View Full Version : Honda Civic / Del Sol (1992 - 2000)
- water pump
- itr swap in EK now, axle problem!
- what year si was this engine from.
- How much does a z6 tranny weigh?
- What INTAKE for a 96-98 Civic DX? Or does any intake fit?
- Prepping for rear main seal replacement
- I/H/E cause major lean condition?
- B16 swap soon
- my b16 is killing catatylic converters
- Buddy Club spec 4 or Skunk2 stg 2 ? Which 1 is better?
- igniter swap
- A car with no keys....
- Running a cracked exhaust manifold
- New engine
- video
- Whats a good source for EDM parts?
- 92 dx hatch/ ls turbo in va!!!
- LEGAL OR NOT
- Ic pipping question
- Motor lag
- civic ex wiring harness
- DEL SOl......
- plug wire causing bad mpg?
- del sol problems, owners check in.....
- I JUST Got a Honda Civic. Need some answers. Im a real Car Newbie! Please help me out!
- Tokico Blues??? Opinions
- Car misses after vtec engages?????
- jdm d15b header question, searched
- Ek is lagging bad.. help me out
- 96 coupe
- Recaro XL bucket seat
- S2k suspension on a civic?
- Tranny Oil Fins??
- gears popping out...
- Anyone done this=jdm b16a2 head/b18b bloc?
- Question about 96-00 Civic Ignition cylinder compatibility between different model Civics.
- solid cel, maybe bad distributor?
- what wire on ecu for o2 sensor gauge delsol
- MSD 6AL Questions
- 94 VX Block 94 EX head Base Timing Issues.Any Suggestions?
- how long could an b18a ls vtec last
- loosing water
- loosing oil
- can the rear lca bushings be pushed out and replaced?
- New to this, any opinions help out...
- EK SPOILER
- what cams should i use
- auto to manual swap 99 civic EX
- Traction bars for the 99-00 Civic Si
- best fitment timing belt for ls vtec
- Access
- nos for 00 si small shot
- how to rewire obd1 alternator to obd2????
- B20vtec Problem? WAt Timing Belt/Wat Water Pump?
- For the Cooling Experts...
- Gas
- How would i Fit Coupe seats in my 4d
- Nology Ground Strap Install
- Abnormal startup after battery died. help?
- Engine acting up again
- New b16 Swap Tranny Problems
- Quick Question need answer asap: What bulb is in TYC 92-95 one piece projectors? Is it H1
- eg springs vs SiR springs
- New Bushings Help
- didnt i see a thread for EG console?
- are my head bolts reusable?
- K20A/K20A2 Swap in 1997 Hatchback
- Helping a freind out
- headlight burnout
- Another swap question
- only sparks once in awhile. help....
- 99 Hatch GSR swap ???
- what else can i do!!!!!!!!!!!!
- i Need help, MY brother blew up my car???? theives and noobs!!!!!!
- D series skunk 2 manifold?
- A List of Problems
- Simple green
- What's is the idle speed for a stock 93 civic ex?
- is this normal
- HELPPPP, GAPs GAPs GAPs!!!!
- My Civic = totaled by Cavalier last week, would you buy a shell if....
- Such thing as D16B?
- Y8 oil pump problems?
- licence plate on the left hand side of the bumper?
- i need a car fax TONIGHT>>.... willing to pay 5 bucks for one...
- is it worth it?
- Just need an opinon/ B16A2 Turbo or NA Gsr
- b16 b18
- which ECU should i use??? Smart input please
- My 2nd Drop Didnt go so WELL...
- Civic for an Integra
- 92 vs 99 DAMN!
- d16y8 questions....
- Anyone Run Kteller 2.5inch Exhaust Kit with resonator to a 2.5inch ES OVAL?
- auto transmission fluid change
- B16A without vtec!!
- Neuspeed Sport vs. Tein S-tech
- megan 4-1 header
- Looking for Pics, EB 99-00 SI w/ Work Emotion Gunmetal
- mini me swap info
- what rims
- which camber kit should i get first front or rear?
- b16a2 eg swap. What else do I need?
- wtb: single cam hydro tranny so cal
- problems with fuel guage.....help w/ troubleshooting
- ek steering column in eg
- prelude/ accord 5 lug setup
- water pump went
- trans problem?!?! im dumb
- Car Color
- suspension
- Motor Mounts
- 93 SI HB stripped nut in front main crossmember
- confused on code & specs?????
- so has anyone fabbed up 99-00 fogs on their 92-95 hatch/coupe?
- Door Panels
- need help finding a turbo-kit
- 03 Si Springs vs 97 DX Springs
- CTR Climate Control Hookup
- OBDII code P0108 (Help)
- stainless steel brake line coating ?
- B16 BoLt On ?
- think u got a nice swap???? look
- (i've sreached) ek foglight install
- does anyone know if you can buy quarterpanels for an eg hatch?
- anyone have a ecu JDM v-tec for sale D15B
- 92-95 passenger floor all wet after rain? heres directions on how to fix.
- Quick question
- Periodic check engine light, knock sensor
- dumb question but important
- NEED HELP WITH B16A SWAP
- what does a b16 weigh?
- CTR headlights... doh!
- Del Sol Si brake booster question
- AFC?
- $50 all u can carry
- what else do i need?
- Preparing my D16Y8 for Turbo.
- Help ME PLease!!!!!!!!!!!
- Need a driver's side view mirror PRONTO
- cam timing #1 TDC at 4 oclock
- Trunk swap, 97 to 00 Si, Wire troubles
- Just got a turbo kit for 95 EX
- d16z6 turbo ?
- Axel problem
- JDM NAVIGATION INSTALL EK HATCHBACK (pics included)
- d16z6 out and b20 block in HELP
- GSR or CTR
- Exhaust hitting gas tank
- TireRack HT Discount?
- do i need this bracket for my header?
- How to post in the classifieds forum???
- Clutch problems! HELp!
- EK headlight Q
- Will integra springs/shocks/tophats fit 92 Civic Sedan?
- Motor mount bolt question
- whats wrong with my car???
- rattle sound from underneath...
- Is valve clipping really worth the time?
- 3040 proportioning valve.
- h22 in del sol?
- 1998 Civic LX D16Y7 Turbo Help
- type r tranny question...
- Fidanza Short Throw Shifter
- KYB GR-2 ???
- ECU GURUS PLS HELP
- 1997 HX Exhuast
- is there a such thing as a water and oil pump gasket..?
- GSR Cluster In EK
- Installed: 15/16th Master Cylinder on my EJ1 (results)
- will the eg rear strut tower brace fit my ek civic?
- 99 Civic VIS Cf Trunk Fitment??
- Pic Request: Green 92-95 civic with gold/ bronze wheels
- Sticking E-Brake
- GSR CIVIC HB question
- nos for 97 civic ex sohc
- WHEN IS CITY AND WHEN IS HIGHWAY
- Is it okay to remove the head of my engine throughout all winter
- distributor install help
- throttle issue?
- anyone know if the aem hybrid intake cold are or short ram thx
- ECU & Tuning Help
- 1997 civic...keyless with CD player
- Hit a Pothole... need help
- is this an issue: 98 gsr tranny, 98 gsr pass axle, 93 gsr driver axle and halfshaft?
- SI emblem on cluster glow?
- Fuel Pump Relay??
- Need help with EK rear bumper and lip
- VAFC2 problem after install...
- Tranny Problems: (*searched-unsuccessful)
- Speedometer Problems 94 Civic Hatch
- 93 temp gauge problems
- Engine keeps missing???????
- I'll keep all my n00b questions to this one thread, promise
- Codes, Alternating Idle, and Gas Mileage
- resistor box?
- Power Steering Rack - Interchangeability 93 SI HB
- Help w/CEL codes
- What are these sensors? B16A2 OBD1 (pic's)
- h22 runs like shit after nitrous
- EG6 rear diskbrakes on an EJ2
- Wiring schematic?
- Engine Swap help! (02' 1.7 into a 95' DX)
- steering question
- My Ej8 Slowcivic
- CEL ecu code #43 Fuel supply system . . . .anyone know about this?????
- pic request
- zc into eg
- adjustable wheel ?
- CTR Navigation System!!!
- help on TIEN HA's
- vtec question!
- Alot of quick questions..... B18c1 in to 96 EX
- d16a6 vtec good or dad
- battery relocation
- charging system and ignition problems. help me please!!!!!!!!!!!!!!
- tubo gsr or turbo ls
- Last chance for a dying tranny?
- Correct oil for tranny
- civic / accord parts interchange
- 2006 Civic SI seats in an EK
- civic=world class sports car?
- cel code 1 or 10? which o2 sensor to use? obd2 - obd1?
- ECU question, obd2 to obd1
- How much is this car worth?
- 94 Del Sol Specs
- A/C Bracket Question
- VSS Help?
- jdm B16 swap in a 95 civic ex .............
- gsr block/b16 head
- low 13's or 13 flat on civic gsr w/o boost?!?!
- Door lock messup help, help.
- Question about climate control positioning
- shorter shifter, not a short throw shifter?
- thinking of going right hand drive can anyone help me?
- What 3" catbacks are available for my hatch?
- header/cat
- 92-95 civic with nuespeed sports
- DOHC ZC for Sale!!!!
- Red "H" Emblem
- wtb 99-00 si cluster have ?'s
- Flame me.....searched...........still have a question.
- Front Grille
- recent motor swap
- sellin my EG6
- d16z6 to b16a3?
- Balljoint popped out? Why? How to fix it?
- Honda Civic 1999 troubleshooting SRS system
- blinking cel misfire cylinder 3
- What is this worth?
