View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Bad coil?
- major problems with rear disk conversion
- i need some parts. any advice.?
- b16 swap shift linkang???
- Lower rad hose
- Ex trans into del sol
- Need help please!
- XTD clutch... Need contact info
- Fog Lights.
- RPM's fluctuate when accelerating
- speedometer dont work
- what car did my tranny come out of???
- msd 2 step
- New Idle Problem Now!
- 99 civic stereo system?
- crooked engine, tranny mount?
- timing?
- Alignment question
- b18a1 swap
- ek wing question
- what will it take
- Need some advice and opinions for my B16 that is currently being swaped.
- tps
- So I just took off my front bumper and a part feel off...?
- Need help with my EK9 CTR cluster...
- quick question on a crank sensor
- I want to convert my auto tranny to mannual?
- how do i get more power out of my 93 civic without converting to manual
- my engine an oil light won't cut off
- power window slowing down when going up
- jus bought a 93 civic coupe
- How to check the Y21 tranny fluid level
- NEW HERE
- LCA'S/ T BRACE FOR SALE???
- LSD
- 1996 EK9 GSR gauge cluster????
- d16z6 to b16a swap
- Need Help!! GSR prob....
- how can i fix my mirror
- Need fuel pump help asap
- Anyone seen these? SARD TCV (Torque Control Valve).
- Torque Specs for GSR rods and mains?
- acura integra gsr shiftlinkage not fit on a 94 eg hatch with a gsr
- Question about sleeves?
- JDM Headlights
- Cluster doesnt work??
- quick stupid question
- b16 tranny rebuild
- Oil consumption/engine problem
- Emblem questions.
- Have questions about JDM B18C.
- wut should i do...
- Car Vibrates When Shifting.
- is a b16 dip stick the same as a b18
- gsr brake swap
- I NEED HELP
- state ref
- my car is throwing a code 15, please help
- usdm b16 compression?◙?
- my new 1992 EG with nothing but a roll cage and some suspension
- wire problems
- What Cam to put in my R
- Swapping D-Series, How Long?
- Fog lights
- tail light problems
- need pinout for a 1997 integra ecu and a 1996 civic cx
- H23...
- TEIN Basic Type Coilovers
- EGR Valve...Do I have one?
- Can you switch to synthetic after running regular oil?
- Help! Overheating, then surging idle... 95 Del Sol S
- over heating
- smoked headlights... need help
- Cooling system PSI??
- Z-series autometer inop -- rough idle
- VSS problem
- Need Help
- tire rotation
- Fuel Injector Flow Rate
- Is this 92 Civic a good deal for $1k obo
- Anyone converted from 3-wire to 2-wire IACV?
- inside front door panels from 93 si fit into
- anyone know where to get these tail lights?
- ready to boost??
- Question on drive shaft for 1992 Civic
- b16 swap
- STOLEN MILANO RED HATCH OTTAWA, ONTARIO, CANADA
- HELP!!! Can't post pics of clean ass hatch!!!!!
- advice on lowering
- ? bout GSR console fiitn with Civic Hatch
- I want to put a K20a lump into my honda civic em1 coupe 1999 b16a2.
- Buying an SI
- Help intercooler
- temp oil plug
- Acura 1.6 el - annoying rough idle
- Thinking of buying a hatch with 180k miles
- I WAS SO WRONG!!!!!!!!!!!
- anyone near richmond wanna get interview for a documentary!!!!
- help help
- Dents and falling bumper
- My Windows
- can any one help with timing
- were can i buy a d16z6
- turbo tunning, help guys
- throttle plate/carb cleaner
- wastegate help
- 1996 del Sol fog lights?
- which turbo is beter???
- FOG LIGHTS for EG
- wiring fog lights to headlight warning buzzer?
- What caues a warped rotor
- need help changin cv/joints
- anyone know this site?
- replacing radiator hoses ?
- Infamous stereo code
- K20Z1 SUPERCHARGER EG
- civic swap
- Civic Beginner
- ws2 muffler
- need help answerin my question
- Starter Problem just exchanged nothing!!! D16Z6
- Moving seats from left to right.
- What is the best front camber kit?
- how do you get your car BAR'ed?
- Can someone link me to a thread that troubleshoots startup?
- BEST UPGRADE for the money? For a 98 civic LX
- vtec problem
- too much pressure in cooling system
- 98 civic LX manual trans- grinds only going into 3rd gear
- 94 LS into 98 HX coupe?s
- Putting front end back together, How to reinstall? (Couple of pics)
- D15b, tastefull mods
- Can I install a EF rear disc brake conversion on my 93 hatch?
- see some smoke's after i changed the spark plug wire's wat's might be wrong?
- how do you install a oil sandwich plate
- where can i buy a supercharger from?
- Help car's on but wont move!
- head bolt torque specs!?
- EF needs your help
- Anyone know what kind of LCA i have?
- eg with b18b1, harness Q
- turbo
- 99 honda civic si manual
- streetstyler
- Anybody want Z3 fenders from my '99 SI?
- Removing Door Handles
- lung bolt question (searched)
- EK hatch GSR
- speedo help
- d15z7? or d16z7?
- Knock Sensor?
- HONDA CIViC QUESTIONS
- TPS replaced, Same probs occur
- hatch with gsr
- Need Help
- MAP SENSOR ISSUES!
- is this turbo kit worth the money?
- just changed my brakes and makes noise?!?!?!?!?!whats wrong????
- CRX Wheels.. Got images ???
- just got my y8 swapped into my 96 dx
- Fuel
- PLEASE HELP ME!!! Brake Conversion Question
- d series trans question
- Just installed new type-r cams
- d16y8 into a 94 civic hatchback
- 92 Civic Ignition Switch problem
- d16y8 into 94 civic hatchback
- B16a swap into automatic
- 99 civic tranny in a 95 civic Dx Does It Work??
- whtie smoke, has sluggish feel when pushing gas...
- How tight to torque
- I need help but dont know what this part is called
- DIY Tps replacement writeup.
- Making a CF Bezel for s2000 Cluster in EK (Help needed)
- anyone done a poormans type r
- Help... steering wheel vibrates with new wheels at 110km/h+
- Just rebuilt my motor vtech 2000 honda civic 2000 1.6 liter
- just a quick question on which wires is where on ecu (crank sensor) d16y7
- si transmission
- ECU chipped VS. NOT
- A simple Question need a simple answer
- GSR swap... Now having speedometer problems.
- d16 - b16 engine harness question
- is my ej1 rare? 11.5" front disks and LSD
- STRUT BARS
- Turn signal bulb help
- car shutting off when idling in first gear! help please!
- del sol si brake upgrade
- help ecu cel light!!!!!!!!!!!!!!!!!!
- question about knock sensor
- HELP! car shakes when step on gas
- Turbo Help
- lookin for eg coupe
- 94-95 gsr wire harness and 2001gsr integra wire harness
- are EG si rear brakes the same as DC2 rear brakes???
- well i'm a newb with a trim ?
- can a 2001 obd2b ecu be transformed into a 95 gsr?
- HELP!! OBD1 B18C1 into Civic VX Wiring
- Axle pops out of tranny only on passenger side ..........WHATS THAT MEAN>>
- Is it possible to BAR?
- ek chairs
- B18A1 SWAP
- The Dreaded Word: 1/4 panel patch kit
- 94 civic vx harness vs. 94 civic ex/si harness?
- removing roll cage
- TPS bad?
- wheels
- a/c line question....
- is it vtec??
- Brake/Rotor Help
- 205/50/16 tires?
- 92 DX Dashlight Problem
- Power Steering Pulley Wobbling?
- Security
- h brace torque specs
- Removing Drum Brakes
- Z6 head on a Y5 block.. I have a few questions. (Searched)
- Whats the price on...
- vin number civic hood question
- d15 or d16 turbo calibration
- Is this the cv boot that just went??
- Oil pressure issue. Need a couple extra brains.
- what fluid to use
- Replace IACV or entire throttle body?
- Vent Fan
- wiring
- Hondata Intake Mani Gasket
- L@@K Can't figure out what....
- Suspension
- car not running need help pease!!
- main relay
- question about offset in a 00 civic?
- need some input looking for a quiet muffler
- new ur opinion for trade offer! thanks
- LSD?
- no back lights???????
- update: on ek auto transmition "check engine light code"
- Suggestions for...
- Sick of projectors, going back to stock.
- how do u rewire or repin the b16 dizzy for a 98ex wiring harness
- 94 ex coupe into 94 cx hatch
- front end conversion
- need some help with my cat
- ac not working well.....
- DC2 integra front end to eg civic hatch
- is unbolting the exhaust bad???
- catalytic converter please help!! obd2 2000 si
- tps question?
- is this guy legit?
- oh damn, i think i'm F***ed
