How to check engagement of shift selector
What connectors or wires do I check with an ohmmeter to get the reading with the brake is engaged. Describe how this can be done please. What settings do I put ohmmeter on?
Re: How to check engagement of shift selector
Trying to see why I cant get me shift selector to move. Cant hear it engage when the brake is applied. 98 civic dx automatic
Yes I checked the fuses. And the shift lock system . The description of solution in the first post is what will help me at this point.
No reason at all. Please just ask me what I need to post to help you help me. I have the cover off the shift selector. I check the continuity of the connectors with the ohmmeter. I am getting a reading. But I am not getting a reading when I apply the brake. I am thinking whrn the brake is applied I should bea able to get a reading beacuse something is being activated. Sorry if I not describing the problem. .
One other thing. I just swapped the engine 98 in out of a 97. The wiring harness is very slightly different. I want to know is this the culprit.
There are two/three connectors to the shift selector that I check.
How did you test the fuses?
Have you done the tests below?
bard
13
03-22-2007 02:34 AM
