View Full Version : Honda Civic / Del Sol (1992 - 2000)
- gsr hatch questions
- GSR Setup - Before Purchase Parts List
- eg hatch headlights
- 93 ej coupe...no brake lights or horn
- I bought an engine from Engineworld usa in Houston - www.usedjapanmotors.com
- 97 honda civic hx wierd jolting problem? help please!
- My EK3 setup
- not starting s.r.s.
- newb question about a/c
- h22a/92 civic wont start :/ battery installed backward by myself heh
- need help with ecu? wat P72 ecu dosent look for FTP???
- H22 CIVIC (EG) CHARGING SYSTEM PROBLEM
- EP SEATS??
- distributor question plz help
- how much is my car worth
- Need HElp - Disarm Clifford 3.5 With out remote.
- timing belt question
- b16 eg random cutting out while driving
- tranny seals for D15B
- LS SWAP NEED AS.... SEARCH DID NOT REALLY HELP ME
- CIVIC AC TROUBLE
- obd2-a or obd2-b ? for a 96 Civic DX p2e ecu
- EK Starting Problem (please help this is annoying)
- Just joined
- bad battery= bad gas (mpg)
- What ecu???
- Jerky steering?
- new here
- JDM B20B swap issues
- Sounds like my car is bogging out....HELP!
- 4.7 ITR Final Drive install Question
- Radiator fan not turning on
- help with price range...
- Timing Belt Question
- wiring gauge?
- I'm Stumped, Car Won't Start!!! Please Help
- pwjdm 3 pt frt bar fitment ek?
- blow by
- lookin for new turbo and need opinions
- NEED HELP, evap code
- 93 hatch k20 swap, advice needed.
- bah, another stupid wiring problem.
- 4PT Autopower Rollbar. PHOTOS for a 2000 Civic Si. EM1.
- need help on b16 turbo setup
- Window Problem**** Any Suggestions?
- will a DA short shift fit a EG
- civic rear spoilers?
- Stuck in Gear
- ES Hyper flex bushing kit install
- How do I Register JDM Cars?? Acura and Honda
- vx transmission
- I need some answers!
- Hellooo HT
- EG airbag question?
- is it difficult to change a d16z6 oil pan?
- boosted b18c
- update on my ej8
- will 97 CX front calipers/brake setup work on 92 VX
- help!! trying to figure wats the promblem of my handling
- need info about ref ticket
- D15B
- cxv
- Where are heat tabs at?
- Just pick up my new EK. check out some pics!
- d15 Eg to b18 Eg swap...what shift linkage???????????
- REVING Problem...on D15Z1 motor...PLEASE HELP..!
- im having touble starting my car, ANYONE HELP!!!
- Plastigauge Measurement Question
- engine need to be out for lsv conversion? socal shops?
- clutch help
- 96 front bumper into 99 si?
- 1997 Civic (EX) - Dash board A/C panel convertion
- Is this worth anything?
- apexi vafc wiring hell! help me
- BUDDY CLUB FRONT AND REAR CAMBER KITS
- 1500 RPM stutter
- PCV Valve Idle Issue
- idle problem. help!
- 1995 Del sol Si - Very high clutch release? Adjustable?
- How much is this car worth
- Check engine light on 97 del sol, engine laggy
- 1993 si No Power
- Y7 Cracked Header Questions, O2 Sensor Placement on New Header?
- my CEL doesn't work
- Seat Harness question
- would b16a2 headers fit b18c1
- EXHAUST HELP!!!! 92 lx swap
- 96 civic ex VSS problem
- Timing question
- Cant figure this out... help please!
- BAR help please..
- cars been sitting now won't start?
- my em1 got broken into......wt should I do?
- Power window conversion on 93 civic hb
- Car doesnt show any signs of electric?
- any suggestions for my b18b1
- car wont start
- anyone know of this **streetstyler.com** ??
- 95' Del Sol rear window noise problem is driving me nuts....
- corner lights on
- Timing belt broke while driving
- Boosted automatic delsol, Trans ?'s
- License plate relocator EG Post em
- What other civic doors will fit my 92 hatch SI? help
- 6 ECT - water temperature sensor
- 5 Lug front wheel bearings keep failing...why?
- ac compressor clutch replacement
- Bad Brake Master Cylinder?
- Wheel Offset on '98 Civic - FIT OEM Rims?
- Water oulets size??
- Bad Wire
- How would i plug a set of injector holes?
- 01 GSR intro 93 hatch
- fuel pump not turning on
- Valve guide replacement and grind.
- are both torque mounts the same??
- got an ek/eg question. looking for answer.
- Timing help on honda civic
- tokico/tein setup-will it fit/work on my 99 ex
- Turbo Civic Wont start?
- Which engine should I buy?
- HONDA CIVIC '93 DX COUPE "IT STOPS SUDDENLY WHEN IT'S HOT"
- ECU question, please help!
- Re-pinning the primary O2 sensor in OBD2B Civic....
- How to replace light bulb indicator on my dash board
- fabric interior
- Car Shaking 55mph+ (Searched but no definites)
- Searched - Wiring Question
- Replace Passenger Fender?
- Car is dead and has no power! Don't know where to start
- How similar is the del sol to a civic suspension/brakes etc ?
- noise coming from rear end of car
- Tokico shocks/struts
- *** injectors not firing*** need help asap
- Has anyone converted an 88-91 EF to OBD1? No, Seriously
- HELP PLEASE!!! Timing problem or spark plugs or cams or what!? help?
- CEL code 16
- Emergency ac bracket question
- JDM D15B VTEC DIZZY
- Problems with IM & TB. UUGGHHH
- I have a question about Eg Mounts!!
- A/C blows cold sometimes and hot(not cool) air the rest of the time.
- tanabe exhaust problems
- where can i buy an OEM style del sol hood?
- Will my 1992 cx hatback pass smog with d16z6 ex motor
- vss
- Aerodynamics that work
- d16 zc rods questions
- My brake lights won't turn off...already bought the switch
- Do 93 civic sedans come stock with plastic speaker surroundings?
- timing belt from advance?
- Help?
- k series
- this may be a silly ?
- WHAT IS THE BEST B-SERIES ENGINE TO PUT IN MY 95 CIVIC EX
- help on my 96 civic hatch ride
- Bad trans or Bad axles????
- How Do I Adjust My Seats
- 2000 itr brake caliper on a 99 civic si...need some help!!!!
- eg dash conversion to itr conversion
- cooling problem
- oem clutch and fidanza flywheel?
- venom chip
- skunk2 intake manifold
- WTB. civic si cluster
- light size?
- which car would you rather have
- I cant get the CEL!
- MISFIRE what are the chances of a having a bad coil and or bad igniter module?
- what is it that makes that sound coming from the motor... it makes it sound like....
- wow buddy club spec 2 exhaust
- Projekt-sol !!! (build thread)
- Is this worth it at all?
- please confirm Dual Core Radiator for 1992 Honda Civic CX hb
- B16 Cylinder Sleeve
- Name These Wheels!
- Back up lights not working. I get power at socket but no light.
- turbo manifold
- 96 cx hatch power window conversion help..
- is compression of 150 good?(all 4)
- does having gas mileage increase gas mileage?
- Still Having Idle Issues (VACUUM LEAK)
- tri-y header installation help!!
- Hydro to Cable
- CoilOvers
- car won't drive pass 3k
- built d16y7 any good??
- A/C problem! Full condenser but no cool air.
- civic hx swap?
- Blox intake manifold question HELP!!!
- Limited Slip Differential is very noisy. is this normal?!?!?
- subframe tear out, just happened, awesome.
- b16a2 or b161b?
- JDM Type R Distributor and Timing Questions?!?! Please Help!
- Ek Power folding mirrors bench test
- 205/60/14 tires?
- Driver seat bolt cover
- 00 Si
- help out.
- rear seat cover thingy
- is it good to have a straight pipe?
- eh2 w/ b18c - idle/backfire issues
- Removing Deck (or dash) on 92-95 civic
- need help with tranny
- ls v-tec head gasket leak...need help
- AEM Wide band UEGO install questions
- Rear Disc Conversion Questions...
- Where is my primary o2 sensor harness?!
- Timing marks / no bottom cover
- b18c1 in limp mode
- d15b swap (5mpg) WTF??
- odometer doesnt work
- b20z hitting hood.
- car won't start after sitting a while?
- Loud knocking noise when braking ?
- DIY: VTEC Indicator light
- fuel pump problem
- VTEC solenoid - engine burning oil
- HELP with my sohc
- battery or alternator problem?
- cooling fan 94 honda civic dx
- 99 LS in eg idle and MPG problem..gas prices got me STUCK!!!
- First Post - looking for advice on CX to VX conversion
- gsr in a 99 ek...
- stupid cel please help
- head build ?
- radiator doesn't fit right (pics inside)
- No Dash lights after installing Sony stereo in 1999 Civic
- cruise control fuse
- Exhaust systems 94-01 integra to 98 civic hatch
- 4dr eg door problem
- need help about brake rotor
- oil warning light not working
- quick harness ? si & ex...
- is this a good deal on a del sol?
- car died, now code 21 and 41
- 95 ex idling funny when the a/c is turned on
- FUEL RAIL WONT FIT ITR MANIFOLD...HELP PLEASE!!!!
- Will a D16Y8 engine from an Automatic fit a Manual?
- don't tell me it's the headgasket
- B16 fitment from crx to 96 coupe
- 1000cc injectors??
- car has problems startings..help please
- short shifter
- Engineworld USA Sucks
- Is this car worth the money?
- can you reuse b16 head used on lsvtec
- Ek hatch with sun roof ?
- 2000 EX coupe, 100 + degrees outside a/c stops working - please help
- Help with Fuel leak on '97 Civic DX.
