View Full Version : Honda Civic / Del Sol (1992 - 2000)
- P1259 vtec system malfunction
- DIY Blues......(axle related)
- Building B16a block
- Any cheap odb1 scan tools available for 92-95 civics?
- shift linkage
- stereo head unit removal trouble
- [DIY] Amber/Red 99-00 Climate Control/Cluster (apologies to 56k)
- Project Civic HB
- My Project EG
- I hear a crack when i shift
- Is 210k too high mileage to start modding?
- Building a H23!!!
- Is H4 bulb the same as 9003?
- does this sound like a good price?
- Noise coming from front end!
- ECU Wiring Question.
- parts numbers
- 12v cigg socket help
- Free horsepower
- HELP b18 not running right
- EVAP canister
- Gauge Sending Units
- Changing battery cables.
- good idea
- increase viper 791xv range???
- Tranny question for B18C1's....
- Is there a write up on how to flush an automatic tranny?
- Did I get scammed by Import Replacement Parts????
- Tenzo R brake kit
- Is there a harness on the rad fan to remove it?
- 93 civic coupe tranny issues
- Catch Oil Can
- idle problem d16z6
- efdc on EK
- exhaust install question
- Spoon n1 fits on Apexi N1 bpipe?
- Help with Distributor Wire: No spark
- Apexi N1 coupe and hatch piping
- Electrical Question: Loosing power to my radio
- What shocks with my H&R springs?
- help: need two diagrams
- identifying ECU
- steps in removing radiator
- Blinkers no worky
- 91 integra throttle body on d16z6?
- Another Startup Problem...
- steering out.
- Bad Distributor?
- seat belt swap
- what ignition wire for turbo timer...
- car weight question
- noob vafc help
- Mirror Help
- Edlebrock Turbo kit on a 1999 d16y8
- is this turbo kit good deal or garbage?
- Axel removal help!!
- 6" JRC FMIC with OEM fogs? can it be done?
- Sorry for the thread in the wrong forum, but I can't post in the Kills or PM anyone
- Weak HandBrake
- does mugen intake fit EG with a/c?
- Knock off CTR headlights 96-98
- Side molding question
- diff between bb4 and bb6 h22 motors?
- strong petrol smell
- car is dead
- Silverstars vs. PIAA Extreme White....
- del sol gauge pod??????
- D15B(sohc vtec) head on a d16y6
- Found out today that the key I got with the Civic is valet and not the Master key
- h22 mounts in a ek
- [FAQ] What kind of gas mileage do you get with your Civic?
- EK Shock Help
- making skidplate?
- a swap question that most of you cant answer
- Suggested selling price
- maintenance required light
- valve cover
- milling head... How much to shave off?
- Fake J's Racing Intake [w/ Pics]
- eg w/ h22.. what header? and intake
- t3/t4 or t28
- header conversion fitment
- C-pillar Water Leak 2003 Civic LX Sedan
- d16z6 vs b16 delsol
- vtec or no vtec
- Transmissions
- ARE AIR/FUEL RATIO GAUGES REALY ACCURATE?
- Idle Problem
- Advice on Brake lines for EH2 with Integra Brake Swap
- cluster swap
- cam gear
- Brand new to the Honda world and need a little help!
- can i make a o2 sensor longer ?
- y7 mini me to y8 what do i need to buy ?
- has anybody on here tried this before???
- del sol 4,5,or 6 point harness
- help - bleeding clutch, tried all ways, still messed up
- B18C Swap -- is this a good deal?
- No power
- Which lip for my car. help! (pic)
- Difference in chassis/suspension 92-95 Civic
- eg auto to manual conversion q's
- How much would you pay for a 98 hatch w/ gsr swap or 98 hatch w/ stock motor
- Brake problem
- Oxygen Sensor Wiring
- Intake/ check engine light asap
- Ups man paid me a vist
- which springs for a del sol? POLL!
- ZC transmission
- Del Sucklo
- jdm cluster not working right
- comparing coupe and a hatch
- RPM Fluxuation
- Civic Alternator Problem. help please
- denji projectors. only high beams work?
- Ls swap in a Del sol?
- rod bearings
- WTB: B series tranny
- what do u guys think?
- B18c1 non vtec in the sol?
- Goodridge brake lines and bolts question.
- TB gasket / IM cleaning
- Replaced 02 sensor.....how long till ecu resets itself?
- BC SpecIV Cams... How is your idle?
- Bizzare coolant leak to overflow with boiling, PLEASE help
- Can someone do a CARFAX for me please... =)
- Harness for JHPUSA sidemarker bulbs?
- the best b20/vtec setup>>>>>>
- eg with s2000 set up on type r 5 lug
- What are the parts on your door right near you window called?
- keyless entry control unit??????
- safe to reuse head bolts?
- Water Pump and Timing Belt Replacement - CX
- Anyone know Evin Safdia or Jdmislife?
- suspension question
- does anybody have that book"honda engine swaps" by aaron?
- Filter Question
- Civic won't start, little help
- Help With Driving Light Installation
- VIS carbon fiber hood good or bad?
- laggin on me
- Differences between USDM, AUDM and JDM chassis
- Can I swap a dx tranny onto an HX civic
- does obd1 civic dash harness work on obd1 (94-95) integra??
- b18c or b16a
- will this fit my intercooler and T25
- 97 B18c into 2000 ek... few questions?
- type r style lip too short!
- Custom Turbo List?
- b18a1 which color wire is the tps voltage wire
- code 71,72,73, and 74?
- GSR disc brake swap ?
- An article with all you ever wanted to know about suspensions....
- si rear disc conversion?
- Help a newb convert a dizzy back to stock! yAy!
- Windshield wipers won't turn off
- gas mileage for cx hb?
- i have a question
- Fender Roll or Tuck ?? who's done it? pics?
- engine problem...car has power loss
- ctr or itr internals with cams>???? wich for my JDM B16A
- corner lights
- omni power coilover concern
- p2t ecu chip question
- will these tires fit my hatch?
- Question for all...
- B16 Smokes need help!
- BRAKE QUESTION
- IACV
- OEM CTR/ITR LSD
- going sol shopping: WTB
- Intake manifold question
- idle problem obd2-obd1
- obd2 to obd1
- ECU Question?
- wheel suggestions!
- Converting head back from Ls/Vtec???
- 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
- getting sidemarker to blink in sync with corner plus stay on when not signaling?
- 99 ex coupe weight
- Where to get custom interior done?
- B18C in my 93 Coupe.. Do I buy intake for GSR or Civic EX?
- b16a1 in 93 4door civic
- 2005 HONDA COUPE SI
- b16 power loss....why?
- Car wont move after i made a U Turn.
- clutch / tranny slip ???
- Intake Question... tried searching first, I promise.
- Tapping sound from my motor
- A few questions for you guys
- help with track bullie
- Doin Brakes...Got some Q's...
- Help spongy brakes
- ok so my hood latch broke, now what?
- k20? and manual trans Swap into my 02 Ex AT and tall driver- worth it?
- Question about a dc5 cluster in a Ek9!
- hondata or uberdata???
- What Do I need to know for a H22?
- How Many Miles Is To Much??
- b16 swap problems
- Pics of s2000 Seats in civics
- swapped in d15b7, won't start!! need help!!
- What's the best computer for a turbo car??
- anyone have carfax??
- D16z6 header on a b16?
- What Body Kit Is it? The EK front bumper on an EG/EJ? can some one help?
- attention cusco 6pt owners (eg/eh)
- v-8 turbo civic
- Clutch slave help
- wire diagram for 99 si
- JDM ITR steering wheel in a 95 civic ex
- ctr/itr et. times??
- Throttle Body ???
- super civic
- Questions About Hondata
- Can anyone post a pic of a 99-00 civic fuse panel cover(underdash)?
- Y8 what price!!!!!!
- Dash lights dimmed
- A/C
- erratic steering? oppinions plz.......
- Does 99-00 Civic dash fit in a 96-98?
- Helm manual / front brake pad shims ?
- DC JDM Header on 92 EG Civic?? Fitment question.
- Just bought a 97 civic ex 4 door!
- New ECU and IAC Problem
- hello help please
- HELP its raining season!!!! TARGA LEAKS!!
- 93 Civic Coupe DX passenger door handel
- can this be done ek dash in eg
- Civic Si 1/4 time
- B16 landspeed records
- Engine Knocking = **(`
- look what i found: honda anti bling
- guage removal
- SI supsension VS. Civic Supsension
- shaking car
- gas needle
- koni fitment issues
- h22a check list
- cluster question
- spoon weight saving ?
- energy suspension
- What would a 98 Hatch w/ b16 swap run 1/4 mile w/ cai and stock internals
- sensor number?
- New to civics but..What would a 98 Hatch w/ b16 swap run 1/4 mile w/ cai and stock internals
- $2k suspension upgrade worth it?
- check engine light on!!!
- Valve COver!!! HELP!!
- part # pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeee
