Clutch pedal up almost all the way before it engages
Old 07-09-2012, 03:08 PM
JDMequalslife's Avatar
Default Clutch pedal up almost all the way before it engages
Car is a 1992 civic with a sohc zc. Just changed the clutch because the old one sucked, and id have to let the pedal up almost all the way up till it would engage. and now after a day its the same with this one am i suppose to adjust something or what?
Old 07-09-2012, 03:32 PM
embersanenders's Avatar
Default Re: Clutch help
How close to the top are we talking? There is an adjustment screw on your pedal near the top that you can use to adjust the pedal. Loosen up the nut, use your hand to spin it in or out which adjusts the pedal closer or away from the floor, re-tighten the nut.
My clutch does kind of the same thing, won't engage till I'm about 3/4 the way up, but I think that's pretty normal? Correct me if I'm wrong.
Old 07-09-2012, 04:54 PM
type_r_ek's Avatar
it SHOULD engage between 1/4 and 1/2 on a GOOD clutch, however i'd try and adjust the screw first, mine for example is maxed completely out (i need a clutch baaad) and it still engages roughly 1/2.
Old 07-09-2012, 05:07 PM
Like no lie i have to let it up and maybe like the last half inch it engages. i changed the clutch last wednesday. it was a cheap clutch
Old 07-09-2012, 05:10 PM
EF9_TryMe's Avatar
Your addressing this clutch as "cheap." Meaning the product is OEM aftermarket ? Or a cheap performance clutch ?
Old 07-09-2012, 05:23 PM
Cheap as in its a no name oem clutch. Now i first it was a little better, and it does engage hard. but now its like the one i had before and i know how to drive stick. only car ive had this problem with
Old 07-09-2012, 05:40 PM
Former User's Avatar
Do this and then leave it alone:
Old 07-09-2012, 06:06 PM
The Grumpiest
grumblemarc's Avatar
Sounds like you changed out the clutch for nothing.
Old 07-10-2012, 04:12 PM
EF9_TryMe's Avatar
Default Re: Clutch pedal up almost all the way before it engages
When you had the trans off, did you make sure the throw out fork was not bent ?
My buddy had a problem where he bent his throw out fork to the point where it slightly cracked.
This dilemma gave him a late engagement symptom as well, but like RON said .. adjust it and see what
happens.
Old 07-10-2012, 04:23 PM
CRX God
whited's Avatar
Bleed your hydro system. I had it happen to me once when swapping and engine. The clutch went to the floor, and only disengaged at the end. Bleeding it fixed the problem.
Old 07-10-2012, 05:47 PM
type_r_ek's Avatar
id try bleeding first then adjust it.. if that doesnt work buy a well known brand clutch or like stated before check amd make sure your trans is ok to begin with
Old 07-18-2012, 05:09 PM
sorry for the late response but ill try bleeding it. then adjusting it and see if that helps
Old 07-19-2012, 07:25 AM
kyden's Avatar
every civic/integra i have driven has had the clutch let out near the top.
Old 07-19-2012, 09:04 AM
hillbillycivic's Avatar
my 98 civic starts engaging in the top 3rd of the pedal travel, it dosnt realy do anything untill the top 1/4 though. iv been told its normal for these cars. so yours should be fine if its like mine.
i can even push the clutch half way in and shift fine not that i should be doing that its a bad habbit.
Old 07-19-2012, 01:17 PM
well i drove my friends 1998 civic and the clutch was a little better then mine, but when he drove mine he would rev it super high because it was taking to long to engage
JDM97dc2R
06-03-2009 05:33 AM
redman223
07-13-2007 07:19 PM
tigueremalo
01-14-2007 02:29 PM
Sinner
04-27-2006 10:44 AM
Steve
07-23-2001 01:42 PM
Quick Reply: Clutch pedal up almost all the way before it engages
