View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Are Recaro SRD and JDM ITR rails/brackets the same?
- Y8 Mani Swap, I thought I had all the right parts.. what now?
- del Sol In-Tank Walbro Fuel Pump Install Question
- Need an opinion on shocks to go with. 400 hp coming soon
- Engine Damper B.S. or Really works?
- are spark PLUG WIRES interchangeable?
- Full energy suspension bushing kit in the civic hows the ride
- Where To Buy a B16A
- headers on an HX/D16Y5?
- turn signal problem....little help? 92 civic
- what color is my car
- Intake piping for GS_R in 96-00 coupe
- Ej1 Foglight bulbs
- JL 12w6v2 HO Wedge box fitting in an EM1
- Just ordered a set of Falekn Azenis need some info.
- rear disc swap civic question
- Need help with loan buying a itr hatch!!!
- CHECK LIGHT on 96 EK
- ***NEED HELP ON PIC****
- what to do with my civic
- Racing seat install
- D16 mods help
- best h4 non hid bulbs
- ls vtec set up help?
- poor noob lookin for advice
- ITR muffler on EG?
- difference between '97 and under b18C5 and 98+ b18C5 motors?
- got free coilovers but will they work?
- Field Controller w/ JRSC Map Controller
- jdm ek sidemarkers
- Questions about Del Sol "S" model, SOHC
- 94 EX will not start unless in 5th gear
- new project is up and running. :D
- Is this a good deal?
- Where can i find a cheap igniter for a 99 ek
- eg tailgate
- Need a upgrade, Piggy back or new ECU
- some of interior lights wont work......................
- Difference Between a CTR Exhaust CAM AND GSR
- eibach sport line springs w/ kyb gr2 shocks
- Ebay Supercharger
- in need of parts... still a new member...
- Just bought Black 98 Civic EX...what's next?
- for sale.92 cx eg clean title, phantom grey , so.cal
- JDM rear wiper :P
- some pics of my block old and new *56k warning*
- what header gasket should i buy?..
- Searched but found Nada about DIY intake
- Are the Tien S-Techs any good?
- Civic ek hatch with a jdm itr motor for 9,500. Is it worth it?
- Idle wierdness on the B16
- Installing Springs, LCA's, Sway Bar
- what brake pads is every body using?
- Whats your thoughts on the NEW Rota GAB Wheels???
- engines- how to distinguish obd 1 from obd 2
- 2001 Civic Ex sitting on Neuspeed sport springs and Koni adjustable shocks
- fuel rail help
- stock horse power?
- eg under the knife
- what exhaust
- dyno tuning?
- Anybody selling a Honda for 2500?
- Custom Civic Front Grill???
- Magnaflow Catback....Ja oder Nein?
- i'm looking for EG shell!
- who remembers my crashed integra..........
- Civic Condenser Size Question (really easy)
- Will the hondata d16z IM gasket fit my d16y8?
- brake problem
- just wanted to introduce...
- 97+ Prelude Calipers bolt on to 92-95 EX hubs!?! (with pics (to come))
- EG6 cluster ...or RsX-S cluster into 94hatch?...
- !!HELP!! why is my car over heating
- motor running lean
- wheres my oil pressure sending unit
- chipped ecu fuel managment setup on turbo y8.
- Identify this camshaft PLEASE!!!
- b16a in a ek hatch
- Machineshop B16 comes tommorow, Have a few questions...
- no speedometer/tachometer
- Progres shots...my forte
- Problem with installed RSR exhuast..need input
- EK arm rest in a EG
- Check out the new interior.... CTR carpet, ect...
- axle problems
- 2 piece header off 89 CRX
- apex'i world sport suspension...
- Car Won't Start, PLEASE HELP!!!
- SOHC V-TECH head prices
- Problem when taking turns
- 96 ITR brakes onto a 97 hatch
- CALLING ALL SOHC, CALLING ALL SOHC. TIME TO REAP FOR SOHC
- greddy d16y8 install
- 2000 si wiring harness problem!!!!!!!!!!!!!!
- rear brake line busts-rear disc conversion. why did this happen?
- which shocks
- Are These Rims Worth ALot?????? JDM EG Civic Rims
- sparco rails on Bride seats?
- diff. between gsr and ls spark plug wires?
- weight 04'
- How many H-T members drive an auto or standard????
- amber alpine 9813 in 99 ex
- got a question
- What OEM FRONT SWAY bar on EK with SI LCA
- need mre grip
- cut out guides for EK hatch rear interior?
- D16 faq
- Please Carfax me.
- Tips to keep your car from being stolen. Post them!
- just a little car trouble
- 99 b18c1 into 95 dx questions
- Im kinda new at moding the motor on my 95 civic dx and would like to get some info on underdrive pul
- Here is my sol 1 more pic
- Here is my sol
- Throttle cable and bracket ?'s (skunk2 intake mani)
- 185 tires
- I got my 1pc headlights today...
- rain is a bitch....
- 99-00 civic carbon fiber hood question
- need some help....(having to do with ek and wheels)
- MPGs and HCs?
- y7-y8 IM swap over question?
- ek civic - skunk 2 coils and kybs...
- What throttle cord to use with this??
- Keep Blowing Fuses?
- new to HT. 98 prelude swap in 96 civic HB. need help!
- Remember the post of my 93 CX Virgin who met Mr JDM, well here's the update!
- creaking clutch
- whats the size of the gastank on a EG??
- ITR exhaust on EG coupe?
- What Short shifter/Bushing combo makes for the best all around shifter?
- installing ITR Intake Manifold on B16
- How to paint Faded OEM plastic skirts?
- Can changing cap and rotor mess the timing up?
- civic vs s13
- Help me pick a set of 5 lug wheels in the 1k-1500 range.
- Need help on power window civic coupe
- Polishing Stock Rims
- CEL code 41
- Exhaust Leak???
- KYB agx + Ground control springs Question!~
- RADIATOR CAP
- How do you hook up an A/F ratio gauge
- good tires?
- Integra Cluster
- EK H22 Setup...
- RED EG W/BLACK RIMS POST SOME PICS FOR MEH
- which spring is which. front and back .. longer front or shorter for the front
- disconnecting/removing AC
- Need info. Anybody have 92-95 civic electrical manual?
- :: SlammdSol ::
- No map Sensor? Is this right??
- How Many Bottles of Honda MTF for a B16a2 Tranny?
- can't decide
- ferio covers
- What should I do?
- civic
- Great site for EG Hatchlings...
- difference between d15b7 and d15b8?
- japandomesticmotor.com
- Where to find the Honda belt tension gauge?
- Swapping Trannies!?
- d16z6 water pump
- Ground Locations???
- Shipping a car ~help~
- intake for d15b7?
- Good Shop Just North of Dallas
- 270hp/185trq GSR motor :O
- ITR Recaros...?
- Honda Emblem
- paint
- 2000 GSR fuel pump in EG??
- What do ya think?
- H&R Cup Kit
- camber kit!!! help!
- LS vs. GSR Axles and Intermediate Shafts
- EP3 steering wheel on 92-95?
- which exhaust?
- witch is Better?????? PLZ HELP
- Got my CATZ ZETA H4 last night im in pressed
- header flange bolt size? Anyone know it?
- Which cam to buy???????
- Preference of Oil 5w-30 or 10w-30
- whats the BEST throttle body for a Skunk2 Maniflods
- bad topic: I rode in a Ferio rental car today.
- Progress rear anti-roll bar or Beaks kit?
- autometer instructions inside
- Bored...Time on my hands...need advice
- Will This Shock/Coilover Combo Work?
- whats a good stand alone Ecu or EMS??
- just crashed my hatch SF bay area.
- eg si rear disk conversion...did search
- need new tires.
- removing primer
- Should I get this 96 cx?? whats the catch??
- Ground Control experts...spring rate, need help???
- best place to get brake upgrade
- Difference <<< BODY STYLES >>> 96 cx compared to 99 dx
- defrost with no a/c?
- WELD Racing Runner
- i need help
- 5 wire to 4 wire conv
- EGR Valve problem
- **INFO ON THIS CAR**
- can anyone tell me that kind of wing this is ?
- h22 into 98 civic
- EK and EG exhaust pipes
- DOES ANY1 KNOW WAT COULD BE WRONG?
- WTB: del sol seat belt bracket passanger side.
- bump stops
- CLR on my 01 ex muffler tip?
- Help
- Bye Bye Tranny :P
- seat fitting?
- What morons in Jeeps do to our hatches!
- replacing front windshield
- d16y7 spark plug order.
- injector leaks when i touch it...?
- Check Engine Light off, then on, then off again??
- My car got some shoes.
- H22a or B18c1
- Broken Seat Belt
- Hatch
- a favor from someone with a manual
- GSR Tranny Problems Maybe? Help
- "X"Carb exempt parts on"Y"jdm engine in"Z"car = Legal????
- new motor just crapped out!
- What 02 sensor for A/F guage?
- seats
- wierd problem , car dies every once and a while
- Poll: Worth of stock 13" steel wheels w/ good tires.
- has anyone heard of this or seen it before? sorry i dont have pics
- Underdrive pully
- Anyone still suggest Hmo for a b16?
- new pics of a lost cause...
- Piston Ring Replacement (Searched)
- Swapping B18C...Which is best CATBACK EXHAUST to go with?
- (Searched)
- what mounts am i missing?
- how to make black headlights...
- how to install apexi vtec controller?
- removing tint.. defroster lines?
- del sol with slips and eg with speedies or ssr
- Lowering Questions from a Newbie
- valve cover cleaning help.
- HELP! Car used to bog, now no start @ all.
- Stock Eg Wheels
- 1/4 miles time for sohc vtec civic hatch
- just got new exhaust.
- ::install:: recaros in an si
