Intake for 1996-2000
- yellow healights really legal?
- spun bearing...what do you replace?
- New Arizona HT Member. HIYA! Pics Inside.
- 4DR VS. COUPE FRONT BUMPER
- Faulty ECU? Bad Burn? HELP ASAP
- mini me on a HX block???
- intake decision?
- fuel pump and BAR ?
- will vtec work on minime swap if i use the 91 si distributor
- CYP Sensor (Code 9) AGAIN!!! HELP!!
- wrong about tps
- Should i get an ecu chip for my obd0 crx with a d16y8
- need help with new coilover kit
- Question
- sway bars
- fixing mounts,help
- Registering a swapped motor
- motor choice?
- Are these normal O2 test results and am i wiring it up right?
- Question about synthetic oil
- 1993 Ls
- dead car: replaced battery and starter but no luck
- Need Help Identifying This Hose/Part. Need Part Number
- Hondata Chipping question...
- Clutch Problem... I think.
- Code 41 problem
- My new $500 del sol ......................Now What
- Help me with steering wheel.
- where can i get some nice 17 inch rims from for pretty cheap
- anyone have a link or diy on how to put a gsr cluster into an eg?
- will shocks from a 91 civic sedan fit a 93 ex coupe?
- depo foglight installation manual
- getting wheels tomorrow, what size tires?
- Mini Me/Head Swap Help
- Thermal R&D stealth vs Greddy sp2
- quick question
- d15b7 timing belt changed Big power loss.
- will springs from a 91 civic sedan fit a 93 ex coupe?
- rsx steering wheel in a del sol?
- Del Sol Headlight Conversion
- compression and leakdown test results
- Vtech won't engage on 95 EX coupe
- 99-00 Civic SI Dash+Door panels in EG Hatch????
- New Here!! Trouble starting 1993 Honda Civic EX
- I got a GSR CIVIC also new to this site
- Thanks to H/T members
- exaust fitment question
- eg swap question
- Valve cover breather
- B series High Performance ignition systems!!!
- ebay steering wheel setup... anyone have experience with those? please post
- can anyone tell me what clutch this is
- Comp Cams 59300
- any recent dealings with Osaka?
- Suspension Help
- +_+========starter bolt fell in Transmission
- GSR brake conversion parts for EG coupe
- power steering
- Routine Maintenence General Questions for a 1993 DX Coupe
- JDM DEL SOL INTERIOR
- its probably been repeated... but..
- swap question, help
- front bumber
- need help with a fuse box diagram ASAP!!!!!!!!!!!!!!!!
- Please help me with swap of a GSR into an EK. ***Searched***
- need an eprom burned
- starter
- 92 DX Sedan axle help
- FS: eg cargo hatch
- Does 94+ integra cluster direct fit for EK?? PLUG AND PLAY???
- Dented my oil pan, is this near the pickup? (PICS)
- engine upgrade
- stock redline for 1995 obd1 b16
- New engine and I'm burning through Cats!
- B16-T or LS-T
- New Deck, but Stock Speakers
- 95 EX axle for manual & auto the same?
- Is this a good deal?
- D16Z6 Head/Swap Question
