1994 Civic CX Hatchback (clutch questions)
Hi HT,
How do you tell if a clutch is worn out? What is a fair price to pay for an OEM clutch plus labor for a (5-Speed) 1994 Civic CX Hatchback?
My car was purchased in April of 2008 with 96,000 miles. The car now has 146,XXX miles. I don't think the previous owner ever changed the clutch but I could be wrong. Also, the car is stock.
The Grumpiest
Re: 1994 Civic CX Hatchback (clutch questions)
You can tell if the clutch is worn. There is no mistaking it. It will feel as if it it's okay and then loses it's grip at higher RPMs.
So far it doesn't feel like the clutch is slipping or losing grip. It does feel soft when I step on it though. I am just concerned that I have driven over 50,000 miles and haven't replaced it. What is the average number of miles a stock clutch can go for until it's time to replace?
The Grumpiest
It's time to replace it when it's starts to slip. There's no time frame. It can still be gently driven when it starts to slip so you'll be okay until you replace it.
Not sure what a hydraulic system or a master/slave cylinder is. When I step on the clutch I do hear a very light squeak. Getting and staying in gear hasn't been a problem. Slipping has not been a problem, yet.
What is a fair price to pay for an OEM clutch plus labor. (for future references) I may get an estimate from a Honda dealer to get the high end price. I'm sure local mechanics are cheaper. Are generic clutches just as reliable?
make sure your fluid is topped off. should help stiffen the pedal. or bleed the line to make sure there is no air.
Posted from Honda-tech.com App for Android
Seagull Management
I've seen lots of them last over 200,000 miles.
I've seen clutches last well over the 200k mark as well. most wont but it is possible. as for a price, you can get the exedy clutch kit at the local parts store for around 200 and labor will be different from shop to shop. I usually charge 200 for a clutch swap. Also, as far as the soft pedal. Like the other guy said, might be a hydrolic problem. pull back the carpet behind the dash on the driver floorboard and look for fluid. The clutch master cylinder is a very common problem on these cars and it really isnt that hard to change. good luck either way
On that thing about pulling back the carpet, is that if we see fluid leaking in? There is the thing the pedal attaches to. I'm guessing its the clutch master cylinder? And I see fluid coming out of it. Does that mean my master cylinder has a leak or problem?
My pedal travels a lot, but it isn't nearly until I let go of the pedal that I feel it starting to move the car(in first).
Hope I didn't 'hi-jack' the thread.
Just a quick tip to help you isolate the problem...pull the e-brake, put the car in 2nd or 3rd gear, rev the motor to around 2500-3000 rpms. Let the clutch pedal up while holding the rpms at the said level. If you kill the engine, the clutch is not slipping.
Also....do some searching around in these forums...there is a crapload of info in here...
For now, just bleed the clutch system. It's as easy as bleeding your brakes, and can be done in 20 minutes in your drive way with a friend.
That is the clutch master and usually they leak inside the car. I havent seen one leak down the firewall or anything. like I said, very common problem for these hondas. You can also adjust the travel of the clutch pedal by breaking the 12mm lock nut loose at the top of the clutch pedal and then adjust the threaded rod to your liking, good luck
Seagull Management
They're cheap enough that it's not a bad idea to change. Pull the boot back around the slave cylinder and see if it's wet, if not it's ok, if it is replace the slave cylinder.
tiresmoke
01-23-2006 08:56 AM
Hatch It
01-18-2005 06:54 AM
fred92htch
09-10-2004 05:36 AM
