View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 1998 cx hatch O2 Sensor and Vent shut off valve solenoid
- 1992 civic preloading on shocks?
- 500hp 10,000rpm b16a2 css block or darton MID sleeves
- Good options for sway bar with Yonaka exhaust?
- Violent redline cutoff at 7-7,200 rpm with b16
- Y7 block,Y8 head
- 1996 Honda Civic Sun Visor
- D-series close ratio gears vs. turbo setup
- B18c old rods, honda elders..?
- Banana Style wheels
- B20v NPT plug leak
- 00 civic won’t rev past 3500
- Can I use oem del sol shocks on my civic eh3?
- 97 honda civic
- DSM injectors without chopping wire harness? obd2
- 93 DX hatch wont Start D15B7
- factory spray paint
- 99 SI kill switch
- 92 eh3 idle problems after installing distributor
- body Swap
- Civic to Del Sol engine swap?
- Gear position indicator wiring
- d16y8 main bearing torque specs and sequence?
- 92-95 EX with B18C swap and kept accessories
- Ep3 seats in ek civic seatbelt solution?
- My car eco test fail ..37820-p28-g01 ECU is burn ..
- Need S-shaped exhaust pipe section only
- '95 D15B7 possible head gasket leak. Asking for advice.
- 9000rpm b16a head w/ supertech valves springs and retainers
- troubleshooting: D15B7 stock engine has unstable idle.
- Heating problems
- Are civic parts interchangeable with the Del Sol?
- Civic beeping with open door, no key in the ignition.
- Takata air bag recall.. 96-2000 - And other safety items discussions.
- 1992 eh3 was driving then died out of nowhere
- Transmission Fluid Leak
- Threw a rod in my 95 civic dx sedan manual transmission
- EG dash illumination lights not working
- Noise at 1500 to 2000 rpm after changing timing belt, water pump, 2 auxiliary belts
- 5000 rpm
- Del Sol Transtop Manual
- Exhaust system recommendations for 93-95 Civic EX coupe
- '98 Civic Unknown Pull
- P0325 code Knock sensor. Need advice.
- 95 Civic LX manual with a Code 4: Bad Crank Position Sensor
- No ecu signal to injectors 1,3,4
- Replacing only upper part of radiator support? 98 Civic EX
- 98 civic Bseries swap
- fucky wiring
- Trunk luggage shade for 96 Ek 3 hatch
- Slow idle and loss of gas mileage.
- B swapped Eg civic ECU troubles / question??
- 93 Civic DX Hatch M/T Oil Leak
- Timing belt
- Problems with idle 92 eg d15b p28
- HELP! B series block with trans won't turn over
- 95 Civic Oil on Spark Plug Threads
- Front suspension bushings
- B20b motor swap - 95 Civic DC - ECT sensor problem
- Inherited Grandma's 95 civic ex: d16z6 head and valve questions
- ek civic trunk leak
- Oil Catch Can Install / PCV Valve Delete Help
- Skunk2 upper control arms...loose steering
- 97 del sol b16a3 swap CEL code 14 IACV
- b16b fuel pressure?
- Main really bypass or hardwire with switches
- Wiring Confusion.
- 1992 eh3 rear lower control arms interchangeability?
- DOH!!! Forgot to reinstall the washer between the torque converter and flexplate...
- 95 civic DX sedan no start issue
- 3 bolt dseries post mount?
- 2000 Honda Civic will only push start
- EG auto to manual swap idle surging
- 94 Civic Engine Bay Fuse Box Electrical Schematics
- New Trunk Seal
- Timing a remanufactured head
- No crank
- Did I damage/ruin my transmission?
- 98 Civic need info
- Civic 94 ex brakes on a 96 civic ej9
- What engine harness can i use for a b18b1 swapped 1992 honda civic hatchback
- Replaced radiator & hoses, all hell broke loose! (2000 EJ8 -- P0505 and noise)
- 00 Honda Civic SI Surging on Throttle
- 1996 civic automatic to k20 manual ?
- My 2000 Honda Civic seems to be shortening out my coils.
- stock 95 del sol not starting
- Hey guys! Need more info
- eg wont start
- Daily driver Del Sol
- B18a1 ls with cable s1 trans
- Bad distributor?
- PLEASE HELP ME!
- 94 Auto to Manual, Need help
- Sunroof
- 1000+HP 8 Second AWD Build Thread // Humble Performance (WARNING Picture Heavy!)
- Help
- S300/P28 on a d15z6? worth it?
- Any differences in lower control arms?
- R12 to r134a
- 99 civic lx hesitation problem when motors warmed up only and through all rpms
- Suspension for a 300whp build?
- GSR Swap Help!!!
- D15B2 problems, considering engine swap with D15Z6
- No power in drive and shifts hard.
- Oil pump housing gasket??
- **Build** 1993 Honda Civic EX Hatchback
- ef horn clip part number
- 1st project
- Injectors for d15b7????
- Passing smog after engine rebuild
- 1997 Honda Civic Hatchback D16Y7
- 1992 eh3 cold start surging idle issue
- b16a issues/questions
- Civic won't start on damp weathers
- 2000 Civic front bumper allignment way off
- loud whine/stiff steering after replacing steering rack
- 98 Civic EX - Knock Sensor/02 Sensor
- SS brakeline question with EK Civic brake upgrades
- 93 Civic Frankenstein Y8 head swap
- How do I delete A/C? Can't find any bypass pulleys.
- '02 Acura TL J32A2 and Auto Trans going into '98 Civic EK - Wiring Help Needed!
- What size injectors and Fuel pump. Also a good (cheapish) ECU/ECM
- Del sol vtec smoke radiator
- Rear impact bar for 97 Del Sol, any other models work?
- 97 Del Sol P/S to manual rack, which steering u joint?
- 1992 eg hatch b18b1 swapped hiccuping
- B20 swap help
- 98 Civic Hx Wont warm up/ Weak heat
- Need help!! Doing a B20 Swap
- Side mirror help
- Help ID this sensor please.
- Suspension Sleeve Kits Thoughts
- Mirror Glass Part Number
- Help-22a1 4door ek swap
- What is this rattle? Help!
- engine swap issues
- Blinking CEl Light
- 1992 Honda Civic Manual Transmission Problems Diagnosis
- Gas tank protectors
- 92 civic hatchback b16a clutch issue
- Help !! Firing order D16Z6 (Solved) - Bad Dizzy
- 1992 eh3 what’s the other shaft with the boot right near the cv axle?
- Misfire sucks
- Ignition Switch Causing Fuel Pump Issues?
- Need help with my 1993 del sol with boosted d16y8
- EG rear calipers fit an EK?
- Strange knock/tapping sound
- Which digital clusters fit 96-00 ?
- 92-95 Civic eg6 cluster
- Del Sol to EG Civic Power Steering Rack Swap
- cel doesnt come on
- 2000 HX, wanting to swap in a D16y8, re-use harness?
- Looking for some help with a DelSol in Phoenix/Tempe AZ
- Tell me how if I’m wrong
- D15B7 head on d16y8 block?
- Sparco seat base question
- Ej8 Build
- Speed Problem
- Aftermarket suspension similar to stock?
- Question about Axles and Axle seals.
- D16 to B18 Swap
- high idle cold start
- Idles in neutral 1500rpm and now has cylinder 1,3,4 misfire
- 2000 DX Sedan manual transmission rebuild kit
- Is a slave cylinder boot supposed to have an incision on the side?
- Automatic transmission questions after swap
- C129 92-95 VX - Any connector on the 6th gen?
- Stock 97 civic
- Any Tips on how to remove the 32mm end axle nut while car is....
- Honda Civic Swap
- Cluster temp gauge not working
- 2000 Civic LS/Vtec EM1 build thread
- Intake manifold gasket leaking on second try.
- P0335 - Limp Mode - D16Y8
- Engine swaping questions
- 1992 EH3 d16z6 motor mount torque specs
- 94 civic won't go into gear
- Is tuning on chrom still a thing?
- 2000 civic z6 swapped p28 harness no spark
- Iacv opinon
- Would you rebuild with these compression test results?
- Need help on 1992 Honda Civic Si Hatchback motor mounts!!
- IACV Honda civic 1998 d16y8 a/t
- d15 wont start
- gauge cluster stopped working
- Intro and Newb Questions
- D16z6 turbo build
- 97 honda civic revs to 3k and wont go down!!
- Needing an opinion on piston swapping y8 to b7
- Will the exhaust of a D16Z6 work with a B16A2?
- Aftermarket quarter window trim?
- Sohc ph16 vtec exhaust mod
- '98 Civic DX issue w/ "fuse 15" (7.5a) constantly blowing
- New build! Okay to much mismatch info! Help
- 99-00 black si front lip
- New Project Car
- D16Z6 to d16y8 swap problems!!??
- Auto b16 swap
- Replacing heater hoses 2000 EX coupe
- Steering wheel play, perpendicular to rotation axis.
- Will 98 civic ex auto trans. work with my 97 civic ex engine?
- D16Y8 manifold swap high idle.
- Subframe brace bolt
- Master Control of Door Security
- Obd1 b18c gsr igniter icm help
- Electrical problem
- What gauge clusters and steering wheels are plug n play into a 99 Honda civic lx?
- Need OBD2 connector terminals
- 1996 Civic DX manual transmission issues
- Brakes going to the floor, white smoke from exhaust, sputtering idle when warm
- B20v i found golden flakes in vtec solenoid
- 1993 civic hatch calipers
- any advice
- B16 turbo
- Problem with clutch pedal
- Option connector slot fuse question 2000 Civic LX
- How can I tell if my s4c lsd transmission is a type R?
- Electrical problems
- 93 del sol s. K swap vs b swap
- Need help restoring my EG
- Left power mirror not working
- B18c cold start problem
- What head gasket to use for a 1995 CivicD15B7
- Just picked up a 2000 Civic EX Coupe! Need Pointers For This Project!
- Inner tie rod removal
- no threaded hole in my trunk for spare
- D16Y8 Burning a quart of oil every 300 miles PLEASE HELP!!
- 97 dx couple issues need help on
- Fuse #14
- Alternator fuse keeps popping stranded
- What harness? b16a3 in obd2 97 del sol
- CARB Legal B16A3 Header? No longer made?
- odd smell in bay
- High Idle Mystery 1993 Honda Civic VX
- New clutch, PP, disk aligned but PP does not fit in transmission bell housing
- 92 eg Heater problems
- Engine Swap
- how to swap a F22b3 into a 96 Honda civic hatch
- 97 OBD2A Civic LX D16Y7 - Help requested
- Wiring Harness Help
- Odd Power lock issue
- Emergency brake light on
- NEED HELP Del sol b16a3 swap wont run
- 95 civic hatch back seats
- recommendation on engine swap
- Which coolant type/brand should i use?
- How to check for ruined GSR HEAD/BLOCK
- 97 civic hatchback Canada vs US
- Looking for an ECU 37820P30G00
