View Full Version : Honda Civic / Del Sol (1992 - 2000)
- EKsquad..
- worth saving a short block or trash
- Poor Man's Comptech Icebox I made today
- 1992 civic 1.5L single cam wont start
- EG automatic into EK automatic
- new to me 1994 civic ex questions
- Code 43 fuel supply system
- window help...wont go up?
- help, car has fuel and spark but wont turn over
- 99-00 Si vs base RSX
- running hot?
- B18B swap in auto EG, a few questions...
- EG intake still usable w/ swap?
- LSD transmission, good deal?
- TIre issue.. need size help
- Gauge Cluster Malfunction
- timing d16z6 engine - please quick reply needed
- got a stumper...
- radio & clock dont work after wiring
- Removal of upper and lower timing belt covers
- window wont close anymore HELP
- DIY Parking Pole on LHD Civic
- cv joint question?
- Midori Green EK Coupe, Pic n e one?
- please help
- switching tires
- Black Civic EG6 i was bidding on from Yahoo Japan
- z6 dizzy not getting spark
- vtec solenoid???
- Wierd Oil on Plugs... (EM1-B16A)???
- Problem with Civic, multiple CEL's triggered at once, Help!
- another stupid incident
- best place to buy an oem si lip 99-00
- D16A (z6) into 97 Dx Questions...
- Power window switch disassembly (to clean contacts)
- b16a4? no idea
- teg shifter in d-series linkage?
- Need your opinion on price...
- clock on eg
- serious ? ek hatch
- headlights with running lights question
- Do i need camber kit for coilovers ?
- 2000 civic with a 96 engine harness wont start
- 95 ex vtec quesiton
- .:!Where can you buy rare del sol parts?!:.
- Problems With My Camber Kit and Rubing
- 2000 Honda Civic EX AC problems
- honda distributor cap vs. integra one
- Need Help Fuel Gauge isnt working
- ignition problem? just installed MSD.
- check engine codes
- Leather GSR seats in an EJ??
- 92-95 Civic transmissions and misc.
- More '92 Civic LX problems; electrical system dead...
- Need Help with power steering
- OBD harness question
- car wont start... need help
- EK armrest question...please look
- 99' D16Y8 overheating
- help with the clutch
- ran my b16a2 last night
- Random/Intermittent "won't start" condition -- 94 EX.
- Which Distributors Work with a Y8 Head?
- zc obd-0 into 92-95 ?? help
- Removing headliner in 97 civic?
- 90 ef si rear lower control arms fit on 92-95 civic ?
- best way to remove small scratches and dents
- p08-1? what head?
- ek exhaust question
- DC2 seats into EJ6
- checking CEL on 96 ek help
- Plug wire issues
- misfire need help
- apexi noir exhaust for civic eg coupe/4dr
- tow hooks
- Pulled a connector plug off my harness
- h22a EG will not start
- motor mounts
- water drip under dash with air conditioning?
- front lip
- Name that Sensor
- 92-95 B16 and 99-00 si B16: same parts?
- eagle crank shaft b18c5
- Shave Door handle for hatchbacks
- need to post my pics
- holes in fender well
- getting around the iacv
- temp needle bouncing?
- losing ne power ?
- exhaust??
- My new hatch.
- Del Sol Rear end repair
- ob2 communication problem
- 95 EX Coupe sunroof issues
- EF Clutch & flywheel compatibility question...
- 95 gsr into 96ek needs wiring help
- Exhaust question
- Throttle opens, engine (D15B7) doesn't respond well. TPS issue?
- 96-98 sir front bumper fitment
- Grounding Kit From Friend
- engine question
- CX intake manifold and dizz--> z6 longblock?
- help asap! car wont stay running more than a few min.
- smoking problems
- what is the largest wheel that will fit?*
- How do you install OEM rain guards???? 92 EG
- How much is this EG Hatch worth?
- Official 96-00 civic picture thread
- msd ignition
- Speedometer not working
- Car randomly dies while driving/idling
- Integra 4D back seats into 92civic 4D
- Carbon Fiber Velocity Stack
- Will 13 inch rims fit on a 96 ek civic EX coupe
- EK Si - did cap/rotor, won't start, destruction imminent
- d16z6 overheating/pressure prob
- knoking noise
- Firewall plug
- knock sensor
- hks Turbo Timer Wire Up??????
- Engine swap Info, Help
- Quick question about 96-00 HX ECU's....
- a/c
- obd2 wiring harnass and etc
- Interior Removal Help 95 Civic DX
- 96 civic ex 4dr build and 98 el conversion
- clutch alighment HELP!
- Motor mounts for a GSR into an EK
- 92 hatch ls vtec cel problem
- NEED axle help ASAP!!!
- Power Windows
- Mugen twinloop with turbo setup?
- Is my lower ball joint shot?
- how do you identify trannys?
- 4x114.3 conversion
- Need help with axles quick!! :)
- Correct firing order with pics for obd1 b series in a eg coupe? Need pics to know
- does anybody know??
- help finding a thread plz
- Wiring obd1 dizzy to obd2 help
- Will this motor mount work??
- Acura 1.6 EL 97 = Civic 97 ?
- No Start
- Weird O2 Sensor Issue
- b16 oil leak..
- final drive counts..
- gettin a motor bar legal
- pic request: obd2 distrubutor on obd1 motor fitment
- b18
- honda domani front end conversion
- 94 civic dx mini me vtec problems (engine sputters, car won't start)
- obd2 GSR swap
- car has to cool down before starting up again?
- Rubber Injector Insulator on IM?
- car wont start/ignite.. ALTERNATOR?
- b17 swap
- OBX question...non typical
- Bogging and misfiring, what seems to be the problem?
- Mini me swap please read
- Is my fan switch the problem?
- best way to replace ek transmission
- oil coming from exhaust ports
- Blown Engine Help!!
- passenger door wont open on my ek hatch wtf !
- Fenco parts
- Weird Cluster Lights Question...
- master cylinder brakes
- B20vtec EG Check Engine Light MISSING HARNESS
- Wire tuck
- Parking Brake Adjust
- trans question ?
- D16Z6 swap wont start
- your experience with H&R springs
- Glass scratches?
- Looking for a b16a head................
- Honda Civic Stolen!!!
- What's better str8 pipe or high flow cat?
- b16a2 eg capable of 15's?
- Dc Airbox Into Eg Anyone?
- Will DB8 rear seats fit a civic sedan?
- Motor Question
- Weird vibration/noise in EK...
- Kms Valves
- d15/ d16
- Lsd tranny?
- What ECU?!?
- Help! Distributor/spark Issue! No Spark After Dist. Install!
- Painting engine bay?
- Fuel Filler Valve ?
- EM1 fog lights
- Just got a 97 civic ex...a/c Issues
- surging idle/brakes go to floor(random) tried everything
- What is causing my del slo to bogg at 3k??
- Clutch Getting Weaker, Almost Non-existant
- ok hood pin holes
- Help with 92 civic vx w/Gsr swap
- brake light problem
- 95 Del Sol S D15b7 Boggin, Backfiring. Please Help
- 93 Civic CX with 95 A/C complete unit installed! Need help!!
- GSR center console in eg
- 2000CX hatch. Help!
- New to Honda-Tech, My Del Sol Si
- quick question...
- eg dx head gasket pound?
- hey Q. about d16 block
- car dosent like to start sometimes
- Vtec harness question
- papers for motor?
- Desirable Offsets for wide wheels
- minor accident
- +5v needded
- wiper help needed(i did search)
- Air Compressor Clutch relay???
- Skunk2 Springs on 92-95 Hatch
- wiring issue clock and and cd player no constant power
- B16-vs-ctr tranny
- B-series gearbox Conversion
- Identifying an OEM vs. aftermarket brand radiator?
- b16 JRSC on b20?
- HELP! Problem with lighting
- alternator help
- Camber Kits.. New A Arm Kit vs. Slider Kit
- civic with b18b1 swap what a/c compressor and condessor do i need?
- Ebay aluminum radiator?
- car safty
- how much for gsr harness?
- Single Cam Builds?
- need a good basemap d16z6 zc pistons
- 1999 civic 5 speed
- Need help: Headlight fitment issues
- Which Fuel Rail?
- JDM B16A A/C pump questions. Hot...please help
- ?s on brake swap
- Help locating Front Engine Mount
- radiator fan help
- valve adjustment affect gas mileage?
- Suspension Questions!!!!
- the EJ8 guy again: Putting in tranny fluid
- NPR pistons and piston rings
- ::urgent:: Altenator Bracket Question
- track civic help
- Oh noes! rad problemo, help please...
- Suspension.. need some help (pics inside)
- D16Z6 spark plug gap
- aem boost controler install help
- Gauge Cluster Question
- Pwr mirrow/lock/windows Swap Help
- I have money and vision, but no direction, help?
- Better brakes?
- 1996 Civic LX Header/Exhaust/CAT Suggestions
