1997 honda civic hatchback gauge cluster problem
Old 07-14-2012, 07:38 PM
Del_Slo_b16's Avatar
Default 1997 honda civic hatchback gauge cluster problem
Hey guys i have a 1997 Honda civic hatchback and it has a broken speedometer. The needle is broken and the trip/odometer doesn't work. Anyone got any ideas on that i can do besides replace the whole thing. thanks in advance
Old 07-14-2012, 07:49 PM
CO671's Avatar
Default Re: 1997 honda civic hatchback gauge cluster problem
You can replace a speedometer alone from another 6th gen Civic Cluster. Remove it from your vehicle then remove the clear plastic+black plastic and the gauge bezel then unscrew 4 screws in the back and drop the new one in (make sure you jot down your miles and keep it noted as a sticker in your door or in the glove compartment for future reference unless you want to go ahead and modify the replacement odometer)
If you're interested though, you can use a totally different vehicles cluster that's not a direct plug and play, you'll need to do some re-pinning and modify the mounting; or a CRV cluster which is direct plug and play + you get a tach.
Integra Cluster into 6th gen
http://www.clubcivic.com/board/showthread.php?t=97738
7th gen Civic cluster into 6th gen
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/2004-civic-cluster-ek-2720309/#post41431594
http://www.clubcivic.com/board/showthread.php?t=195635
s2000 cluster into 6th gen
http://www.d-series.org/forums/diy-f...ing-bezel.html
Old 07-14-2012, 07:54 PM
92lxsleeper's Avatar
here you go
http://www.youtube.com/watch?v=POPZL93qUaM
Old 07-16-2012, 11:18 AM
ViRStephen's Avatar
Good guideline with video to show more clearly, keep it, thanks.
rivaladversary
16
09-14-2009 03:07 AM
90 civic hb
04-06-2008 01:27 PM
949
09-07-2007 04:45 AM
kristobal6
04-07-2007 07:48 PM
chinkyEyez
11
05-21-2004 01:51 PM
Quick Reply: 1997 honda civic hatchback gauge cluster problem
