94 D15b stalls with A/C on
When I got the car last year it always wouldn't start on the first try. It would take 2-3 tries but it would always start.
Around January it suddenly wouldn't start. Had the distributor replaced and it worked fine.
Lately I noticed when the fuel's running low (not empty) it would stall when I had to brake abruptly (which leads me to think it might be a fuel pump problem).It would start eventually in about a minute after a few tries.
Last night the A/C would suddenly die and then the engine would stall. The CEL would blink a few times and I would hear a buzzing sound from the ECU when it would blink. The moment I move the ignition to ACC and then back to on the A/C would go back again. Again the engine would start after about a minute. The car would run ok for about 100-150 meters and it would stall again. This time though I still had half a tank of fuel.
With the A/C off, the engine runs great. Stepping on the gas does not change anything, when the A/C suddenly dies, the engine will stall after a second
Any insights would be appreciated. Thanks!
Re: 94 D15b stalls with A/C on
That's what's strange about it there's nothing. It works fine without the A/C.
I had the same problem with my EK with a d16 engine before (sort of). The idle would get so low when the A/C is on that the engine would die but the moment I turn off the A/C switch idle would go back to normal. And if the engine does die it takes one flick on the ignition to start.
Not this time though, when I turn off the A/C switch the engine would still die and it would take a minute or two of cranking the engine to start
axtran
08-13-2006 09:24 AM
