eg hatch b20b - overheating
My first question, is my radiator fan suppose to be blowing hot air? And on very hot days what can I do to keep my engine cool so my car doesn't overheat and shut off? Any advice plz and thank you
Re: eg hatch b20b questions plz help!
Do you have an OEM thermostat installed correctly? Is it opening? Have you bled your coolant system? These are all basic things you should have told us in the original post.
If you havent done this or had someone else do it, you should atleast take a gauge and check the quality of your coolant. Its a bulb squeezing tool and should tell you your temperature capabilities and its cheap at a parts store. Radiator fluid doesnt last forever and needs to be changed like any other fluid, just at different mileage levels. Good luck.
Re: eg hatch b20b - overheating
have you checked the coolant level? are there any leaks?
if you car is overheating bad enough to shut off, the engine could be permanently damaged.
when i had my b20v in my sol i had a similar problem but i never over heated to the point of shut off..just warmed up a lil more when i was in it but always cooled back down to running temp. i read a few places that it was due to improper air movement.
The air blows toward the girl,and how do u know u need a radiator flush cuz I can't remeber the last time my car had one,and I think my car shutd off also cuz the idel air contorl valve is messed up
macmac89
23
02-06-2010 09:52 PM
spock_rocker
06-06-2005 03:32 PM
