92 eg hatch/b18b1 swap - idle problems
Car is a 92 eg hatch with a 1996 b18b1 in it, since I bought the car it's been doing this and I can't figure it out, at startup idle is too high, rpms sit round 2k constantly fluctuating between 1600 and 2100 as it heats up it ranges between a 300rpm difference, til it fully heats up thermo opens up, and then it drops to close to 100 maybe less, stays there for 2-3 seconds then keeps fluctuating between 400-900 but it will drop to 100 shortly after I stop at any light, car drives perfect, it's just when I'm not on gas, I think I may be a timing issue but the whole bog mode it goes Into makes me think it's a sensor buggin, no cel at all either, I allready did ficv. Ideas ?
Re: Motor problem stumped
Re: 92 eg hatch/b18b1 swap - idle problems
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
so far here it what i have done.
changed the ecu.
cleaned And even fully replaced the iacv
replaced every coolant hose and vaccum hose
did a new head gasket not too long ago
ive messed with the timing a few times without any luck,
i replaced all the distributer parts
ive adjusted the idle
nothings helps
owned the car 2 years done the same thing since day one,
could it possibly be the mass airflow sensor ?
the only thing that i havnt done is swapped in the charcoal canister for the integra one i still have the eg one. but i capped off one port and led the other under car to remove of gasses
ideas ?
oh no check engine light ever from this
jugger im gonna try the link you sent me on thursday and see if i get any luck, ill post back if it works, seems promising
changed the ecu.
nothings helps
ideas ?
so i figured it out.
so i went to go take off the fitv to find my year doesn't have one, then i got bored so i took off the throttle body, to find that the gasket had been cut by previous owner.... RETARD !!!! like seriously who cuts it ?
so new gasket, and voila ! fixed.
thanks for all the help guys
idk whether he took a gasket for another year or tb design and tried to make it fit but still just fail !
AnthonyPenn313
05-10-2013 04:47 AM
