View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Nice to meet a few of you yesterday....
- Bore & Stroke
- What oil for '97 Del Sol Vti (dohc)..
- experience with engine stands and hondas?
- axel srength question
- Camber Kit advice
- DC header -- ?Cat? -- Apex'i WS....measurements
- 98 civic DX ECU pins
- www.osakajdmmotors.com
- proportioning valve?
- Problem with my Tachometer
- Can Anyone Vouch for Kei-=EK9?
- 3 dolla front lip
- what is the ohms on 96 civic dx injectors?
- When buying an EG
- help on B16A aircon compressor
- Which aftermarket exhaust gives best ground clearence on EGs
- Custom turbo lines/revhard turbo manifold
- Vortechh emergency-Please help!
- Wheel Options.
- who makes lexan windows for a 92-5 hatch <i refuse to say eg>
- will 00 rear disks swap into 93 hatch?
- 99-00 EK/EJ/EM Civic headlight height adjustment?
- grafting front end
- installing spark plug wires
- SRR Lca pics....
- Falken Azenis tire review... Are they good?
- Civic Attack!
- Vtec-E, what exactly is it?
- How many miles on average?...
- EK Spoiler -----Downforce???
- which color wheel?
- Might be a stupid question about ground wires...
- vtec question guys???
- i consider this a decent question...
- Will these tires fit this wheel?
- what motor would you chose??????
- mods for autocrossing?
- twin turbo civic wtf?
- How much do you think I should sell my 1999 si for?
- Turbo Pics
- how do u fit GSR/LS/ITR seats(94+) into a ek hatch?
- bilstein HD VS tokico illuminas
- check out the cop car!!!!!!!!!!!
- ls/vtec
- ECU Qusetion
- dropped some subs on my civic...
- Some Pics of car what do you think?
- Why doe no one help me here EVER?!?!?!??
- for EG which is better B18C5 or B20Vtec?
- Anyone put the gauges in their EG dash? Above the glove box?
- race videos - check em out
- Is this spring compressor suitable for spring replacement? Pic Inside
- new hood for my car
- all DOHC B series owners
- 95 GSR cluster into a 98 Civic DX
- Tow dolly or Tow trailer
- HID Conversion vs High Output Bulbs
- Please help! I have important questions...
- CEL 15?!?!?!
- finally the H22's in!!!
- body kits?
- battery is on its last leg !!!!
- OT: writing essay about my SI...need input
- 97 integra type r comptech header fit on 96 B18B1 ???
- Where can I get some stock/atermarket engine mounts for 95 Civic Ex motor?
- I know this maybe a newbee topic but how...
- RPM tach
- I found a Hatch BUT...
- Does this price sound good?
- kick ass tires???
- What aftermarket air intake to use....
- 98 civic sohc header
- -=-=-=-=-install SI gauges??-=-=-=-=-=
- Pics of Spark Plug Wire Crossing
- One more T&T for us Ohio guys!! Come!
- eg8
- Quick Question
- need help fidning bullfrog head kit???????
- Need Advice on Clutch Prob w/ hatch.....Search did not help 2 much
- cold air intake sizes?
- a few pics of my "hatchie"
- Daily Drivers... what winter setup do you have?
- old exhaust / B18C swap?
- 93 Civic - oil leak
- broken timing belt
- Online Helms?
- Are Si front calipers the same as EX front calipers??
- LSD installation on 99EX
- why wont it let me post in classifieds forum
- Civic LS-T build up
- *** wha is a good free web host to UPLOAD .exe file larger than 2mb
- rear brake swap question
- strut bar installation
- engine swap
- For Sale - 1996 Honda Civic w/ JDM ITR swap
- pics of car after suspension upgrade
- only for b18c1
- What causes positive pressure in my crank case?
- Checked my compression.. doesn't sound right.. did we do it right?
- Radiator Flush
- '92 Civic no spark...help...
- why oh why?
- toda???
- SOHC vtec sound Vs. DOHC Vtec sound
- '91 civic atx, no reverse
- bored...
- deer hit my hatch, got problems
- Need Help!!
- Too wired to go to sleep...so heres a question Id like sum opinions on...
- Need help!! Gas mileage gone to sh1t!
- wow, gotta look at this thing
- Just installed my SRR LCA's [add keywords: lower control arms]
- GSR/EG6 gauge cluster swap
- Taking Eg Euro corners apart to paint, Anyone??
- Anyone have an axle back exhaust system on Eg hatchback?
- Question on Ignition recall for 6th gen Honda civics?
- Eclipse vs Si
- Ground Control question...(sleeve kit)
- H22 EK
- EK Engine Swap
- pix of my vx hatch post some suggestions
- mugen exhaust
- Question about a B16A SiR2 swap...
- nooB from VanCity
- rebuild or new motor
- Suspension Set-up
- fixed my tire rubbing!!!
- Austin, TX ppl, ID siting
- OEM Honda part number search
- suns automobile "hyper ground" earthing system
- Gorilla torque wrench and power wrench set.
- Will my springs settle?
- help! car wont start
- How do I wire an O2 sensor simulator?
- finally
- Im new to honda
- I'm wheel shopping and......
- antenna block off plate for an eg?
- Civic/Integra Rotors
- Civics with type r lower control arms
- post links of racing videos plz
- 97 jdm brakes on 94 non abs delsol...will it work?
- rain & CAI
- quiet exhaust + ITR rear sway?
- A few questions about my VX rims
- Intake header exhaust
- Question about Radiator Swap
- post your non jdm hatch pics here (pics only)
- attn "owen the soyboy"
- Where can i get a swap at a good price ???
- crx si cam in dx hatch
- proportioning valve for ek with no abs and itr brakes
- jdm b18c5 into 98 ex
- Attn Junek9
- Radio Relocation for EKs
- fogging up headlights
- I got a new 99 up Civic Black widow hood how much should i sell it for?
- Tenzo SINKO rnr style 15"
- Oil Filter help....
- anyone tried this
- 3k rpm engine bogg @ restart
- OT: NOS in Eminems 8 Mile movie.
- OT: Why cant I save notes?
- Review of Apexi World Sport with pics
- built up d16
- Valve Adjustment.
- help please
- Tach/CC not working
- VIN Question!!
- Please Help! CEL Code 41 in 92 VX with 98 GS-R Swap
- Norcal meet in Dublin
- tired of this
- Any 5th gen sites with how-to's on remove engine parts?
- Anyone got links to 2002+ civic SiR........
- My 1994 EJ1's theft and rebuild ***56k WARNING***
- WOOOHOOO HKS Coilovers here I come
- is it broken??
- Hit and Run
- Sick of thieves!!!
- price on hatch?
- went to the strip tonight?
- Need Help w/ 95 EX motor
- my first car!
- What is wrong with my car?
- 92-93 Civic DX with ls vtec and P30 ECU, throwing code 7??
- Hatchback Catback Best Fit?
- clutch master cylinder?
- My new Neuspeed strut bar doesn't fit perfectly!
- OT: FUCKING theives, Stole my MR2
- 205/50/15 falken azenis on 94 gsr rims?
- direct drop in motors for 95 hatch
- **anyone running JIC FLTA-2's in eg6
- best swap for Ej8..
- Brake size
- Integra Springs (H&R) on Civic hatch
- look what i made for my eg today
- obd1-2 distributor compatibility
- how do I do the swap???
- gsr rear sway bar on my eg i have some questions
- "HATCHIES" ?!?! What the hell?
- CTR Pisons in GSR block
- How to tight roof on Del Sol?
- exhaust
- new si
- SOHC SI head on a SOHC EX block
- new motor
- body repair on hatch rear Q's
- hatches are ugly
- Thanks for all the help, but I got one more question.
- Car done...pics inside
- how to get rid of brake fluid stain... =(
- sohc d16 breathing
- help on JDM gauge conversion
- Anyone have pics of stripped interiors from a 96-00 Civic HB?
- 95 Civic DX "auto" using a Greddy Turbo?
- my allmotor civic pics
- went to the track
- Where did you buy your Bride seats?
- how do i take of shiftlinkage??
- are 96+ springs the same as 92-95?
- eg lip
- Whats retail Price on 5 lugs conversion...
- About to drain antifreeze and put in new antifreeze
- what does the hondata intake manifold gasket do for a b16?
- motor swap
- Do i need different LCA's?
- Anyone know or tried this?
- Engine Block Stamps and ID ?'s
- exhaust sound clips
- side skirts
- Would a JDM GSR cluster fit my EG?
- Roofline Spoiler for 99-00 Si
- rust in muffler!
- picked up a clean CX from a Dealer
- KYB AGX and what coilovers on 99dx coupe?
- dyno d16y7....
- another one gone....
- quick question.. EX vs. DX
- 03 Si
- Any Engine Installers In the RI area?
- Brake Swap Questions (already used search)
- SKUNK2 manifold : and TYPE-r throttle cable
- Help my Brother and I
- ***If you're Tired of Spamming Little Turds in This forum, Then Check This Out!***
- Looking into cams for my B16a2, help please
- Who knows how to fit ITR/GSR airbox in a 96-00 civic?
- Type R Rotors
- few pics of my work in progress b16a eh2
