View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Need help putting AC, PS , CC back in EM1 with a b20 vtec
- Best street full coilovers for EK chassis?
- 92 LX - Intermittent Start Problem
- 92 Civic CX (D16Y8 swap/P28 ECU) - Blown ECU replaced but engine still won't run
- Ladies and gentlemen, I've got a weird one.
- 92 Civic Dx 1.5L wont start until I stop cranking
- 92 civic VX/manual: bottom end rattle
- Trans mount b16a swap
- 95 civic has a rough idle and stalls
- 2000 Civic overheating
- 94 civic cx steering wheel lock
- Turn signal help?
- Overheating only when A/C on & going uphill?
- Alternator: Headlights, dashlights flickering SRS on and off
- does EF upper control arm fits a EG sedan?
- 1996 Honda Civic EX Head gasket change???
- 92 hatch with d16y8 idle fluctuations need help
- OEM lower ball joints - Which one is which?
- Can a radio be mounted where the climate controls are? Civic 95 EG HB
- 96spec ITR Swap Bushing Hell..p
- 97-00 Honda Civic engine wiring harness same??
- Where to find Good D16z6 engine
- DC2 shocks on EG. Ride height?
- 1992 honda civic hatchback, type R, trunk/rear window lock
- 1999 Honda Civic Harmonic Balancer came off today
- got multiple Cels codes in one are one the cause of the next??
- P30 ECU - leaky capacitors replaced but car runs poorly
- What's the brace attached to the front lca called?
- 98 civic LX. D15B7 swap, need help figuring out power steering
- D16Z6 Skunk2 Pro Series Manifold throttle cable bracket?
- 1997 Civic cranks but won't start
- 1996 civic - which intake gasket?
- 00 Civic don't like rain or puddles
- Shifting hesitation
- pressing in wheel bearing
- 96-00 VTEC wires
- 1994 Del Sol with fuel pump issue
- Denso 471-1420 vs. 471-7050 AC compressor difference
- 92 VX front end clunking, steering rack?
- One Single Sputter To End All Sputters
- 1996 Honda Civic having issues with intermittent stall (Solved)
- Catalytic converter California or EPA standard
- Oil Viscosity for 2000 Civic EX
- 1999 Civic Wont Turn (solved)
- Car does not start after clean intake manifold
- What part is this?
- Master Cylinder Brake Line Interchangeability
- 92 Civic Si Hatch won't start
- Misfire on cold start
- Broken dash vents
- 95 Civic No Start
- 93 EX Coupe - Cruise control troubleshooting, RE speed sensor
- 97 Civic - temp gauge not working
- D15 3 stage oil pan
- N/A d16y8 build
- Jdm b18b in 2000 em1. no spark
- Civic 00 radiator fan always spinning
- EG/EH driver door stuck
- 98 Civic overheating
- Correct Oil Volume Spec: D16Y7
- B16a vs d16y7
- ITR Steering Wheel+Column in EG?
- 00 Civic EX - Prolong life of auto tranny?
- 98 Civic EX Coupe -- Mod Advice requested
- Windshield Wiper Stopped and Then Started Working Again?
- 99 Civic Ex codes P0135, P0141, P0500, P1298 and P1456
- Rear bumper em1
- '97 EDM EJ9 - Follow the project
- 98 Civic - bogs going up hill
- Been driving without a crank pulley bolt
- Help help help someone pls
- Jerks or misfire when driving with ac on at low rpm or idle
- Fixing My '95 Del Sol
- Anyone had good luck with these new Cree LED Headlight bulbs that are now available?
- Looking for opinions - Bordering on overheating.
- 98 civic ex - Blown head gasket
- clutch on compressor not turning
- Replaced SRS unit and now getting code 1-1
- Hole in bellows breather tube
- Unchanged Surging Idle After Troubleshooting - 93 Civic (solved)
- 2000 Civic EK3 Overheating Problem Mystery
- AC Issue, 98 civic low pressure line hardly cold
- Bb6 prelude brake booster in ek?
- AIR CONDITIONING PEOPLE! Need help with adding AC into an EK with a B series swap!
- BAD EXHAUST LEAK
- 99-00 SI wiring obd hell!!
- Burning oil, rolling coal, killing exhaust systems
- 98 d16y8 in 99 civic
- 98 d16y8 in 99 civic si
- 92 Civic CX - No power to the fuel pump and other components
- 2000 em1 p0172 code??
- doing a del sol shell swap this weekend, any tips?
- Del Sol - high mileage oil or not?
- Rusty Corroded Stubborn Fasteners
- New to the honda scene, have a battery problem?
- Transmission oil. S20. 1993 del sol
- Gasket question
- A/C Issue - Cannot find answers...
- Steering wheel tilt lever loose..HELP!
- Steering wheel column em1
- 96 cx hatch with coilovers has soft brakes after sharp turning
- Electircal wiring and fuses; 12V cigarette lighter
- Aftermarket Radio Installed, no power at source with ANY radio now....Please help!!!!
- 1998 honda civic hx transmission issue
- b16a2 AC compressor belt, idler pulley/tensioner - interchangeable with B18?
- 2000 Civic CX - radio installation led to a bunch of electric problems
- CIVIC 95 4dr reverse lamp wire - which one
- Wiring revlimit light to check engine light?
- cabin harness help 92 cx hatch
- How to tell apart the 92-95 Cx/Vx Transmission
- sedan to coupe/hatch bumper?
- 99 Civic won't crank
- 92 Hatch, D15B vtec. Engine bogs, after car is hot, at low rpm in 1st and 2nd
- New Master Cylinder
- 96 civic - Bolt for lower left torque mount broke off in frame
- 94 Honda civic brakes having problems
- 93 Civic Battery and Oil light came on then engine died.
- 2000 civic SI won't prime with ignition
- EKSTK Hasport Mounts
- 1996 Honda Civic Ex Starts with a house key! lol
- Obd2b-obd2a conversions
- Gauge of wires on the door panel controls?
- whining sound (steering?)
- 93 VX acceleration pulsation... need help...
- 98 civic ex 4 door automatic what is this
- Del Sol suspension/ chassis improvement
- Honda Civic A/T D16Y5 1.6L Poor Fuel Economy
- 98 civic ex/D15B VTEC - What ECU?
- Removing eg coupe/hatchback door molding
- Trunk Adjustment...How is it done? (92 Civic LX)
- 93 Eg honda civic exhaust problem
- 00 civic ex - What engine?
- B series swap into an ek coupe
- Water in EG corner light
- 97 Civic DX mini me swap - injectors and fuel rail question
- Got in a wreck, what should I check?
- Which Integra parts should I swap into my 00 Civic SE?
- 93 hatch fuel not priming
- Auto b18 TB work on d16y8 manual car?
- Distributor O Ring & TDC
- Ex/Si brake upgrade on a CX hatch question
- 94 EH B20v build
- 98 passenger power window problem
- 94 Civic/d16y8 swap - no oil pressure
- 96 Civic motor and trans into 95 Civic?
- DIY - DRL wired to low beam for LED H4 Bulbs. (PIC HEAVY!!!)
- Need help identifying this rotor
- Huge Power Loss With A/C On
- 97 del sol si/d16y8 - No crank no start - ignition
- 1993 eg roof chipping need help
- D15b OBD identification
- Overheating......again..
- 96+ jdm d15b non vtec
- Gage cluster
- really bad engine misfire? need help!
- CEL - B16B swapped eg
- Help with wiring swap (1.3 carb to b16a1)
- Fuel Gauge to Fuel Cell Sending Unit
- Time to say goodbye to my Dizzy? Squeaking "chuck chuck" sound from dizzy side engine
- 99 Civic A/C Help -- No Condenser Fan Or Compressor Clutch Engage
- Where can I buy a Y8 cam cap?
- Custom Sheet metal guage cluster question
- Need Interior Help
- fuse 44 blowing, failed ECU?
- Help finding legit fog lights for eg civic 4dr 94
- D15b for a d16y8
- Power Windows/Motors
- 97 Civic Seat Rail Removal
- 92 Civic HAtchback - D15B7 problems
- EG hatch/b18b1 swap - map sensor question
- Best Head: D15b single Vtec Vs Zc Sohc Vtec Vs D16Z6
- D15B7 Crank Bolt
- '97 Honda Civic DX Sudden loss of power and stiff steering
- Condensation on bottom of air box. 97 civic
- Budget gsr
- Re-ring?
- 1993 Del Sol AT to MT tranny mount question?
- D-Series combination for my Civic 1995
- help to prevent spining rod bearings
- 1993 Del Sol S - Crank no start
- How to start a new thread in a Honda-Tech forum
- 95 Civic HB Window motors slow. Can't figure out why **Fixed**
- Speed Sensor Replacement
- 99 civic - Accessory socket not working (not fuse)
- 2000 b16 head cam cap - bolt size?
- Help !! - 1998 Civic Mystery Overheating
- Del sol a/c - r12 to r134a conversion question
- b16b eg - axle and oil leak questions
- Need some help with power windows, locks and mirrors
- Lower end block swap D16a and D16y8
- Trying to decide on shock/coilover setup? Help me out!
- 93 del sol take off issue
- JDM d15b part issues.
- Differences and reliability between all years of the 6th gen civic?
- Po135 po141. Battery light on and spedo nonworking please help
- 96 Civic failed smog test help!
- Electrical problem and CEL
- 1992 civic hatchback b series swap problems
- Compression testing 2000 civic
- 1997 Del Sol VTEC - Seeking advice on alternative ECUs
- Tach needle jumping
- EG civic hatch hood
- BWR subframe Brace and ASR sway bar
- Gas Gauge Always Reading Low - Not Filling Tank?
- What is this plug, 92 DX hatch
- 92 EG6 - ENGINE CRANKS BUT NO START
- 95 Del Sol Overheat
- 1998 civic AC installation parts
- Opinion on exhaust needed
- 95 Civic cranks but won't start
- Crank pulley keeps coming loose
- K-tuned pro-circuit b/d series fitment in 96-00 civics
- 97 Civic EX - Emissions test high HC and NOx
- Replacing CV Axle Driver's side need some help
- My swapped-hatch has been stored in garage for nearly 13 years.....
- will Fit seats fit in a 6th gen civic hatch
- My $400 97 Civic DX Coupe
- Mechanical timing on d16y8
- 97 civic fuel pump/relay issue. No power
- Squeaks & Struts
- 97 Civic with D16Y7 engine wont start
- Constant power source for ECU? 2000 LX not getting power
- 2000 DX no start
- 97' civic ex coolant leak and reservoir overflow
- Searching for a blue print or a list of assemblies for honda civic hatch eg
- EK Hatch DX Rims Questions
- Mini me swap with a auto to Manuel conversion
- EG engine swap questions
- 1995 del sol D15B project need help
- 92 1.5L 285k Miles. Tries to Start, dies instantly. (Solved)
- 92 Hatch Antenna wire hole location help.
- Spark Plug Tube Inner Rings Need Replacement...but what about the Bolts?
- b16a slave adapter size
- Civic 97 DX - CEL codes P1297, P0135, P1337, P0141
- Radiator fan won't turn on
- 99 civic ignition problems
- 95 civic 1500rpm sputter
- DIY: 2007-11 Si Rear Seats into EM1
- 97 civic dx hatch push to start/radiator fan wiring help needed
- EM1 - Need help finding throttle body coolant hose part number
- B16a del sol wont go over 2k rpms
- EM1 power window/locks conversion in an ek?
- 92 civic - Random overheating
- 94 Civic Rear Drum Conversion Kit - In a pickle !
- Which K&N air filter for a Honda Civic 5th Gen 1.5 LSi?
- Short shifter install?
- Del Sol pulling to the right?
- taillight corner parking light socket/holder part number
- RHD del Sol Project! Just starting, will continue to post updates!
- Front passenger door leaking
