View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Shift Linkage Problem??
- What kind of wing is this?
- Installing DSM 450cc Injectors.. having a couple problems
- tools for engine swap
- cars bogging no check engine light
- EK Side Markers... ADONDE?
- How to swap a ITR cluster into a 95 civic hatchback
- Mugen Front Lip?
- Good Drag Springs.
- K Sport Coilovers... hmmm?
- just did a compression test on usdm h22a1, readings
- Power Mirrors Relay
- whats this sensor or valve on b18a intake manifold
- help1 1995 civic ex is DEAD!
- Fuel Pressure
- Oil pan gasket?
- Integra Type R head In my B16 block
- vtec wiring in 92 cx
- whats the point running no lower timming cover?
- Car Sputters badly then turns off !
- Perfect Swap DC cluster into EG cluster*Help*
- Recommendations on potential engine swap...want YOUR opinions..
- Replacing doors, ignition switch and keys
- hey, how much does it cost to bore?
- Intake for ITR TB?
- New wheels and tires, alignment?
- (searched) steering wheel stability
- 97 Civic Strange Noise
- Installing powerlocks with FACTORY keyless entry on 96-00 Hatchback????
- timing belt cover!!!!!
- Bit Of Help
- Vacuum hose on intake manifold
- 92-95 civic 4 door vs 92-95 hb or coupe. ??????'s
- wiring harness
- Lining up the front fender
- Best head for my setup???
- GS-R calipers on EG
- y80 tranny..what is it..
- 5th gen trim level questions
- wrong engine mount?
- i have bad luck with cars.....
- Need Engine Info On d15b
- How to remove pistons/rods?
- Questions about 2000 Civic Si
- how can i make a d16y7 v-tech with out replacing head?
- spring install question
- what parts should be used?
- 96 civic weird light dimming while driving
- Help Diagnose Please! My EM1 is rattling like crazy.
- BOOSTED MINI ME???? RELIABLE????
- need help in ls swap
- Headlights on an Eg
- wondering if wiring and mounts are going to be the same??
- Brake problem
- HELP: air/fuel guage stays on lean side.
- Blower problem - Only Hot Air coming out of vents.
- b18 swap help
- OVERHEAT HELP!!
- civic rear speaker cover removal
- 1" master cylinder and 40/40 prop valve question
- Rer motor piture request *PLEASE HELP*
- new steering wheel need help
- 95 ex coupe b16 throttle cable
- How do you wire up the resistor pack to an ek harness
- BRAKE LINE
- What do you guys think about this???.....
- weirds sound deadening
- gsr swap affirmative
- which tranny is better for my b16a2..
- ls tranny in B16a2..
- what are the timing specs on a b16a
- Schematic Diagram
- Trans for '99 y8 (boosted)
- PMTR in an EM1
- NEED HELP
- Vitara piston install question. Need opinions...
- Squealing noise from driver side wheel
- jdm eg6 headliner
- 2K Rpm Idle normal when cold / starting up?
- popping in front end
- ideling question
- Electrical Problem (please help)
- gsr alt on a b16a2
- needle broke on gas gauge on si cluster
- swap k20a2 in ej9-need help !
- skunk 2 lowering
- 1998 Civic EX + $6500 = ?????
- Rear disc brake conversion
- 92 civic cx.. lug pattern?
- 96 Civic Sedan with Eibach PK springs - need to increase ride height
- Dropped a fucking bolt in the head!
- PCV black box fitting size D-series
- ground clearance
- check engine light on a 98 ek
- can someone hook me up with a carfax
- want to know i f i can fit these tires on my si
- how lond will i be a trail i wanna be a member!!!
- tranny help
- 96 civic ex 5 speed code d16y8
- 96 wiring
- seats?
- appearence ??
- leaky tranny
- cross member
- Performance & Other Upgrade Questions (n00b)
- need help on which motor to buy, best for turbo?
- need pic of d16y8 vacum and hose to finish the swap
- autometer guages
- JDM Sidemarkers from EGs fit EKs?
- VAFC2 95 civic hookup question
- Will this catback improve gas mileage?
- EG h22 clutch swap NEED HELP??
- Creeking on the driver side.
- what cluster to swap?
- I have a question about pricing,..
- Quick question...
- 99-00 Wing and 97-00 Integra Wing are they the same>?
- Any cool antenna's for a 98 Civic HX?
- help a newbie please (engine convo)
- Do i need a evaporator?
- help...can't post...somebody post for me please...
- gsr clutch install
- 92-95 civic gas door
- How much are swaps these days?
- ECU swap?
- idles like a subaru
- intake?
- car starts up and then shut down
- b20b swap what next...
- Will a 96-98 ek hood fit onto a 99-2000
- turbos
- Wiring headlights for EG6 Civic 92-95
- Automatic or do a Manual swap..
- OBD2 p75 ecu on d16y7
- Progress Coilovers
- WTB: 99-2000 civic style bumper for a 98 Ek bumper
- CHIPPED P28
- b16 a/c question
- Gauge pod idea!!!
- will raising the compression ratio affect smog?
- problem with throttle positioning
- tired of my bumpy ass ride...help me!
- Kill switch help
- Problem on my 1992 Civic DX Sedan
- P75 vs P06
- 1999 hx timing belt
- msd cap, rotor, coil
- when to change plugs and wires
- EG6 Civic 92-95 horn won’t work; aftermarket wheel
- bog??
- Manual Steering RACK conversion...
- finally my s2k ap2 cluster is fully functional
- ek rear lca's??
- how much are toda flywheels? and are they good?
- 96-98 DX Harness wired to VTEC engine???
- Snapped Cam Cap Bolts!
- need opinions
- NOOB question can you put ac in side a 1994 civic hatchback cx
- Time to stiffen up my car...(H-Brace)
- tq head bolts?
- ODD VSS issue
- car died then started right back up. Need insight
- got this y7 block and z6 head what to do?
- HELP- knocking noise from engine bay
- Radio Code Help
- can some one help me out need this on the road
- del sol fogs
- Where does this hose go to? is it important?
- Reverse Glow Gauge
- Will WS2 Muffler fit on N1?
- Question about bearing clearances...
- Bottom caliper bolt is REALLY tight
- HELP... my car wont start, and im at work. =[
- 00 civic JDM B16b CTR swap.
- o2 cesor making car cut out??
- What springs for a sedan?
- brake light help please
- sold my civic
- high horse power
- drivr side e-brake not workng
- Uneven suspension
- problems with cel code!!!! please help
- Where to buy door mouldings??
- ECU for a Honda Civic Dx with a B16a1
- Soooo bad
- Cruise Control Vacuum
- the complete suspension kit?
- d16 vs. b16 vs. b18c1 vs. b20/ls tranny vs. si tranny vs. gsr tranny???
- Part # for jdm EG/EJ1 jdm window visors....i cant find it....
- CEL code 70... AT malfunction
- Need Help Installing a JDM D15 into Civic
- anyone know where to get Philips X-TReme H4 bulbs in the u.s.????
- sideskirt installation
- b18b setup in 95 del sol
- removing back seats from 95 civic ex
- motor bogging out.
- located were????
- fastest muffler fix
- 75 or 100 shots of NX
- fuel injector leaking safe to drive?
- i need info about sir tranny...
- Radiator
- need help plz answer!!
- gsr with itr cams jspec 00
- post pics of 4 door civics
- What does EK stand for?
- Front End Popping sound...
- Electric load detector?
- Will ATS final drive fit in VX transmission ?
- newbie
- SIDE SKIRT REMOVAL
- '92 cx steering rack in a 95 ex?
- cleaning my tranny
- should he buy it?
- Is it possible to convert my 00 cx cluster to an ex cluster.
- HELP WITH MY Radio WIRE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- doing swap in friends g/f's car need to know...
- headgasket troubles
- Car will not turn over?
- Civic VX Automatic?
- Car dies ocassionally and won't start for 5 min
- camshaft & crankshaft seals
- vss vs. cluster?
- ABS Modulator
- newb question
- catch can diagram, would it work fine ?
- bottom-end rebuild
- Need Help With Power Steering System of a 99'SI
- Need Help With Power Steering! 99' SI
- TEIN STech Springs - Cut
- gas light
- 96 civic tie rod end
- STEERING suggestion?!?!?!?!
- Can I put driving/fog lamps in the bumper/air dam of my 98 Civic HX?
- civic b16 p30 ecu..
- Complete 95 civic ex coupe doors on a 92 hatch cx
- HELP!!! Changed battery and dont have code for stock radio
- Removing cams, slid timing belt off?
- 99 si won't start, help me out plz
- Is there a way to change the way the brakes feel on my 98 Civic?
- Really need help!!!!!!!!!!!car won't start
- quick question ...
- Wanted 1998 civic ex oem CATALYTIC CONVERTER
- car grinds in gear?
- b series engine mount question
- Overflow bottle to radiator hose size?
- Radiator fan problems
- need help!!! swapped my tranny on my 95
- will 98 guage cluster fit in a 99 civic coupe?
- ECU Ideas
