00 Civic A/C problem; works fine at idle, cycles while driving
Old 07-08-2012, 01:08 AM
Thunder_Hammer's Avatar
Default 00 Civic A/C problem; works fine at idle, cycles while driving
2000 Civic HX manual transmission
100 degrees ambient temperature
On Friday I had my a/c compressor, expansion valve, dryer, and condenser replaced. The a/c works fine while the car is idling; the compressor is running constantly, condenser fan running, and the vents blowing cold air.
The problem is while driving the a/c cycles about once every 30 seconds. I can feel it turn off, and then go back on with the click of the a/c clutch. When the compressor either turns on/off there also is an annoying change in pressure hissing sound coming from the expansion valve or evaporator area under the dash.
Also when I am at idle, with the ac running fine, and I rev the engine the compressor clutch clicks.
Any ideas on what the problem might be? Is this normal?
Old 07-08-2012, 09:16 AM
Former User's Avatar
Default Re: AC problem; works fine at idle, cycles while driving
Any cooling problems? 30-second cycles is not abnormal at 100F ambient temperature.
Old 07-08-2012, 02:06 PM
It is cooling fine. The loud clutch engagement, and the hissing pressurizing sound coming from the evaporator area made me question the work.
Old 07-08-2012, 03:05 PM
^Post a video with sound. The compressor clutch does, however, make a click sound when it engages.
Some hissing noise in the evaporator is nothing to worry about.
da_ska
07-18-2009 03:24 PM
blackcrx16
07-09-2009 01:48 PM
si_em1
10-28-2008 04:22 PM
einzelherz
08-28-2008 04:19 AM
TheIntegraGuy
11-03-2004 09:36 AM
Quick Reply: 00 Civic A/C problem; works fine at idle, cycles while driving
