knock sensor help!!
knock sensor help!!
kinda new to the b-series era....
picked up a 95 civic coupe with a 99 gsr swap running on a p72
whenever i hit vtec, the check engine light will engage, i jumped the harness and it pulled up code 23 "knock sesnor"
is there a way to eliminate this problem??
thankS!!
thankS!!
Re: knock sensor help!!
run a wire from the #3 spot in the pic to D3 of the p72 ecu.
Just steal some pins out of a civic that go into the engine harness plug from a scrap yard or something and sodder the wires up. - do same **** with the pins into the ecu.
Tada.
stockegsix
05-11-2003 10:17 PM
