View Full Version : Honda Civic / Del Sol (1992 - 2000)
- pic of 92-95 civic si sticker
- rear brake dics conversion on 99 honda civic sedan
- Connecting OEM power lock to turn signal
- help please
- I've been waiting to post since 2006.
- what engine is this??
- B18b eg... swap in b18a?
- Anyone have carfax?????????
- better gas mileage.
- D16Y8 to D16Y7 downgrade problem (iacv)
- POWER WINDOW CONVERSION. HELP.. 96 dx with 99-00 si doors..
- 93 Del Sol not starting
- Quick?:94 Integra exhaust bolt to 94 hatch?
- y8 long block
- Cluster Gauges Not Working?!?!?
- throttle body question
- dizzy question
- Wheel weel lining/Rust pevention
- ***k20vs k24vs frankestein build?***
- power lock conversion
- TROUBLE CODE 8.. HeLp
- need help with pistons
- VTEC engages at 6000 instead of 5500?
- Car acts weird when cold
- My new ride, 00' Si Clone! Give me your opinions!
- 2000 Si Clone problems
- what seats fit in ek?
- My motor laggs WTF?!?!?
- car starts but will not stay on.
- I think my clutch is going out?!?!?
- Vtec not working on H23vtec swap in EK hatch
- ek window visor question
- caliper fitment size
- NEED HELP/IDEAS FOR EK PROJECT
- stuck throttle cable, please help cars idling at 3k!
- Painting lug nuts
- ***POST YOUR K SWAP***
- d15b on y8 head in a 97 hatch will it start with obd2 ecu?
- idle system malfunction
- will StrutBar Fit on d16y7?? without intake?
- ECU help
- Can a GSR DC header fit on DOHC ZC motor?
- l00king for your guys gas millage on the 97 civic automatics that you have owned?
- Flywheel?
- help neutral switch
- does that garunteed to pass shit work?
- buying a 98 civic EX......
- Issue: 98 civic dx dies when let off gas
- BDL Fuel Rail question
- Intakes?
- Del sol ?'s
- What is the typical price to paint these
- how do i get my stock em1 seat to sit lower
- D16Z6 with a p72
- HEEEELP!! 98 Honda Civic Ex coupe AT
- ROOF RACK
- new to the civic forum
- ASR 24mm sway bar endlinks question ?
- Main Relay clicking consistantly?
- Keyless Entry Stopped Working!
- car is running rich what to do?
- identiyfied this a/c compressor.
- Plug problem
- how to find out if tranny has lsd???
- HELP!!!! Turn signals light up when i step on the brake!!!
- Emissions Help
- Skunk2 Full Coilovers
- fuel feed line Need help! asap
- gsr tranny in ek
- B16a cel code 43(Fuel Supply System) Lags badly!
- del sol steering wheel
- Carbon fiber hoods?
- Yay! another cel post!!
- 99-00 EM1 Wheel Color Question
- whats wrong with my car. need some input
- my civic wont start
- h22 turbo porblem
- d16z6 comes in auto form?
- ECT and O2 running rich=bad mpg
- 99-00 tail light question
- b18b engine swap in eg?
- BRIDE SEATS question need anwsered asap
- check out my AWD civic EG6
- dirty carpet
- For Sale or ::Trade my P2T ECU for OBDI P72 :)
- Clutch Switch plastic thingy majig
- crv cluster in ek hatch
- any difference between left hand and right hand drive mirrors?
- Online Parts catalog
- Ek coilovers used with an EG subframe
- Question
- Hatchback transmission
- vtec controller causes cel. normal???
- your odyssey/braille battery setup : Pic request
- looking for quiet exhaust
- B16a sir swap?
- OBD1 gsr into an OBD2 hatch
- shift linkage for b series
- parts needed for a b16? 2000 ex
- RS-R GT2??
- will 97 dx ac compressor fit in 93 ex
- Maintenance Help with 2000 ek hb
- Anyone ever used rear main seal from Autozone?
- 94 Civic DX Suspension into an Acura?
- how long ?
- Assembly Lube Question
- Engine Swap ?????
- how do you use KYB AGX Shocks
- Need Help... How to swap H22 into 2000 EK Hatch
- How would I identify........
- Where can I get a SINLGE JDM fender?
- Civic climate control lighting question
- B16 gears to ls case
- Replacing Piston Rings/Rod Bearings D15B7
- help me tire tuck!!
- Can 00 si window harness be used in power window conver in 94 civic????
- B16 swap
- I'm just really annoyed with this...
- Passengers Side Window HELP!
- EJ6 A/c Rattle?
- problem with my radiator/cooling system?
- 97 EK build up...need opinions and help please
- Trying to set cam timing...
- Help removing rear bumper off 2000 civic coupe
- need help after distributor installation
- How to put a carbon fiber hatch on ek ?
- Free tuning software? Help
- Will 96-98 Coupe Windows fit a 99-00 Coupe?
- dc2 front lower arms on del sol?????????
- Headgasket part number for D16Z6
- axle emergency.....help!!
- eg fogs
- Mugen Twin Loop Question
- need help asap about engine
- 92-95 EG Glove box difference...pass. airbag vs non-pass airbag?
- Odd question for Odd Idea, backwards mini me
- 96-00 badass 4 doors
- Fuel tank issues?
- 96-2000 EK EX Trans question!
- Clutch noise only in reverse
- code 22 (vtec pressure valve) help..
- steel braided clutch line
- question about brake lines
- weird problem.
- 96 EK with GSR swap woes
- halfshaft stuck in trans halfway
- Obd2 USDM B18c1 into 92 Dx Hatch, help clarify please.
- b18b1 Barred, can it be done? in cali
- stering column vibrating back and forth. please help
- cx civic a/c
- fuel starving and hesitation
- RWD civic with rotary motor
- JDM VS USDM climate control
- RWD civic with rotary engine
- The Deffinitive Rear Bushing Thread
- Manual to power window help (pic).
- questions on doing a mini me swp
- rear took hook SIDEWAYS
- Hatchback build
- steering wheel lock
- where can I get the eg6 double din for rhd?
- coilover question
- will a milled head ported and polish still pass ca smog???
- DA brake master in EG
- what ecu should i get?
- air/fuel gauge help
- what harness bar is everyone running in their sol?
- Bolt in cage, Do they work?
- ABS light..no code..what next??
- MAP sensor replacement
- code 41 p61 ecu
- 92 Accord Diagnostics reading....
- Need some help with my GSR Rebuild
- sir headlights???
- civic help
- dissapointmen =(
- best ls vtec kit
- itr oem intake in eg civic
- eg b18b1 bogging only under elecctrical load plz help
- H brace bar on CL
- 92 civic. loss power, engine shuts, can't start
- Burning valves D15B7
- spray paint FTW!
- GOT A LITTLE PROBLEM...
- 2 map sensors wtf?
- can someone burn a tune for me? professional tunes only please.
- HELP. What to check when buying a imported car
- 95 DX starting problems. Fuel problem.
- Suggestions for new clutch?
- integra sway bar in on my eg hatch..and muffler question...help
- 99 CTR swap questions HELP
- NO VTEC??
- Wierd Mini Me Swap....
- b18c into civic
- VTEC Problem? Supposedly
- Tach signal wire off ecu??????
- Hi guys..
- Welcome the hew member of the family.
- So Upper balljoint snapped last night....
- can I get some pics of stock del sol shifter bases and some stock prelude bases?
- radio and climate control lights need help!!!
- starting problems
- d16y8 timing?
- Car wont start, just clicks, dash dims out. not the battery/starter
- Question on my ECU dilemma
- Civic wont start :( rapid clicks and gauges die out. Not the battery/starter
- Quick question
- major malfunction vaccuum leak?
- cost for engine machine work? In Quad City area.
- Foglight questions
- EK parts used in an Eg for auto to manual swap.
- Raybrig/Stanley OEM Foglights for 99-00, do they come yellow?
- D16y8 head
- Need help with ek swap!!!!
- del sol with alarm
- StreetRays.com is back!
- brake swap Dc5 brembo caliper on 96-00 civic
- how can i tell if the MAP, IACV, or TPS is bad? concerning idle issue
- Civic failed emissions horribly
- building race car, NEED HELP DECIDING.
- sheered flywheel bolts (h22a civic) damaged crank?
- Anyone know where i can get this?
- Diagnostic Port on 1996 Sedans ??
- need help wiring knock sensor
- Civic randomly died and isn't getting fuel
- Omni power camber kit?
- car wont start!!
- noob questions on build of b16a2
- Head gasket question please help!
- Lumpy Idle/Cruising . Clean IAC?
- eg wiring help
- h2b upper rad hose question
- Quiet Exhaust's?
- need help finding out what mounts I need for EK
- 92 DOHC zc parts
- Horn Issues
- Cost of Exhibition of Speed ticket in CA?
- sunroof doesnt pop up
- Skunk2 Coilover Sleves...interchangeable da, dc with eg?
- how to power steering with b18a1 in 98 ex civic
- Which heater hoses do i need?
- Temperature issues, not warming up.
- Just ordered b18c from HMO
- JDM D15B OR D16 VS JDM B16
- 93 ex doors on 93 vx
- converting to manual
- Picked up a new toy, probably will be back on the fourms again
- D15B2 to B16A2, what is involved? tips & tricks please! :)
- Help eg power window conversion
- eg sidemarkers mesurements..
