View Full Version : Honda Civic / Del Sol (1992 - 2000)
- trade up
- fix b18b1 ls or buy b16 block
- power steering high pressure line going into rack wont come off
- rsx seats in a civic
- modified dx dizzy to work on z6(pics please)
- How to remove AC from an eg?
- d series ignition systems?
- ++ PICS GALLERY OF OUR EG's AND SOL's (NO COMMENTARY)
- minor scratches on CF hood, do i use 3m?
- got a problem big 1
- hmmm what should i do???
- speed sensor broke?
- No accelleration from 1/2+ throttle
- Customer got car jacked at gun point@street races.... parts found and thief caught!
- Pretty newb question: drain tranny before axle change?
- ITR seats in a EG......PROBLEMS???
- Air conditioning
- b18c5...best place to buy just the engine/tranny??
- Burning OIL HELP!!!
- Motor swap in SAN DIEGO?
- intake manifold....
- screwed on a cam gear?
- Cable to Hydro Tranny.
- si master cylinder?
- b-pipe question
- Tach Meter for an EK
- Know of somewhere less expensive?
- Swaping trigger wheels in a OBD0 B16 to OBD1 D16?
- is it worth getting ?
- ECU and VAFC
- p29 pistons in a d16y8?
- D series tranny differences?
- compression on my civic check it out..
- Timing Belt Honda civic 97, Any experiences ?
- engine problem
- b16 high idle
- OEM COMPLETE EK SI FRONT END SO CAL
- Any ideas what this could be?
- Vtec help
- i dont know.........
- Ground wire for a ITR
- Oil Leak
- How much does it cost to replace this?
- o2 sensor
- WAT TURBO TO GET
- Any luck with crankshaft pulley with strap wrench?
- my tranny sucks i want a new one, help please
- alternator problems
- Wiring Help...Someone Please Help!!!!!!!!
- I need some advice on an exhaust system.
- hondata help!
- MES (Memory Erase Signal)
- Omnipower coilovers: hatch and coupe the same?
- How do you deal with wheel rubbing the fender wall.
- no one has mugen hood pins, what the next best
- D16Z6 Interference Motor?
- NEED BRAKES, 00 EX, where can I get some rotors/pads???
- 1999 civic ex? vtec or no go?
- D-series oil pressure gauge *searched*
- EG Brake booster
- 99 si a/f guage
- Which Shocks Will work?
- civic chip
- p73(integra typeR)pistons in a b16a motor from a 99 si
- rear stabilizer bar problem? PLEASE HELP!!!
- auto to 5-spd swap HELP!!!
- I can't check CELs.
- experts...what do u think
- O2 sensor/air fuel ratio
- Del Sol Stealthbox
- civic got broken into!
- Bleeding the Clutch...
- question for Comptech oval muffler owners!!
- b18vtec vs almost stock d16y8 96 coupe , i thought i should get spanked!!
- Can ANYone Help ME please!!!!!!!!
- We finished installin a drag turbo kit and now problems
- I would love to buy an EG hatch, but IS SAFETY GOOD/BAD?
- need help
- srs airbag light on
- REAR DISK DELEMMA
- steering wheel shaking
- Exhaust question, Search is down.
- Will a 97 front bumper bolt up right on a 93 delsol?
- Help Tuning N/A Civic With V-AFC-II
- Civic Emissions FAILING
- eK hatch fuel system pressurization problem / idle problem
- Roof sealings Del Sol
- What kind of cams are these?
- b18c vs supercharged d15b
- b16 hatch vs mustang GT
- Help!>! Throwing code 22 (vtec pressure switch)
- [FAQ] How-To Prevent Your Doors From Rusting w/ Pics!
- Some pic's of my swap progress how am i doing?
- i'm so lost, eractic bogging, and surging
- axle question
- Pass side window prob?
- HKS DLI
- swap write up?
- Civic oxygen sensor swap...
- Map sensor code 5 Idles fine, then revs up and dies.
- Year ID on head?
- which clutch?
- stereo
- energy suspension shifter bushing set?
- GE sleeved/decked block
- Universal o2 sensor wiring?? help please
- Anyone Have a Link to D Series Gear Ratios?
- Crank Pulley on Ebay
- Newbie "?Regarding Auto -> 5sd Tranny...
- 99-00 si commercial??
- Weight of PAG compressor oil for 134a air conditioning?
- suspension
- obd2 dizzy with my stock obd1 harness
- any1 able to read japanese?
- What happens if your car is jacked and...
- How much does a D15b lsd tranny cost?
- I bought a Civic Hatchback
- widest tire on stock rims?
- bushing ?
- oil pan compatibility question
- New Brake Pads, Crappy Pedal Feel
- Oxygen sensor wires? searched
- Weird Tapping Noise From Front Driver's Side Wheel Area.
- del sol aftermarket aux lights wiring help?
- Best Way to Fix a Broken Lip?
- Think i found the water leak but........
- Low/Sinking pedal after rear disc swap
- b16 powerplant question
- can some1 help me out with 1 piece headlight install...thanks, quick questions...92 hatch/gsr
- Woe is me.
- vtec controller?
- How to clean intake manifold
- what fuel system componets should i use?
- HELP: 96 ls turbo is not boosting
- Rear disc conversion
- will this work?
- When i turn on my AC and lights, the idle goes far below 1000rpm, like 700 or sumtin..and then my ca
- help search and no luck
- Car doesn't start all the time...
- HELP: Headers too short...!!!
- Noob Queston on VTEC Controller
- EG B16A.....Turbo or NA??
- my car is sputtering, please help
- where to find used transmissons?
- CEL HELP!!
- where to buy AEM hybrid intake?
- h22a Swap!
- oil disappearing (search no help)?
- Help? What color are the wires to your IAT? 95ex
- Del sol Leak
- EG rear disc conversion for EK
- vibration from the rear tires ? plz help
- Oil Dipstick???
- Proper Proportioning Valve
- itegra door panels in eg civic hatch???????????//
- anyone have a 92-95 CIVIC HATCHBACK turbod with the d series motor.....?
- CAR WONT START HELP!!!!!!!!!!!!!!!!!
- Duffer HX needs suspension tips
- seat won't stay up. keeps reclining....
- ecu choice
- Installing a stereo in an 01 civic RIGHT NOW.. need help
- **HELP** MSD ignition ?/Problem
- wtf?!?! steering wheel hub wont go on!!!
- WTB: Civic SI Wheels 4x100 any year
- Ek coupe with GSR engine swap- Need help
- Removing belts for power?!?!
- question bout minie swap
- I'm not a newbie i swear, haha
- Anyone have 99-00 SI rear endlinks? I need measurements!!!
- del sol... door question
- any changing fuel filter howto's online?
- Car selection
- Where can I order a mandrel bent axel-back pipe?
- will a 96-99 front end fit on my 92-95 hatch
- CA-B.A.R. questions.
- Cam gears
- throttle body help
- P2E ECU run a B18b???
- Fuel pressure probelm I think.
- Starter Kill switch?
- Got ground controls near 19382? I need to borrow your height adjustment tool
- Anyone done engine compartment wire hide?
- Civic Instrument Panel
- Painting an CF duckbill spoiler
- Weird Problem when starting
- Problem on REAR tires!
- Speedometer problems.
- header info
- EX tranny
- NEED FAST RESPONSE... oil pan issue
- What is stock exhaust size on 98 EX Vtec VS 97 LX non-vtec?
- Spacers!!! (For hood)
- Clutch Suggestions......
- Civic coupe fog lights
- Mounting Gauges in Dashoard
- poping out of gear
- What motor does this header fit?
- B16a feels sluggish??
- MORE VAFC2 HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- IMO: Oxygen sensors. What Do you think?
- Improving braking without rear disc.
- Whats next?
- Backfiring
- which car? searched*
- Wuts the best Cat-back system for a 96-98 civic ex?
- Anyone do paint in socal?
- good deal? also delsol/civic interior swap..
- obd2 chipped ecu please help
- Cam Seal Leak and Intake Manifold Gasket
- Input shaft wear (big deal?)
- Which springs are front and which are rear?
- plug wires?
- anyone in the binghamton ny area???? i need help
- New Ride: 1993 Honda Civic EX Coupe
- sol bulb clusterf**k
- Inquiry about shift linkage: B16A2 into 93 Del Sol Si
- high flow cat vs. stock?
- LSD
- relocating sol corners
- CEL code 45.....cat needs replacing...just replaced O2 sensor....HELP!!!
- is my engine Vtec or not ?
- Where can I get the mounting hardware I need?
- Keep D16Y8 or swap ?
- Help needed with my Del Sol Si
- Car won't start after clutch, Intake Manifold, & Turbo Manifold Install
- legend brake upgrade on 2000 civic ex
- Question about CTR's and HID's???
- Black Plugs --> SMOKE?
- coilovers vs shocks/springs
- Ebrake not stopping hard enough?
- Stock internals boosted with proper tuning?
- installing boss quick release? help...
- electric shock
- Not low enough????
- Help, I've got some rattling from my crankpulley.
- WTB civic Taillight Driver side 99-00
- would a 4-door hood fit on a hatchback?
- clutch question??
- Problem with sway bar
- <<<<<<<< ek4 climate control "light" question >>>>>>
- How often to start car when in storage? advice?
- E-Brake Question
- OBD1 v.s. OBD2
- idle problems
- nitrous nozzle position
- how are my spark plugs?
- Catback off an 99 si fit 99 hatch?
- 2nd gen integra rear disks on eg civic?
- Gsr distributor question
- mud/splash guards on CTR?
