Some proportioning valve clarifications...
Guys,
I searched and most of the threads I found were a bit confusing and went back and forth about EX/Si/CX/DX brake setups and prop valves.
I have a '93 CX. I already upgraded the front brakes to LS ones. I just picked up a full rear brake swap (trailing arms, calipers, rotors, handbrake line etc) from another Integra LS (I believe a '95) so I can replace the drums with it.
The stock prop valve currently on my hatch is the one with lines coming out diagonally (almost like a star) as opposed to the prop valve that was in the donor LS (it almost looked like an "H", it was more squared).
I have two simple questions:
-Walter
- How do I find out what prop valve I have (is 40/40 or 40/30 stamped somewhere)?
- How do I know for sure whether or not I need another prop valve?
-Walter
Re: Some proportioning valve clarifications...
Kaiba,
I appreciate the time you put into helping me out.
I just realized I described my current prop valve very poorly (I got confused).
Here's a picture I took today of the stock prop valve that is in my Hatch:
...and here's a picture of the prop valve on the Integra where I got the rear disc swap from:
I looked at my prop valve today and couldn't see any marking that specified the type.
Any additional info will be greatly appreciated.
-Walter
-Walter
the second pic u posted from the teg isnt a valve... ls tegs have antilock and dont use a proportioning valve....I think Im right here..
That second pictures is from civic/integra with abs. Like I said you can the 4040 from the integra DA easily.
yes, the "valve" from the 1995 Integra you have came off a car with ABS brakes. That's more or less a union to connect the pieces of lines instead of controlling how much goes to each. The valve you need comes from either a Civic Si, or an Integra with regular brakes. Either 1990-93 Integras have them or 1994-00s. The Integra MUST be non-ABS equipped...not sure which models that was for DAs, but DCs were RS model only.
I have one sitting on my shelf, ready to mail if you're interested. Asking $35 shipped/paypalled.
http://tinypic.com/r/2u7ovg9/7
PM if interested.
PM if interested.
Thanks for the clarification guys.
Yes, now that I look at it again the 2nd pic I posted doesn't look like a valve at all, but more like a "hub" like component.
"NotAJDMFanBoy": Thanks for the offer, let me see if I can find one locally, I'll PM you if I decide to pick yours up.
Regards,
-Walter
Regards,
-Walter
Targa250R
05-24-2007 10:15 AM
StolenTeg
10-02-2006 01:05 PM
boosted_dc2
10-26-2004 06:02 PM
