1995 Del Sol VTEC brake pads
Old 07-10-2012, 10:41 AM
boostshunt's Avatar
Default 1995 Del Sol VTEC brake pads
I have a 1995 Del Sol VTEC. I want to replace my brake pads with OEM parts. Can I use any Integra (non type-R), or Civic EX brake pads as replacements, front and rear?
I've searched and cannot find a compatible solution for direct OEM replacement pads. The parts number given to me from the local Honda dealership is inconsistent to what I found online. Tons of Civic and Integra OEM pads with different part numbers on Ebay but I want to make sure I purchase the correct application that will fit my car.
Any suggestions appreciated.
Thanks
Old 07-10-2012, 10:50 AM
The Grumpiest
grumblemarc's Avatar
Default Re: 1995 Del Sol VTEC brake pads
You didn't say what calipers on on the car. They usually have numbers stamped on them which will help you in your pad selection.
Old 07-10-2012, 01:09 PM
Seagull Management
94EG8's Avatar
IIRC you need to order Del Sol VTEC/JDM '92 - '95 Civic SiR pads. Integra calipers are not the same, neither are Civic EX calipers, they're very similar but not exactly the same.
Edit, this applies to the front pads/calipers. The rears are all the same.
Old 07-10-2012, 03:24 PM
dpetro1's Avatar
If you really want OEM, the part#'s are:
Front: 45022-SR3-V03 ~$42 online
Rear: 43022-SR3-020 ~ $39 online
no need to order online from ebay, just go to your local store and grab their pads. should be less than $30 an axle
bubskie
11-15-2010 03:40 AM
sLyBlAzNbBoI
08-13-2010 01:05 PM
S2KBAR
04-10-2006 02:50 AM
rotten
02-12-2004 05:41 PM
Quick Reply: 1995 Del Sol VTEC brake pads
