View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Headlight frames
- Bought a 1999 civic EM1 EBP
- 2000 Honda Civic LX not charging
- High idle, surging
- Timing won’t advance past 0
- *Help* map sensor issue.
- REFURBISHED D16Y7
- 1999 honda civic ex coupe coilover suggestions?
- Integra type r shifter in 98 ek coupe
- Jack spania racing conversion harness
- manual window install 95 civic dx
- 1994 25th Anniversary Edition Eg Civic Sedan Vti
- Rocker arm torque sequence
- 99 civic a/c not working
- 94 Del Sol with a 2018 engine
- Boosted B20b vtec using a b16A head
- Heater/AC blower
- Hello everyone help
- 00 Civic Auto Shifts Really High in RPM's after Replacing Cylinder Head
- Noise in Cylinder Head After Valve Job and Head Gasket Replacement
- Manual swapping a civic
- Forgot one dowel pin between clutch bell housing and engine, am I good?
- Idle.
- Need help with Vtec situation on Unfinished Project
- Help with wiring!!! 2000 civic dx with y8 head
- How to Take Off Ek Civic Door Trim
- EG sedan rear seat swap
- PKE with key slot
- are there any bumper reinforcements that are interchangeable
- Am I looking at replacing the head gasket?
- Stuck intake manifold
- CIVIC VX B18c ITR swap HELP!!
- California carb legal ecu jumper???
- civic eg reverse shaved side molding
- 1999 CIVIC EX COUPE Healthy Crank , NO START
- clock spring / cable reel pinout
- 93 Del Sol cranks won't start
- 98, with random "flooding"...
- B Series Swap Issues / 96 Honda
- 95 civic, 94 integra prop valve swap
- Shorted Wires
- What intake pipe/tube will fit my stock d16 airbox and Skunk2 Pro Intake
- Patch/replace 6th Gen. 1997 Honda Civic CX, KA 5MT, D16y7 brake lines
- Rust repair eg
- Darting or swaying on hard left turns
- Fiberglass hood for '92 EG Hatchback
- D15B7 valve-piston interference?
- B18A1 crankshaft pulleys
- AEM fuel rail causing issues?
- Temp gauge
- D16 Radiator fan wont turn on
- Recommended Distributor
- what alternator can i use for a b16 a
- Motor mount stud install
- Del sol intermittent shake at highway speeds
- 2000 Honda Civic LX Steering Wheel Vibration at 75 mph plus
- can someone confirm this wheel and tire size?
- Crank no start. Not sure what the issue is.
- Just rebuilt my motor and 2 cylinders have no compression
- 95 Honda civic coupe build.
- 1995 Honda Civic DX Starter & Motor Mounts help
- F22 or H22 EK Hatchback Swap
- When does fuel return to tank?
- What is the correct ICU for my 1992 JDM 1.6 DOHC ?
- Best ECU choice for set up?
- 95 Del Sol Si: Prime, No start.
- B16a ignition module
- Does anyone know the dot/paint colors of OEM EK9 Type R Springs?
- Rebuild
- Can the CL1 handbrake spring clip fit on a 99-00 Civic EK ?
- EK civic with EG/DC front subframe, which mounts to use for B series engine.
- How to tell if transmission has bad bearings with it apart?
- '97 Del Sol - Ticking noise in air ventilation
- Jdm b16a swap in 95 dx first start problem
- Valve cover crack
- B16 keeps frying one injector?
- Del sol won't shift auto tranns
- Wtb automatic transmission jdmb16a would b best
- D16y7 mini me power rating
- Advice on brake upgade for EG
- rebuild and starting.
- Radio and lighter intermittent
- Bouncing Tach needle
- Chassis model Information
- Idle at 1040
- Automatic trans coolant lines
- Need someone who specialises in fixing b-series engines in Birmingham U.K.
- What end links do i need?
- 95 Del Sol- have to turn key 5 times to get car to start
- Help finishing up a rebuild!?
- Car Shuts Off Randomly
- Civic D14Z2 A/C spacer
- 97 ex coupe
- 97-01 crv blower motor in a 95 civic. Is it more powerful?
- Having Issues with my window in my 96 ex
- B16B into 95 Civic Si (First Swap)
- need a power source
- B20 S4C transmission issues
- '98 Honda civic dies on hills
- I need help figuring out where the sound is coming from
- HA MotorSport vs Phearable
- Beginner working on suspension
- Water Pump Leak - pretest pump?
- Running rough
- B series engine swap on a 96 civic automatic
- NOT SOLVABLE! Guarantee you won’t! B20!
- What’s the best fuel system
- Main beam adjustment
- Transmission Leak is Driving me Crazy!! Help guys!
- Virginia tech Champ car
- Tuned for turbo, but no turbo
- D16z6 Wiring Harness Troubles
- Just Replaced Evap Core - Do I need to ad Oil?
- Main Harness C101 Pin2
- muffler suggestions
- Battery light problem?
- Does VTEC remains engaged in VTEC-E engines mostly?
- Cant open door from inside unless I hold tension on lock simultaneously?
- B20V Build…Trans Question
- What’s up guys I’m back to play Honda’s
- EG/EK axle swap
- Changed distributor oil seal and now the car wont start
- How to take off exterior handle lock rod w/o breaking the plastic?
- 5th gen vs 6th gen door?
- 93 del sol Key stuck and no start
- Valve cover leaking?
- B18a1 swap issues
- 98 Honda Civic Stolen No Crank No Start Electrical Burning Smell
- 1997 civic coupe ex bushings
- Drivers side lock doesnt work+ handles are loose?
- Am I Wasting Potential Power??
- Housing
- 00 Civic Si w/B20B - Need OBD2 for emissions
- Rear passenger shock mount rust out
- HELP
- Door lock wont turn
- Clutch not bleeding
- A/C Problem- Refrigerant leaking from evap drain
- 93 Civic Fuel Pump Primes No Injector
- NEED HELP!!!
- Rear jack stand points are busted. Alternative jack stand points?
- Just picked up some “used” Tein Basis Z Coilovers - Question about installing
- 2 pin sensor polarity . How do i check which is +/- on a *2 pin sensor*.
- Civic 1999 AC low side and high side pressures
- 1992 Si Valve cover
- What OBD is my engine?
- D16Y8 turbo PSI for MPG
- Bearing cap installation
- TB Thermal gasket issue help
- Main fuel feed and return line replacement 92 civic eg 4 door
- 2000 Honda Civic ex swap to d15b
- My Del Sol won't start
- A/c blower motor
- New help not sure if is right?
- Dash cluster and turn signals won’t work 95 ej1 ex coupe
- D16y7
- Is my Civic OD Broken??
- P2E with d16y8??
- OEM or Aftermarket Steering Wheel?
- Ej9 bumper from Jdmaster
- I need a solid, nicely fully explained, answer. Are all d-series transmissions, hydra
- 70mm Thottle Body
- Civic coupe hx (d16y5)
- Rear Caliper piston not releasing
- Jerking only when CE light is on
- 98 Civic DX Hatchback crank but no start
- 98 honda civic d16y7 auto to manual swap
- 2000 Civic steering column U-Joint play
- LS Vtec Won’t Go Past 3,500 rpm
- B18b1 with a p75-11 head.
- P0141, wiring checks good, next step?
- 98 civic manual trans p0505
- 98 civic manual trans p0505 code
- Clean electronic trunk release installation
- Advice to swap Trans. AT (mutimatic) with MT on D15B 3 Stage VTECH
- Ex to Lx door conversion?
- Is this sound normal when I clutch in?
- d16z6 manual swapped eg won't engage in gears
- Dum-Dum Issue fixed - Check your dipstick
- P2E with d16y8??
- Fuel Rail, intake manifold, header mismatch?
- Honda Civic Fuel Filter Bolt - need help!
- Motor mounts
- Brake bleeding gone wrong - help!!!
- 1995 civic ex with d16z6
- Del Sol - Rear window lower seal
- How to switch the lense on a 94 civic hatch trunk signal
- B18b Crank, no start.
- WTB:dashboard upper for EG/EH
- Brakes Keep Sticking
- Too much camber! Need custom front upper control arms!
- 98 Civic HX NOT Wanting To Crank
- Clear coat is flaking and paint job is wearing off.
- Passenger side CV Axle
- 95 Honda Civic Main Relay/ECU Fuel Pump issue
- 98 civic 5 speed idle
- Bolts don't line up with intermediate shaft. B Series GSR
- Car only runs when I hold the key in the start position.
- Connect headlights to switched power?
- Honda b20 std dictator problem
- 94 del sol si D16Z6 downshift getting off highway crunch then dies
- 96 civic wont start (stuck at a gas station)
- Del Sol Door Check
- 98 Honda Civic lx computer automatic transmission
- May sound crazy but hear me out
- Ek civic lowering springs
- f20b swap to eg
- What is the best clutch and pressure plate for good pedal stiffness?
- fast rattle noise after replacing clutch and TOB
- ‘99 Civic LX temp gauge fluctuates while idle
- my HONDA needs URGENT help
- Shock tower harness
- Can I put 2000 ex wheels on a 97 model?
- 96 civic idle surge
- Clutch pedal stuck to floor no leaks and clutch fluid is full
- 95 EJ-2 13.9v charging
- tuning my p06 ecu?
- I need help
- 1992-1995 EG turbo guide install B18c4 posts please
- No SRS Light At All
- 97 Civic jerking when light pressure on gas
- 1992 Civic EG D series - car dies when hot
- suggestions for which upper control arms to purchase
- Iso TODA ITB B series Fuel rail
- 1997 Ek1
- Check engine light wire source
- No spark
- Bolt lengths
- Tuning for my car
- CEL stays on solid in ECM diagnostic mode
- 98 civic 5 speed problems idling ruff then dying after starting
- P0335 What voltage should ECU pin 22 be? CKF power?
- [Rust] How bad is it bros?
- Im in need of some help
- Need help!!!!! 2000 Honda Civic Ex coupe
- Dohc zc timing issue
- Carpet help?
- Misfire on cylinder #4
- will 15x7.5 wheel fit on eg hatch
- Horn for a 1992 honda civic si hatcback
- Lambda sensor plug em1
- Rear Drums to Disk Conversion- Scarebird Brackets
- [EK] Rear Frame Vent Hole Purpose
- 92 Civic killing ecu?
- Replaced the Temp Sensor Same Problem
- Best exhaust and header collector diameter for stock D16Y8
- Honda Civic 2000 DX cranks but won't start.
- 3k Idle D16Y8 Leak In Throttle body
- Del sol -> eg disc brake conversion
