Oil temp increasing!
So today I was in traffic, and I noticed that my oil temp was increasing and getting to hot, at one point it did hit the H. It would increase while idling or when I took my foot off the gas, but it would go back to normal when I started to accelerate. This is the first time it has happened and I thought it was gonna over heat on the highway...
I think it may be the hose to the radiator cause it was leaking onto the radiator. Also, could it be the radiator? Please help!
Its a stock 92 Hatch, manual tranny.
been there done that
Re: Oil temp increasing!
- remove radiator cap
- turn heat on full blast
- start car and let reach operating temp
- let fan kick on at least twice
- watch for air bubbles coming out of radiator until they stop
- fill with coolant as necessary
that's how i do it with mine
Alright, got the hose fixed, just need to get coolant tomorrow, and fiil her up and bleed it. Should be interesting. Any tips on bleeding it?
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
The fan does not need to be on, but it also wouldn't hurt. All you want to accomplish is to open the heater valve on the firewall so that coolant flows through and thereby removes air from the heater core.
Oh alright. Well thanks! I will be sure to do this within the next few days, as for now its gonna chill in the garage haha. Also, I figured out I have a D15Z1 motor, I never knew.
trying to flush coolant. there is a supposed engine drain plug to drain it out of the engine according to the books at auto zone, but I can't find it
EGcivic_95
31
01-29-2011 06:09 PM
PearlWhiteAccord
09-25-2002 12:15 PM
