98 civic lsv swap. Misfire above 3k rpm CEL code 8
Yesterday I was drivin my 98 coupe and it would start braking up bad at 3k or higher, at one point the car even turned off. It's a b18a1 block with a b16 head. I've had codes 6 9 17 and 21 since I've had the car so I know this code 8 is new. Which is TDC sensor ? Correct me if I'm wrong. Any one know how to fix this ?
Re: 98 civic lsv swap. Misfire above 3k rpm CEL code 8
The ecu is a p72, but the same codes come up on a p28 as well. Also just started my car and ran codes again and code 4 popped up as well.
I took my entire harness out because I was finding cut wires every were plugs all loose and falling apart and some connectors not even found so I'm in the process of re doing the harness lets hope it turns out ok
KiD Fr0m Da 516
08-02-2004 06:36 AM
