REALLY BAD Threading in my transmission HELP
Ok so ive got the Ls swapped into my Ek (00'), i was driving one day and the bolts on the tranny side gave out.... i got my mechanic to put in bigger ones it held up pretty damn good for a month or two, i check it often cause its still suspect and its loose so i go home and try to tighten it... jack up the tranny and begin to tighten all of a sudden the bolt stops catching and starts spinning like wtf, now i need to fix this problem i dont wanna have to upsize the bolt every month or two nor do i want my transmission at a 45 degree angle again SOOOOOO WHAT SHOULD I DO, all help is greatly appreciated i just dont wanna buy another tranny or something serious pics below so you know wth im talking about THANKS
Re: REALLY BAD Threading in my transmission HELP
Luckily for you the bolt is accessible. It looks like you've already drilled it out some so I don't know what diameter to suggest. However the "correct what should you do" is get a caliper, measure the diameter, find the right drill bit and tap combination and tap out the hole with new threads. Torque the new bolt to spec.
I personally never drilled anything out, but umm it sounds like that's the route I'll take with her.... Had someone suggest thread locking it what do you think about that??
You can't supply the correct torque on one of your main engine mounts. I'd drill and tap it. If you're going to use thread lock/glue use JB Weld.
Alright thanks man, I'll prob get my mechanic to drill and tap it so I don't have to deal with it anymore ..... I'm pretty sure there integra mounts previous owner was really dumb so idk but they suck I know that much might need a new rear engine mount it tends to play on and off the chassis
They could be the mounts from the d series, mounts are one thing I do t specialize in but I do know they're some sort of oem
chargingsnaild1
Transmission & Drivetrain
01-22-2013 10:38 AM
explictness
12
12-26-2005 05:14 PM
hatchback_al
02-12-2004 10:30 PM
turbod16y7vtec
02-22-2003 01:16 PM
