View Full Version : Honda Civic / Del Sol (1992 - 2000)
- honda acura obd2 turbo easy question
- D16Y8 VTEC?
- How much should I py for a 100k plus d series transmission.
- input/feedback on new swap?
- will a auto d16y8 manifold fit on a manual d16y8
- EM1 SI WIRING AND A/C INTO 98 EK4 HELP!!!
- What makes this happen???
- b16 headgasket for boost
- Help understanding swap
- Radio Difficulties...
- d16y7 turbo question need help???
- swapping seat pans
- radiator hose question?
- right axel poping out>?
- will prelude calipers bolt on to my ek
- Degrees in tru-time adjustable cam gear
- greddy evo 2 exhaust or spoon sports full exhaust????
- factory keyless entry
- back brake conversion on my ek
- Trunk Light
- quick clutch question
- ASR 24mm Rear Sway Bar
- got a few questions would like your opinions
- Trunk Light Won't Turn on
- 92 civic hatch cx
- vafc help please
- d16z6 in ek pass smog?
- no heat need answers.. please help
- fast blinker 96 civic hatch
- Information on importing a car from Japan
- wat a new year already.. party on
- WTB: EJ/EK HATCH 96-98 REAR TYPE R LIP
- P28 and ECT sensors/plugs
- how do i make a light blink?
- speedometer needle randomly gliding up. not revving up though
- H22 swap question...automatic
- Check Engine question...plz help
- Engine swap question?
- Fog Lights
- where can you guys get flare wrenches from for your brake lines?
- Center Caps question
- Got a 96-00 center console to fit my 92 Hatch Tell what you think...
- rear door lock problem
- skunk 2
- help me!!!
- Del Sol VTEC brakes on 92' Civic CX, questions..... searched no luck
- i dont understand....
- DOHC swap or fully built D16?
- can 97 HX harness work with 00 DX chassi??
- h2b air conditioning
- Timing Adjustment help plz
- 98 itr cam
- eg interior ?
- Pic Request.
- Auto to Manual Conversion Mount
- cx swap to d16z6 help!
- Will 92-95 4 dr hood fit 92-95 hatch?
- dash removal - heater core
- 98 civic hatch oil pan removal/installation
- Alternator~HELP!
- '92 VX won't turn over, unplug fusebox connector and it cranks but no fuel/spark
- auto tranny question...98 work in a 93???
- WTB: 96-00 civic arm rest
- emblem removal question
- honda s200???HELP
- 94 del sol: super rough ride.. characteristic of car, or blown suspension?
- Del Sol meet in Jax, FL on Feb 2??????
- HONDA DEL SOL MEET IN JACKSONVILLE, FL!!!!!!!!!!!!!!!!!!!!!!!
- Hard Gears
- Honda 99 civic lx cd player e-00
- Exhaust for a 94 civic???
- Bad overheating problem...
- Broken diff? bent rim. axles???
- Going From Disc to Drum... Possible?
- Would you guys trust this?
- Engine supply?
- who lets their car warm in the morning
- About once a week..
- Need help deciding what motor to swap on my 93 coupe
- I searched Everywhere I need help on removing my Abs
- quick b-series questions
- WIRING ???'s PLEASE HELP ASAP!! need info so i can get my car running!!!
- oil pressure gauge
- need help what goes here??
- Rear disc swap? Can you put 90-93 integra rear disc brakes on a 95 civic cx hatchback???
- LS
- b16 swap speedometer not working, no vtec, CEL please help
- Burning Rubber Smell????
- Wont Start
- PIC REQUEST: EG+EK Side Skirt+EG Mud Guard??
- dash question
- P06 ecu on ls motor?!!?
- 1999 civic ex b16 swap
- High voice from the engine ( Video )
- going turbo
- 100% octane fuel
- Rubber smell on freeway 70+
- Windshield wipers
- Primary oxygen sensor
- 03 civic steering wheel swap into 94 civic?
- Timing Belt?
- 2 door interior in a 4 door?
- Need help on wiring vtec!!!
- Who here runs their ek or eg civic in the snow and have no sign of rust
- windshield wipper switch problem
- B20 Vtech
- fog lights on ek
- OBD? injectors? which year?
- B18B1 swap help
- 99-00 HVAC contols, radio bezel
- ok another d16z6 question
- did compression test - should i be worried?
- Civic CX
- obd I motor into obd II car
- can i use an obd2 gsr harness for a b16a2 swap in a 98 dx ???
- turns over,wont crank?
- aftermarket cams worth it?
- need help!! car wont turn over after auto-man swap..
- skunk2 pro s series coilovers
- Help i need some Opinions!!
- Your Opinions about ebays clutch sets?
- does anyone know?
- JDM on a budget
- cx or dx hatch back
- having trouble
- Started my car that has been sitting over a month
- d16z6 wiring help
- Help car won't start.
- H22 INTO A EG HATCH
- Eye lids
- Need DIY for eg6 honda access window visors
- pressure plate bolts
- having hard time shifting gears
- need help with wires
- shaking/vibrating in passenger wheel.......
- intake manifold
- rustproofing
- Strange Noise
- had these cams laying around in the garage.
- jdm taillights
- y8 problem + obd2 d15b vs emissions testing
- help with speedometer and tranny lights
- ls and b20 questions any1?
- b16 differences
- lca's which ones
- !!!!! I Just got a 1996 honda civic And i need help!!!!!!!!
- 95' civic si o2 sensor
- how to wire up power doors
- D and B series tranny torque bracket compitable?
- Myth or Real? D17Z Factory supercharged engine
- Anyone Using LED Turn Signals? (Hyper Blinker Problem)
- cx wheels different than hx wheels
- gains from cam timing
- Soft Brake Pedal
- ECU guys, need your help, lost info. obd2 auto to manual
- Clutch stuff
- oversized valves?
- Swapping in a D15B VTEC into a 95 civic vx
- What gasket?
- need help on wath head to choose for my gsr block!
- HELP WITH FREAKING FOG LIGHTS?
- Few more questions about b16 and wiring
- ECU chip question.
- Screeching noise when driving from wheel area
- Location of ECU?
- Right Hand Drive del Sol - Floormat Templates?
- D16y7 -> b16a2 Knock sensor
- another swap kid.. how do i do it?
- how the hell does this work?
- how to change driver side b series axles on eg civic
- trouble mounting my ASR rear 24mm sway bar on my 2000 civic si
- wtb si blue wing
- Quick suspension question
- Fuel Filter Install
- Where can I get OEM fender lining for a decent price??
- Dome Light Rewiring
- I gotta leak
- Mufflers???
- Does anyone know CTR VTEC engage point?
- ls/vtec or cr/vtec
- Tune up questions - 97 Civic DX
- Is it working or not ?
- Padawan power steering removal kit instruction
- wtb engine
- Subframe Question
- 93 hatch hailed out
- quick question
- Jdm p2t vs usdm p2t ecu
- Rear Disc brake ???
- no valve cover gasket?
- removing ac/ps: is the EJ DX crank pulley smaller/lighter/different?
- have a question about engine rebuild
- Ignition key profiles??
- WTB: 99-00 CIVIC Si FRONT LCA's!!! full and complete please.
- looking into buying a 00 civic hatch
- oil leak....
- which would fit better?
- dnx adjustable coilovers???
- Mini Me Swap
- tranny???
- CEL
- Hay whats up....
- Clockspring question
- ticking\tapping noise
- can mis shifting cause you to blow your engine? skunk2 short shifter cause it?
- interior lighting prob... 00em1
- sportmax wheels
- h22 ecu
- Should i run b20b4 with a b16 head all motor or Turbo
- Need help with front bumper removal
- s40 code on trans??????
- axle issue
- Mods Help, Avatar Error!!!!!!
- Civic Exhaust?
- Helm's manual for 00 civic engine swap
- type r ecu?
- which headlights
- Throttle Body Help
- Radiator Qestion
- Tuning
- rear seats problem .. need help please
- Stolen Parts
- Door skins
- trans fluid question
- My 2007 Civic coupe project
- weird
- HELP!!!! Idle problems with swap!
- will a ws2 catback from a eg hatch fit on a ek hatch?
- B Series Cam Gears
- hi im new here
- v-tec b18c1
- Need a front bumper
- Got codes, need help
- ***WHAT PISTONS WILL BOOST UP COMP IN B20***
- 1993 civic Guage cluster question
- cams
- b16 transmission mount
- To Swap or Not to Swap H22a4?
- P72 ECU IN 96 D16Y8?
- dumb question... jacking up car + fitting jackstand.
- h22 into EG parts list check
- vtec issues
- video camera mount on harness bar....
- '95 civic owner needs help diagnosing car problem!
- are hasport mounts firmer and stiffer than oem honda mounts (B series)
- eg code 20
- front lower control arm thread stripped...
- What Is Tire Size For Civic Upgraded Honda Wheels For 92-95
- what do u guys think?
- How To Fix Dashboard Light
