Car will not start!!!!
Old 07-17-2012, 05:16 AM
jmoney45's Avatar
Default Car will not start!!!!
95 ex civic. it all started at work one day i was trying to start the car and it wouldnt so i check all cables to make sure everything was snug, tried and tried then bam turns on, ok im good. Next day same thing and waited a lil then turned on but since the day before yesterday nothing. Wont start cranks but does not start. Has spark, has fuel pressure, but injectors are not pulsing. Changed fuel filter was clogged the f up changed main relay, still nothing. Maybe ecu? not sure.
Checked grounds all over all good checked all fuses under dash and under hood multiple times. still nothing. Im at my wits end.
Please any ideas would be fantastic...
Old 07-17-2012, 06:21 AM
Former User's Avatar
Default Re: Car will not start!!!!
Is the starting problem still intermittent or is it now in full no-start mode?
When the engine won't start:
1) Will it start using starting fluid?
2) Do all four injector clips have voltage?
If yes to both^, then do this:
Unplug ECU connector A and test connector pins A23 and A24 for continuity to body ground. If fine, swap in a known good ECU.
Old 07-17-2012, 07:21 AM
jmoney45's Avatar
question if the ECU is bad for whatever reason will the distributor still throw spark?
Old 07-17-2012, 07:24 AM
The Grumpiest
grumblemarc's Avatar
Answer the questions. If needed, do the tests as indicated.
Old 07-20-2012, 10:43 AM
jmoney45's Avatar
Update: I took out the distributor, opened her up and there is oil inside. I cleaned it up and put it back on then she started right up, but dies again, so i have come to the conclusion that it is the distributor. Unless.....
Old 07-20-2012, 11:31 AM
This^ is just a guess.
Do the troubleshooting tests. Also check for CEL codes. Otherwise, this thread is pointless.
Old 07-20-2012, 04:12 PM
jmoney45's Avatar
your right.
Old 07-20-2012, 04:14 PM
jmoney45's Avatar
should the injectors have voltage with the car in the on(III) position?
Old 07-23-2012, 05:57 AM
jmoney45's Avatar
1.) It did act as if it was going to start when fluid was sprayed down intake manifold. It did not start completely.
2.) No voltage to injector clips.
The fuel pump does not prime with the key in the on position, I swapped in a brand new main relay and still nothing, only when i jump the pins on the main relay does the fuel pump turn on, other than that nothing. I checked and quadruple checked all fuses, made sure the thermostat ground was snug and grounded. Other than an ECU problem i wouldnt know what else to point my finger at.
Old 07-23-2012, 05:59 AM
rtimeteg's Avatar
def distributor thats how they are near death.
Old 07-28-2012, 06:02 PM
jmoney45's Avatar
Re-soldered old main relay: Problem fixed for the mean time will be some more resaerch.
Thank you everyone for your help..
millionphil
12-28-2012 12:34 PM
pyroom
12
01-23-2012 08:35 PM
skirrrt
14
11-06-2008 09:48 AM
fortymcpants
11
07-19-2008 08:03 AM
civic efb16
08-08-2005 09:00 PM
Quick Reply: Car will not start!!!!
