View Full Version : Honda Civic / Del Sol (1992 - 2000)
- low rpm when coming to a stop already swapped out IAC and samething.
- DC2 shocks/springs vs EG shocks/springs?
- 96-98 spec b20b into 96 ek hatch
- Engine Light and OBD2 error codes 98 civic
- roof racks wat do i buy help!!!
- Overheating with good leakdown #'s
- Alternator Fuse keeps blowing 97 EX coupe
- Electric window clatter/stop at 99.9% closed
- body shop pricing for painting bumpers
- help! lowbeams not working after accident
- Starter troubles
- my car lags when i go!
- 92 civic key on ignition no power no lights nothing
- bogging and shaking problem
- built type r head how much power?
- what transmission will work with a civic type r (b16b) engine? and where to buy?
- 00 civic with GSR, clutch and engine problems ...Please help
- How do i take off a D series Clutch?
- oil pan need to know
- 92-95 civic cd player install no chass harness
- 65mm B piping?
- Accidentally loosened brake caliper banjo bolt.
- does anyone know what lip this is
- b18b1 swap starting issues!!!
- 95 eg6 si start problem
- EK Havac and Radio Din Gauge Pods?
- zc swap into 1996 civic ex?
- Help getting crank pulley bolt off. Yes! I've already searched and tried it myself
- my ek hatch
- suspension problem?
- My 95 eg
- front lower control arm bushing mount, civic 93
- my del sol is burning oil, few simple questions
- Just changed HEADGASKET, still smoking bad!
- transmission problems
- Quick Release vs. Quick-Tilt vs. Both
- compression specs
- Purple EJ1... Valve Cover Coloring
- Square Foot of a EG hatch interior?
- Color coded bumper strips on EK? Need ur help pics included
- Mugen 2 Racing seat questions
- Somethings up with my Suspension. Wheel Bearing Maybe?
- Brake inspection
- Making USDM b18c5 CA legal
- D15B Vtec "hesitates" when i give it gas.....
- problem with pass door and ACC wire at ignition
- b20 vtec
- join the REVOLUTION
- Transmission problems need help
- running a cone filter right on the throttle body?
- No VTEC!! Code 6
- need help with my headlight issue!!!!!!!
- need engine local chicago !!
- how much hp did i gain? - 93 del sol si
- HELP OVERHEATING
- Recommended alarm system for a 1994 civic hatchback?
- 96 civc (d16y8) squeaking
- motor mount questions
- mugen wheel color
- 1995 Honda Civic Blowing Blue Smoke after Engine Rebuild
- Slow GSR (B18c1)
- NEED HELP FAST OVERHEATING
- knock sensor question.
- Hows everyone getting mass inspecions with swaps?
- Tire rotation
- how many teeth on p30 waterpump gear?
- IAC-Valve problem, Need help
- How to remove the bezel out of my 1994 honda civic hatchback?
- vtec solenoid problem
- VX ecu and EGR wiring
- Where to find this?
- rusted distributor cap screw
- Starter going bad?
- HELP! THROWING CODES 3 & 41 - ENGINE BOGGING BARELY STARTING ETC!!!
- please help! Engine knocking
- head swap now overheating
- crv cluster into 99 civic?
- 92 Sedan window regulator problem.
- car dips below idle and almost dies?
- lowering springs question..
- 93 eg gsr help.
- Losing fuel pressure out of nowhere
- Blox Throttle Body ?'s
- The Definative Brake Upgrade Guide for bolt on brake upgrades for ’92 – 00 civics
- Lower control arm nut broke...
- 94 HB. DX. oil light
- where to mount oil cooler on eg
- EG.... HATCHBACK...JDM B16 SIR2... WHAT ELSE NEEDED
- motor bogs after i put it in vtec and burns oil
- any whp guesses?
- any one modified rear interior quarter panels on ej
- Boosting my D16z6 Please give experience
- P28 ECU how do you tell them apart
- How to valve lash adjustment help!!
- ABS??
- Been awhile....
- POST Slammed Del Sol PICS
- NRG steering
- 1999 civic b16a help
- Radiator leak after header install
- 99 civic wiht 96 gsr wont start need help!
- B series swap in EK civic.(auto)
- car wnt go no where???
- fog light problem
- B20B in EG Sedan
- quick question on recaro seats maitanance
- 98 civic tq question
- Grinding
- D16Y8 engine vibration? or something..
- Ek Side Markers*HELP*!!!
- CEL problem
- piston rings
- UptoDate H22a
- Motor sound/problem
- wtk how to remove rear antenna
- HELP!!! Rear Disc Conversion
- will the 94 integra harness work with 96 ls engine? please help
- trying to figure out which s80 tranny i have
- 92 Civic Wiring Help
- b18c into 99 si
- Civic that has no 1500-3000 rpm..
- 94 EJ1 B18B1 Fitv Problem
- OEM Foglight Install Help, Please!!!!
- driving with bad valve seals
- need advise on grinding gears please
- Idle surge & Computer
- swap ZC into civic92lx
- y8 header on a b7 block
- 93 CIVIC FENDERS
- B16 on EG5 hatch
- D15B7 mini-me swap running rich
- car wont start, battery is god, help
- EG JDM DOORS - need wire diagram to power them up
- Transmission problem I think?
- EM1 Running rich =( help
- Best car cover for us?
- vtec problem.. helpppppppppp pleaseeeeee...!!
- SRI with BPi velocity stack kit or Yowai-SS carbon fiber intake?
- Post EK pics with Rota Track R rims.
- starter problem please help
- New Fujita CAI, is a bypass valve a good idea?
- changing D16Y8 O2 sensors?
- Rear disk conversion question
- Just picked up an EBP Em1!
- b20 in a eg need help!
- jdm stores in LA
- 99 si swap into 93 civic
- Ignition coil wire
- b20b problem
- Finally finished my swap
- need help setting timing 92 VX
- NEED HELP! JDM D15B Thermo Switch the same as USDM D15B7?
- question on vti eg9 brake disc sizes
- best way to hook ropes to engine?
- Del Sol Customizing AC System
- problem with redline
- harness issues
- 96 Honda Civic Coupe HELP!? Electrical Short!
- Ls vtec...no vtec :(
- place to buy turbo kits
- Z6 harness for b16 swap???
- Does a P08 ecu have a speed limiter?
- 94 si hatch split axle in half
- type r launch control question
- Auto to manual b18 swap - Why is motor tilted toward the passenger side?
- D16y8 with GX Pistons?
- D16Y7 Header Compatability?
- D series "HP Racing" 1 piece header??
- Tranny upshifts between 4 - 5k RPM after timing belt & radiator replacement?
- Si grill
- CEL problem with jdm GSR in 99 EM1
- I Need Help!!! Map Sensor Problem!!!
- car starting issues!!!!!! EK hatch
- Brakeboost delete?
- HELP!!!OBD2 to OBD1 conversion
- 99 Volvo Recaros in Civic Ej1
- EMERGENCY!! Rear disc conversion problem!!
- new carpet for my 94 coupe??
- 95 Civic LX D15B7 burning oil - what's causing it?
- Video From Back In The Day???
- looking for some nice gauges...what do you think?
- Ej1 Fuse Blowing issue
- Hole below the gas cap
- Window molding
- Is this eg worth the price?
- whats better chipped a p28 or 72
- little black box in the back of block
- Any difference in Gas Caps?
- changing rear interior panel ej ?
- Winter tire and rim selection for 97 EL
- My 94 hatch makes too much noise, what can i do??? help!!!!!!
- random misfire cylinder 4
- JDM EG6 front seat comfort?
- Extreme Engine/Transmission Lag in B16A
- 95 coupe, auto tranny doesnt like to shift
- D15b vtec intake manifold gasket
- What tire size for daily driven?
- Motor swap in eg8 help!
- spoon mirrors help!
- My EK nearly finished! :)
- D15b Vacuum diagram
- help with compression/engine hesitation
- p75
- Broken Lock on Door (Interior)
- Hello, New to Honda-Tech. :)
- Retorquing head bolts.
- I messed up installing a new head gasket.
- upgrading to spoon front brakes and integra rear disk!!!help....
- my 97 EK hatch
- 1993 Honda Civic EX reverse light problem
- P0172 System Too Rich (Bank 1) Civic Si
- Pricing of 4 lug convertion?
- Rough idle and random misfires problem...
- CAI for a 97' LX
- 93 eg with 91 ebrake lines.....
- P72-2 head
- Vtec Malfunction
- Signs of a Distributor going bad?
- Paint a Carbon fiber Hood or No?
- help just bought a jdm ecu for my usdm b16
- DEQ issue JDM B16a
- Which Transmissin mount/bracket
- Smog problems and smog is due next month!!
- harness question.. In process
- Oil Pan Gasket Help
- D15 Bogging at full throttle. Help?
- interior lights not working
- 98 accord seats in EG
- Our friend wants a civic....
- Have a H2b question.
- replacing fuel line
- CAI vs. SRIw/ Velocity stack
- OBDI B18C1 Swap into 99' civic dx help!!
- Gauge Swap Problem
- 98-00 oem A/C kit fit in a 96 Dx?
- New to Honda-Tech 4DR EG
- car jerks and stutters when i ease off gas or accelerate...
- 92 EG project
- d15 fuel line on b18c??
- HELP! B-series swap
- issues with stalling and misfiring
- ecu
- help valve compression
- Need help finding replacement brake master cylinder
- quick del sol help.....EASY
- How many 02 sensor on 95 jdm d15b
- Del sol coilovers fit on an ek?
- O2 Sensor problem? 95 Civic B16a swapped
- 97 Civic Clutch Pedal Assembly In A 95 Civic?
